It would be nice to also have a stop button between the arrows. Is there any plans to get this in a future release?
The problem is we donāt know the command for stop. Weāve reverse engineered IKEAās internal API but havenāt yet found that command.
Ok, so thatās why I cant use the cover.stop_cover to stop itā¦
Ok, good, I canāt seem to find a relevant issue on ggravlingen/pytradfri?
Sorry, This thread is maked as Solved, Why are we still posting to it when there is a general support thread for the Blinds under ??? : -
Surely people should list issues/seek support there ???
We are in danger of having multiple threads to both check and read and now it is integrated, we should all have a common base to work from.
Im happy with my Fyrtur support in HA⦠automations work smooth, and better than IKEAās own app
The only thing that doesnāt seem to work is HA isnāt picking up the current state / position of the blinds⦠as the rest of the people have reported above here I guess⦠I can live with that issue for now.
Overall, good job so far
Hey Nicklas,
Iām about to buy a few of those myself. Looks good and happy to hear that it works for you so well.
Did HA just pick of the FYRTUR after the recent update of HA?
Does it show the battery status of the FYRTUR as well?
First of all: Thanks for the great work making this integration happen!
For a while, I have been looking for a suitable switch to control my garage door, and after having grouped a few IKEA roller blinds together, Iām left with a couple of leftover TrĆ„dfri open/close remotes, and they would fit the bill perfectly.
I see the remotes I have paired to my roller blind groups turn up as sensors in HA, but only exposing manufacturer, SW and battery details. Any plans for trying to expose the button press states as well?
I understand the challenges of working with an undocumented API, and that there are other and more pressing unresolved issues with this integration yet to be ironed out, but if you should discover a way to expose this state as well, I believe there are many besides me who would love to see it in a future version!
Yes it does.Both remote and blinds.
Thanks! Ordered!
Hi! Could you @fribse test these files as custom component and see if your blinds work?
i am not sure if its my setup that fails or if its the code that is wrong.
Hope you can help so i know if its my setup or the code
Yes, Iāll have a look at it, I hope I can do it today when I get home.
Will it interfere with the existing, or just ātake overā the integration, or is it seperate?
Great! It will ātake overā the integration
This is how mine looks now. I have two blinds. If i press up/down on one blind at the time everything works great. But if i want to close both blinds at the same time it freezes Tradfri.
Ok, I oly have one as of now, so I wonāt have that problem
How do I easiest get the files, donāt really want to copy each file into a local file. Iām on a HASS.io.
Download this: https://github.com/home-assistant/home-assistant and then open the folder and go to /compontens and find the tradfri folder. Put tradfri folder in the custum component folder. Delete tradfri integation in HA and restart. After that you add the tradfri integration.
Ahh, ok, I thought I could download just the tradfri as an archive, Iāll get it done, after work I have to and see a buddy about some 3d-printed cases for me, and I hope I get it tested after that.
Hi!
Did you get it to work?
I finally got some time today, I looks very promising, the arrows are updated correctly, the slider updates continuesly.
I wish I had more than the one I could test on.
I got everything working now. After i added both TRADFRI Signal Repeaters one for each blind everything started to work great.
I had to roll back to the release software(0.100.2), yesterday I lost half of the lights (I have about 30 in all).
The lights worked through GA, but were all jumbled in states in HA and didnāt react on commands.
