Hi Fellow HAers-
I struggled with trying to add the Schlage Deadbolt to Home Assistant. The answers are buried in multiple thread posts and component posts. I hope this helps and consolidates it for folks!
Steps to Add Schlage Deadbolt Z-Wave Connect to HA
if you already added your lock but not securely scroll to bottom of this post to learn how to remove it first
In order to add secure ZWave device (which the Schlage lock is) you need to add a network key to your ZWave configuration.
A) Go to your command line in your Pi and execute this command
cat /dev/urandom | tr -dc '0-9A-F' | fold -w 32 | head -n 1 | sed -e 's/\(..\)/0x\1, /g' -e 's/, $//'
B). This command randomly generates a network key for you copy that (it looks like you can also go to a website to grab a key, but I just used the command line) -
Open your configuration.yaml file find your Zwave configuration parameters it’ll look like this (maintain formatting)
zwave:
usb_path: /dev/ttyACM0
network_key: "<YOUR NETWORK KEY>"
Restart Home Assistant
Find your programming code for the Schlage Lock - it was on the back of the lock prior to installing
Navigate to the ZWave Manager in the HA UI ->Configuration -> Z-Wave
When you’re ready click “Add Node Secure”
Now go to your Schlage Lock and follow these instructions (came with your lock)
If you saw a check mark on the lock after a few minutes you should be able to see the lock appear in your HA States search for Schlage
Optional if you want to test to see if it works from a lock/unlock perspective go to services (within Developer tools). Let’s say the deadbolt is unlocked - select “lock.lock” service, then “lock.locked” entity, in the service data put
"entity_id": "lock.locked",
"code": "<your access code, not programming code>"
How to remove the Schlage Lock from ZWave, because you didn’t add it securely
1). Go to your Z-Wave manager in HA UI - Configuration -> Z-Wave
2). Click Remove Node when you are ready
3). Go to your Schlage Lock and follow the instructions below, same as enrolling
4). It’ll take a little bit for Home Assistant to remove it completely, wait a few minutes and restart HA
5). Now go back to the top to add the Deadbolt using Z-Wave “Add Node Secure”
