In FHEM it is possible to tell the radio-controlled socket to switch on but only for x minutes. You can send this command again and again to extend the time. If FHEM crashes, the socket will still switch off after the specified time.
Is it possible in HA to tell the socket Homatic HM-LC-Sw1-Pl-DN-R1 the maximum time it can run?
This is a safety function to ensure that the cooker hood switches off after HA fails.
Yes, with the new integration this is possible. Don’t know from the top of my head how exactly, but it’s possible to send the ON_TIME when turning on a device.
Description:
When the cooker bonnet is switched on, a timer of 60 seconds is set.
If the switch-on command is therefore not sent again, the
Homatic wireless switching actuator 1-fold intermediate plug “HM-LC-Sw1-Pl-DN-R1” switches off automatically.
Edit configuration.yaml
# Beim Einschalten der Dunstabzugshaube wird ein Timer vom 60 Sekunden mitgegeben.
# Wird der Einschaltbefehl also nicht erneut gesendet, schaltet der
# Homatic Funk-Schaltaktor 1-fach Zwischensteck "HM-LC-Sw1-Pl-DN-R1" automatisch ab.
switch:
switches:
dunstabzugshaube_timer:
friendly_name: EG - Küche - Dunstabzugshaube - Steckdose (Template Timer 1 Minute)
unique_id: template_dunstabzugshaube_timer
value_template: "{{ is_state('switch.hm_lc_sw1_pl_dn_r1_oeq0073242', 'on') }}"
turn_on:
service: homematicip_local.put_paramset
device_id: e1a913cb3bce8922ef8afc9c0a54c264
channel: 1
paramset_key: VALUES
paramset:
ON_TIME: "60"
STATE: true
turn_off:
service: switch.turn_off
entity_id: switch.hm_lc_sw1_pl_dn_r1_oeq0073242
Note: To find the ID, you can create an automation by inserting the switch as the ON action and switching to YAML mode. Then you can find the device ID.
I have configured it once. But I won’t be able to test it on site until the end of the week. So the service also starts the timer on the Homatic device and is independent of HA?
If so, thanks for the tip. I like that even more.
For all those who want to understand it. You can select Service as an action in the automation.
Works very well. I have just restarted HA from the road and the Homatic socket is still switched off after the time has elapsed. So I think the timer of the socket is being used. Thank you
The basic idea / The idea of @danielperna84 is better (put_paramset). Because it is not possible to extend the variant (switch_set_on_time).
My plan: Extend the switch-on timer by 5 minutes every 2.5 minutes.
put_paramset: Time is extended. The socket never switches off.
switch_set_on_time: The command is triggered every 2.5 minutes and the socket is switched on. However, the socket still switches off after 5 minutes.
Therefore, the put_paramset version is the best for me:
channel: 1
paramset:
ON_TIME: "300"
STATE: true
alias: >-
Schaltet die Steckdose ein, wobei der Steckdose eine Dauer von X Sekunden
gemeldet wird, damit die Steckdose immer abschaltet, wenn HomeAssistant
gestört ist.
