Something wrong with my theme
I am using this theme:
darkmix:
# Main colors
  primary-color: '#03A9F4'
  accent-color: 'red'
  dark-primary-color: 'var(--primary-color)'
  light-primary-color: 'var(--primary-color)'
# Text colors
  primary-text-color: 'white'
  text-primary-color: 'var(--primary-text-color)'
  secondary-text-color: 'silver'
  disabled-text-color: 'silver'
  label-badge-border-color: 'lime'
# Background colors
  primary-background-color: '#141A32'
  secondary-background-color: '#141A32'
  divider-color: 'var(--primary-color)'
# Table rows
  table-row-background-color: 'var(--primary-background-color)'
  table-row-alternative-background-color: 'var(--primary-background-color)'
# Nav Menu
  paper-listbox-color: 'var(--primary-color)'
  paper-listbox-background-color: 'var(--primary-background-color)'
  paper-grey-50: 'var(--primary-text-color)'
  sidebar-icon-color: 'var(--primary-color)'
# Paper card
  paper-card-header-color: 'var(--primary-color)'
  paper-card-background-color: "#1E2747"
  paper-dialog-background-color: 'var(--primary-background-color)'
  paper-item-icon-color: 'var(--primary-color)'
  paper-item-icon-active-color: 'lime'
  paper-item-icon_-_color: 'lime'
  paper-item-selected_-_background-color: '#282C34'
  paper-tabs-selection-bar-color: 'lime'
# Labels
  label-badge-red: 'var(--primary-color)'
  label-badge-text-color: 'var(--primary-text-color)'
  label-badge-background-color: 'var(--paper-card-background-color)'
# Switches
  paper-toggle-button-checked-button-color: 'var(--primary-color)'
  paper-toggle-button-checked-bar-color: 'var(--primary-color)'
  paper-toggle-button-checked-ink-color: 'var(--primary-color)'
  paper-toggle-button-unchecked-button-color: 'var(--disabled-text-color)'
  paper-toggle-button-unchecked-bar-color: 'var(--disabled-text-color)'
  paper-toggle-button-unchecked-ink-color: 'var(--disabled-text-color)'
# Sliders
  paper-slider-knob-color: 'var(--primary-color)'
  paper-slider-knob-start-color: 'var(--primary-color)'
  paper-slider-pin-color: 'var(--primary-color)'
  paper-slider-active-color: 'var(--primary-color)'
  paper-slider-container-color: 'linear-gradient(var(--primary-background-color), var(--secondary-background-color)) no-repeat'
  paper-slider-secondary-color: 'var(--secondary-background-color)'
  paper-slider-disabled-active-color: 'var(--disabled-text-color)'
  paper-slider-disabled-secondary-color: 'var(--disabled-text-color)'
# Google colors
  google-red-500: 'red'
  google-green-500: 'lime'
# Date picker
  lumo-primary-text-color: 'var(--primary-color)'
  lumo-body-text-color: 'var(--primary-color)'
  lumo-primary-color: 'var(--primary-color)'
  paper-grey-200: 'var(--paper-card-background-color)'
  ha-card-border-radius: '20px'
#  ha-card-background: rgba(150, 150, 150, .1)
  mini-media-player-accent-color: var(--primary-text-color)
  mini-media-player-overlay-color: rgba(255, 255, 255, .75)
  mini-media-player-artwork-opacity: 1
  mini-media-player-progress-height: 24px
But when going to the the ‘manage connected devices’ in the settings i get this:
What to add in the theme to make also this setting visible?
I’m having the same problem when searching unused entities in Lovelace UI -
I must be missing some kind of css setting in my theme below:
Yes, i think so, but as i am not so good in css settings, cannot find the solution. If you find it, just let me know…
Well I found a Light - Green theme with a visible font color - but non of the dark themes have this font color:
I think there is a way also in dark themes, maybe adding some lines… We need some guru of the css settings…
Try adding
card-background-color: 'var(--primary-background-color)' # Card background
To your theme. It’s what worked for me.
Thanks, it works!
Great! Glad it works.
Great it works!
