alias: Refresh iPad when Lovelace is updated
description: Ensure the view refreshes when I make changes to a Lovelace dashboard
- platform: event
event_type: lovelace_updated
condition: []
- service: browser_mod.refresh
data: {}
device_id: 7c29959dc26a200be0d4811f9eaa49d6
mode: single
Dude. This just changed my life. Thank you! Thank you!
Glad to be of service. I had enough of having to run around the home to reload panels by hand. Push save, receive bacon. That is how things ought to be.
Wellā¦yes and no. When i make (small) modifications of my lovelaces i open a page and āleave itā as backup. So if i do anything wrong i have a previous version without making a copy of lovelace before. With auto-refresh iād loose that. Thus saidā¦i miss any sort of history here⦠or should i say CTRL+Zā¦
Yeah, i know⦠it IS available if i would edit in yaml mode. But i rather edit single card at a time, because itās less code, more clear and easier to edit than whole yaml.
Alsoā¦auto refresh refreshes all cards and all views, while manual press on ārefreshā refreshes only that page - itās somewhat quicker.
I just made shortcuts for all my tablets so i donāt have auto refresh, but i can refresh them remotely when iām done or when itās needed.
I had the same requirement for a wall-mounted tablet. I wanted to avoid the approach of string matching so Iāve patched the code that handles the change event.
I have the following javascript in a custom module that seems to do what I need. Youāre welcome to copy-paste if itās any use.
// Patch the _lovelaceChanged handler in LovelacePanel to automatically
// refresh, instead of showing a message
const LovelacePanel = customElements.get("ha-panel-lovelace");
LovelacePanel.prototype._lovelaceChanged = function(){
// Log the reload happening
console.log("Lovelace changed, automatically reload", this);
// Logic copied from the origional _lovelaceChanged function
if (this._ignoreNextUpdateEvent) {
this._ignoreNextUpdateEvent = false;
return;
if (!this.isConnected) {
this._fetchConfigOnConnect = true;
return;
// Show a message for 1 second to announce the automatic reload
const notificationEvent = new Event("hass-notification", {
bubbles: true,
composed: true,
cancelable: false
notificationEvent.detail = {
message: "Automatically reloading config...",
duration: 1000,
dismissable: true
this.dispatchEvent(notificationEvent);
// Do the reload after one second
setTimeout(() => this._fetchConfig(false), 1000);
// log that the code has run
console.log("ā setup automatically reloading");
This was a brilliant starting point! Since I use FullyKiosk, I amended the example to reload the start page on the kiosk.
This is YAML for an automation. You can also create the same automation manually in the UI using a Manual Event trigger for event type ālovelace_updatedā and a Service Call action to press the load start url ābuttonā entity registered by the FullyKiosk integration.
alias: Reload kiosk when lovelace is updated
description: ""
- platform: event
condition: []
- service: button.press
data: {}
entity_id: button.dash_kiosk_load_start_url
mode: single
Not working for me. Not sure what Iām missing. I have this snippet in a file under config/www/custom.js.
Then I have the following in my config:
frontend:
extra_module_url:
- /local/custom.js
Finally, to test Iām opening up my dashboard in two tabs. I make a change in one tab and save it then go back to the other tab. I see the usual āYour dashboard was updated. Refresh to see changes?ā message, but it doesnāt auto refresh. Whatās the deal?
Then open browser console (Inspector), check for errors (syntax errors may stop loading custom.js silently when loaded via extra_module_url). Add console.log('custom.js loaded'); on the beginning of custom.js file.
Edit JS, remove the last check whether notification is present and contains expected information and just do the reload. Change value in setInterval(refreshOnLovelaceChange, 500); accordingly (3600 * 1000).
My version of custom.js being a mix of some ideas from this thread, working as of 2024.02:
console.log("custom.js loaded!");
function refreshOnLovelaceChange() {
// uncomment for Kiosk mode ('kiosk' param must be in the url, tho)
//var urlSearchParams = new URLSearchParams(window.location.search);
//if (urlSearchParams.get('kiosk') !== 'true') return;
var ha = document.querySelector("home-assistant");
if (!ha || !ha.shadowRoot) return;
var nm = ha.shadowRoot.querySelector('notification-manager');
if (!nm || !nm.shadowRoot) return;
var haToast = nm.shadowRoot.querySelector('ha-toast');
if (!haToast) return;
// uncomment to refresh for a given user name only (name as seen in UI)
/*var userNameToRefresh = 'user-for-dashboard';
try {
var userName = ha.shadowRoot.querySelector('home-assistant-main').shadowRoot.
querySelector('ha-drawer').querySelector('ha-sidebar').shadowRoot.
querySelector('a[class*=profile]').querySelector('paper-icon-item').
querySelector('span[class=item-text]').textContent.trim();
if (userName !== userNameToRefresh) {
return;
} catch (error) {
//console.error(error);
if (haToast.opened && haToast.text.includes('dashboard was updated')) {
console.log("Refreshing page...");
try {
haToast.querySelector("mwc-button").shadowRoot.querySelector("#button > span.mdc-button__label").click();
} catch (error) {
console.log("Going to reload whole page instead...");
location.reload();
setInterval(refreshOnLovelaceChange, 1000);
If you update the script, then you need to clear browser cache (reload hard). It also works in the Companion app (you will need to clear its data to pick up the changes - you will need to login and configure the app tho).
On my office computer I have a screen that has a dashboard that shows my security cameras.
I installed that page as an app in Edge and set it to auto-refresh once an hour. There is an add-on for that.
On a pc reboot, it will automatically load that dashboard for me also.
Not much good for an android tablet thoughā¦
My Home Assistant Server runs on a Home Assistant Blue. My Raspberry pi400 utilises the full screen kiosk (above) to log into the server via Nabu Casa.
The flow is very simple, consists of an inject node that injects the SSH command via msg.payload, every 10 minutes. This is so my Ventusky weather map shows the latest data, running in iFrame.
The part of the above that completes the virtual key press of ctrl+r is xdotool key ctrl+r
I discovered this command works directly after my other attempts failed. See this website XDOTOOL fails. Error: Canāt open display: (null)
Failed creating new xdo instance
Setup for the SSH V3 node is as below. Hostname: The IP address of your Raspberry Pi Port: 22 (default setting) Username: The username you use to log into your Pi Password: The password you use to log into your Pi Ssh: Leave this as the default grey text, the msg.payload from the inject node needs no other file path.
I am using Debian GNU/Linux 12 (bookworm). I just checked raspi.config and I am running X11 Openbox window manager with X11 backend. I am unsure if you can set that and have your Pi run correctly?
