EDIT: So my issues seem to have been related to updating the Xiaomi Gateway v3 to the 1.5.0_0027 firmware. Downgrading to 1.5.0_0026 by following this guide fixed all my issues. PLEASE NOTE: The credentials for the gateway have been changed to username: “admin” & password: “admin” with this update! No password or 123123 don’t work when you’re on 1.5.0_0027
Hey all, I have quite a lot of Xiaomi/Mija IoT devices that connect to a Xiaomi Gateway V3 which I integrate into Home Assistant by using AlexxIT’s terrific custom component.
Unfortunately some update, either updating to Home Assistant 2021.7.3 or accidentaly updating the Xiaomi Gateway 3 to 1.5.0_0027, broke my setup with all Xiaomi/Mija devices becoming unavailable.
In the Xiaomi Gateway 3 debugger I get the following logs, but I don’t quite know what to make of them as all the configs are as outlined in AlexxIT’s documentation and have been working previously:
I power the gateway off then on again and it worked with the default telnet open command
with the password 123123 even though it runs firmware 1.5.0_0027
Hello Schmetis, ive been having issues with one of my gateways, if the device is reset I have to add it again in HomeAssistant. Ive not had any problems with my other gateway and have noticed that one is running v.0026, but the problem one is running 0027 like yours was.
Im trying to downgrade, but failing at the first step in the guide linked (probably because i have no idea what im doing in Putty!!)…
i enter the correct IP address for the problem gateway, trying with both port 22 (the default when i load Putty), and port 23 (which is showing in the image in the guide)… 22 gives an error : “Network Error: Connection Refused”, and 23 doesnt seem to do anything.
I assume i should be entering the username and password somewhere, i can put a username in Connection- Data, but no joy with that. How did you get into it Schmetis?
Hi @marine88
What do you mean by “the rest”
I only have thermometers, I don’t know whether the case is different for Sensors and light.
What communication protocol do these run? Zigbee, Wifi, BLE?
Are these available as child devices in the ME Home app under the gateway settings?
The show automatically in HA but are unavailable?
Have you tried to remove the “Xiaomi Gateway 3” integration and add it again?
Sorry to drag up an old thread but I noticed the comment about the light becoming unavailable but the rest still working… that’s my issue.
I have an old Xiaomi Gateway still on firmware 1.0.9 because I never wanted to risk breaking HA connectivity. After a HA reboot the device works perfectly and both my chime automation and light control automation work. After a day or so (maybe less) the light becomes unavailable but the chime still works fine (I use it for my doorbell). I have no idea why this happens. It’s been like it for a while but I hadn’t much attention as the light automation wasn’t really bugging me, but now it’s dark in the morning due to it being winter (Australia) I’d like the light to work again.
Nope. Same situation, the light stops working after a few hours / maybe a day but the ringer still works. A full reboot of HA gets it going again… for a day.
hmm maybe I should look at moving it. I remember having a aqara to mqtt solution before. I only use this thing for a light when I’m on a teams call. And wouild replace it is a smart/wifi connected night light existed (in our region of the world)
