I got the following information scanning UDP ports of my AC wifi module:
sudo nmap -sU 192.168.1.108
Password:
Starting Nmap 7.60 ( https://nmap.org ) at 2018-11-23 20:08 CET
Nmap scan report for 192.168.1.108
Host is up (0.014s latency).
Not shown: 998 closed ports
PORT STATE SERVICE
80/udp open|filtered http
49154/udp open|filtered unknown
MAC Address: 34:EA:XX:XX:XX:XX (HangZhou Gubei Electronics Technology)
I suposse next step is trying to send commands using the app while sniffing the traffic to that IP
After almost one week of reverse engineering the TFIAC application I figure it out how to control this Air Conditioner units over wifi with UDP packets and XML strings!!!
For testing purposes try to use some software like “Packet Sender” and send some commands to the unit IP on the port 7777 (UDP).
Use some of this commands (ASCII)
To Turn off: <msg msgid="SetMessage" type="Control" seq="12345"><SetMessage><TurnOn>off</TurnOn></SetMessage></msg>
To Turn on: <msg msgid="SetMessage" type="Control" seq="1"><SetMessage><TurnOn>on</TurnOn></SetMessage></msg>
To get actual state: <msg msgid="SyncStatusReq" type="Control" seq="12345"><SyncStatusReq></SyncStatusReq></msg>
To raise temperature (in Fº) <msg msgid="SetMessage" type="Control" seq="12345"><SetMessage><SetTemp>74</SetTemp></SetMessage></msg>
to down temperature (in Fº) <msg msgid="SetMessage" type="Control" seq="1"><SetMessage><SetTemp>74</SetTemp></SetMessage></msg>
Now I’m trying to figure it out why sometimes the seq must be 1 and another times needs to be 12345.
I’m not a developer but I hope that someone can test this and help me make a module for use this im HA or OpenHab.
Sounds lovely!
Wish I could help out but my knowledge is really limited.
If I can do anything to help out (that you could instruct me like 5yo.) I’d love to help, let me know!
great job! i’m just starting with Home Assistant and IFTTT.
I have a “Johnson” A/C Unit that works with TFIAC and I can’t connect it to my Google Home.
Do you think that it’s possible to send vía “Webhooks” some commands?
Just installed the component you created, it reads the sensor for current temperature, it detects the current a/c settings, the a/c beeps every time I alter something on the hass overview widgets, but, nothing happens! The a/c does not want to power on with any hass signal! As long as it’s powered on by IR remote or tfiac mobile app, all commands sent through hass work instantly!
Any thoughts on this?
Hello, today I have a new air conditioner from TCL and I hust installed the module!
I have the same symptoms like you! If the air conditioner is on, the I can change mode, temperatures , fans and everything, and I can close the aircondition.
The only thing it doesnt work is the power on! It justs beeps! The component is fantastic!
Can we have an update please? Or any one can help me to debug it?
thank in advance!
