As of version 2, you don;t give it the full path to the appdaemon.yaml file,. just the path to the directory it is in, so:
pi@hassbian:/home/homeassistant/.homeassistant/conf $ appdaemon -c /home/homeassistant/.homeassistant/conf
OK, I got past that issue. Here is the output:
sudo appdaemon -c /home/homeassistant/conf/
2018-02-14 15:23:24.985240 INFO AppDaemon Version 2.1.12 starting
2018-02-14 15:23:24.986238 INFO Configuration read from: /home/homeassistant/conf/appdaemon.yaml
2018-02-14 15:23:25.137383 INFO Starting Apps
2018-02-14 15:23:25.227844 INFO Got initial state
2018-02-14 15:23:25.229255 INFO App initialization complete
2018-02-14 15:23:25.230342 INFO Starting dashboard
2018-02-14 15:23:25.335561 INFO API is disabled
2018-02-14 15:23:25.348027 INFO Connected to Home Assistant 0.63.2
So, I do have 2.1.12. You used past tense when you mentioned that I’m in the “same state that I was”. Does that mean you have found a solution?
If I monitor the daemon output while I click a light button, I get the following error:
Error handling request
File "/usr/local/lib/python3.5/dist-packages/aiohttp/web_protocol.py", line 376, in start
resp = await self._request_handler(request)
File "/usr/local/lib/python3.5/dist-packages/aiohttp/web_app.py", line 310, in _handle
resp = await handler(request)
File "/usr/lib/python3.5/asyncio/coroutines.py", line 213, in coro
res = yield from res
File "/usr/local/lib/python3.5/dist-packages/appdaemon/rundash.py", line 181, in call_service
data = yield from request.post()
TypeError: cannot 'yield from' a coroutine object in a non-coroutine generator
Is this well known at this point?
We’re trying to find out if you are seeing the same issue - we were hoping for an error trace on the screen but you don;t seem to be getting one.
The OP reported that the problem went away when he upgraded to 3.0 beta. IF you do that though there are some changes to the config you will have to work through:
EDIT: OK, I see you posted the error and it’s the same.
Yes you are in the same state I was. And yes, I solved this issue by upgrading HAD to 3.0.0b3.
I followed the documentation here:
https://appdaemon.readthedocs.io/en/latest/INSTALL.html
Except for the the section “Install Using pip3” at the begining of the doc, I did:
sudo pip3 install --pre appdaemon --upgrade
instead of:
Then you can follow the rest of the tutorial and change the appdaemon.yaml file according to your needs.
Hi all. I updated the AppDaemon2 hassio plugin to 1.1.0 and I am getting the same error as the OP:
File "/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 381, in start
File "/usr/lib/python3.6/site-packages/aiohttp/web_app.py", line 310, in _handle
File "/usr/lib/python3.6/asyncio/coroutines.py", line 213, in coro
File "/usr/lib/python3.6/site-packages/appdaemon/rundash.py", line 181, in call_service
The dashboard updates its state only when refreshed, not in real time. Commands doesn’t work.
I’m using Hassio 0.64.3 on RPi, everything worked fine until update.
This are the startup messages:
Python Apps and HADashboard using AppDaemon 2.x for Home Assistant
By: Franck Nijhof <[email protected]>
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 03-version-requirements.sh: executing...
INFO: Supervisor version requirements checks passed.
[cont-init.d] 03-version-requirements.sh: exited 0.
[cont-init.d] 20-init-configuration.sh: executing...
[cont-init.d] 20-init-configuration.sh: exited 0.
[cont-init.d] 21-compiled-dir.sh: executing...
[cont-init.d] 21-compiled-dir.sh: exited 0.
[cont-init.d] 30-auto-password.sh: executing...
[cont-init.d] 30-auto-password.sh: exited 0.
[cont-init.d] 31-ha-url.sh: executing...
[cont-init.d] 31-ha-url.sh: exited 0.
[cont-init.d] 50-compiled-symlink.sh: executing...
[cont-init.d] 50-compiled-symlink.sh: exited 0.
[cont-init.d] 80-system-packages.sh: executing...
[cont-init.d] 80-system-packages.sh: exited 0.
[cont-init.d] 81-python-packages.sh: executing...
[cont-init.d] 81-python-packages.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
starting version 3.2.4
[services.d] done.
2018-03-03 20:33:51.534834 INFO AppDaemon Version 2.1.12 starting
2018-03-03 20:33:51.535472 INFO Configuration read from: /config/appdaemon/appdaemon.yaml
2018-03-03 20:33:51.795415 INFO Starting Apps
2018-03-03 20:33:52.041389 INFO Got initial state
2018-03-03 20:33:52.043845 INFO Loading Module: /config/appdaemon/apps/hello.py
2018-03-03 20:33:52.046809 INFO Loading Object hello_world using class HelloWorld from module hello
2018-03-03 20:33:52.378474 INFO hello_world: Hello from AppDaemon
2018-03-03 20:33:52.383267 INFO hello_world: You are now ready to run Apps!
2018-03-03 20:33:52.383790 INFO App initialization complete
2018-03-03 20:33:52.384852 INFO Starting dashboard
2018-03-03 20:33:52.399717 INFO API is disabled
2018-03-03 20:33:52.414764 INFO Connected to Home Assistant 0.64.3
2018-03-03 20:33:56.219884 INFO New dashboard connected: Main Panel
You seem to have an appdaemon version 2.x. I solved my issue by upgrading it to 3.x. Maybe you should give it a chance. Let us know.
I was waiting for a stable version, to avoid problems with the beta… and I got problems with the stable version
I understand, that’s sad but as far as I know, I didn’t hit any particular issue with the beta.
Updated to AppDaemon 2, changed configuration, cleared browser cache and now it is working again.
Nope… working on computer but I’m still getting the “Error getting state, check Java Console for details.” on the iPad. It works in Safari, but when I save it to home screen to get rid of address bar, I only get this popup.
I read that it should be because of caching, but I found no way to delete cache or reload. Already tried:
Having no access to the web server pages, I can’t try to add caching options in header, or change the JS file path to force a reload.
What version of iOS?
iOS 9.3.5, latest available for my iPad 2. Until latest update of the AppDaemon 2 plugin it was working without a glitch.
Did you mean AD 3?
Yes, my fault
Which version? I put some fixes in beta 4 that might help depending on your version of Python
so youll have to wait untill frenck changes the addon, or create your own.
