[Solved] Looping through helpers in script possible?
I have around 8 HUE motion sensors in my house. I can write a script that checks them all individually like i did for my doors but that are only 3 (i know should be done in a loop too).
The jinja help file doesn’t give me much info on how to access the Helper if have named motion_sensors.
Any hints are welcome
“Checks them” how? Can you be more specific about what you’re trying to accomplish?
If you are trying to check for motion on any of the sensors then probably the best way would be to put them in a helper group. The group sensor will be triggered if any individual sensor in the group is triggered.
They are in a helper group, i would like to run a monthly check to look at battery status and if they go below 10% message me the one (or more) that are below 10%.
I have them in a helpergroup so how can i use a script to loop through the objects in a helpergroup?
See the expand function: Templating - Home Assistant
There are some good low battery blueprints that can save you the trouble. Here is one:
Thanks for this that helped
