After adding an RFLink to Home Assistant I can’t get my RTS screen visible in the frontend. I’v been trying for a few weeks now with no succes. I’v used the RFLink Cover manual. The log file show the RFlink and the commands to the screen
In configuration.yaml
rflink:
port: /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_7413736383735140F110-if00
logger:
default: error
logs:
rflink: debug
homeassistant.components.rflink: debug
and
sensor: !include_dir_merge_list includes/sensors
in includes/sensors there is a file rflink.yaml
cover: - platform: rflink devices: rts_bcd833_01: name: Zonnescherm
I’v added the device to a group:
rflink:
entities:
- switch.rts_bcd833_01
Log:
2018-05-05 19:10:12 INFO (MainThread) [homeassistant.components.rflink] Initiating Rflink connection
2018-05-05 19:10:12 INFO (MainThread) [homeassistant.components.rflink] Connected to Rflink
2018-05-05 19:10:12 DEBUG (MainThread) [rflink.protocol] connected
2018-05-05 19:10:13 DEBUG (MainThread) [rflink.protocol] received data: 20
2018-05-05 19:10:13 DEBUG (MainThread) [rflink.protocol] received data: ;00;Nodo RadioFrequencyL
2018-05-05 19:10:13 DEBUG (MainThread) [rflink.protocol] received data: ink - RFLink Gateway V1.
2018-05-05 19:10:13 DEBUG (MainThread) [rflink.protocol] received data: 1 - R48;
2018-05-05 19:10:13 DEBUG (MainThread) [rflink.protocol] got packet: 20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
2018-05-05 19:10:13 DEBUG (MainThread) [rflink.protocol] decoded packet: {‘node’: ‘gateway’, ‘protocol’: ‘unknown’, ‘hardware’: ‘Nodo RadioFrequencyLink’, ‘firmware’: ‘RFLink Gateway’, ‘version’: ‘1.1’, ‘revision’: ‘48’}
2018-05-05 19:10:13 DEBUG (MainThread) [rflink.protocol] got event: {‘id’: ‘rflink’, ‘hardware’: ‘Nodo RadioFrequencyLink’, ‘firmware’: ‘RFLink Gateway’, ‘version’: ‘1.1’, ‘revision’: ‘48’}
2018-05-05 19:10:13 DEBUG (MainThread) [homeassistant.components.rflink] event of type unknown: {‘id’: ‘rflink’, ‘hardware’: ‘Nodo RadioFrequencyLink’, ‘firmware’: ‘RFLink Gateway’, ‘version’: ‘1.1’, ‘revision’: ‘48’}
2018-05-05 19:10:13 DEBUG (MainThread) [homeassistant.components.rflink] unhandled event of type: unknown
2018-05-05 19:11:00 DEBUG (MainThread) [rflink.protocol] received data: 20;01;Debug;RTS P1
2018-05-05 19:11:00 DEBUG (MainThread) [rflink.protocol] received data: ;ac4100dcbcd833;
20;02;
2018-05-05 19:11:00 WARNING (MainThread) [rflink.protocol] dropping invalid data: 20;01;Debug;RTS P1;ac4100dcbcd833;
2018-05-05 19:11:00 DEBUG (MainThread) [rflink.protocol] received data: RTS;ID=bcd833;SWITCH=01;
2018-05-05 19:11:00 DEBUG (MainThread) [rflink.protocol] received data: CMD=DOWN;
2018-05-05 19:11:00 DEBUG (MainThread) [rflink.protocol] got packet: 20;02;RTS;ID=bcd833;SWITCH=01;CMD=DOWN;
2018-05-05 19:11:00 DEBUG (MainThread) [rflink.protocol] decoded packet: {‘node’: ‘gateway’, ‘protocol’: ‘rts’, ‘id’: ‘bcd833’, ‘switch’: ‘01’, ‘command’: ‘down’}
2018-05-05 19:11:00 DEBUG (MainThread) [rflink.protocol] got event: {‘id’: ‘rts_bcd833_01’, ‘command’: ‘down’}
2018-05-05 19:11:00 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {‘id’: ‘rts_bcd833_01’, ‘command’: ‘down’}
2018-05-05 19:11:00 DEBUG (MainThread) [homeassistant.components.rflink] device_id not known, adding new device
2018-05-05 19:11:00 DEBUG (MainThread) [rflink.protocol] received data: 20;03;Debug;RTS P
2018-05-05 19:11:00 DEBUG (MainThread) [rflink.protocol] received data: 1;ac4100dcbcd833;
20;04
2018-05-05 19:11:00 WARNING (MainThread) [rflink.protocol] dropping invalid data: 20;03;Debug;RTS P1;ac4100dcbcd833;
2018-05-05 19:11:00 DEBUG (MainThread) [rflink.protocol] received data: ;RTS;ID=bcd833;SWITCH=01
2018-05-05 19:11:00 DEBUG (MainThread) [rflink.protocol] received data: ;CMD=DOWN;
2018-05-05 19:11:00 DEBUG (MainThread) [rflink.protocol] got packet: 20;04;RTS;ID=bcd833;SWITCH=01;CMD=DOWN;
2018-05-05 19:11:02 DEBUG (MainThread) [rflink.protocol] received data: 20;0
2018-05-05 19:11:02 DEBUG (MainThread) [rflink.protocol] received data: 5;Debug;RTS P1;ad1400ddb
2018-05-05 19:11:02 DEBUG (MainThread) [rflink.protocol] received data: cd833;
20;06;RTS;ID=bcd
2018-05-05 19:11:02 WARNING (MainThread) [rflink.protocol] dropping invalid data: 20;05;Debug;RTS P1;ad1400ddbcd833;
2018-05-05 19:11:02 DEBUG (MainThread) [rflink.protocol] received data: 833;SWITCH=01;CMD=STOP;
2018-05-05 19:11:02 DEBUG (MainThread) [rflink.protocol] got packet: 20;06;RTS;ID=bcd833;SWITCH=01;CMD=STOP;
2018-05-05 19:11:02 DEBUG (MainThread) [rflink.protocol] decoded packet: {‘node’: ‘gateway’, ‘protocol’: ‘rts’, ‘id’: ‘bcd833’, ‘switch’: ‘01’, ‘command’: ‘stop’}
2018-05-05 19:11:02 DEBUG (MainThread) [rflink.protocol] got event: {‘id’: ‘rts_bcd833_01’, ‘command’: ‘stop’}
2018-05-05 19:11:02 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {‘id’: ‘rts_bcd833_01’, ‘command’: ‘stop’}
2018-05-05 19:11:02 DEBUG (MainThread) [homeassistant.components.rflink] device_id not known, adding new device
2018-05-05 19:11:03 DEBUG (MainThread) [rflink.protocol] received data: 20;07;Debug
2018-05-05 19:11:03 DEBUG (MainThread) [rflink.protocol] received data: ;RTS P1;ae2700debcd833;
2018-05-05 19:11:03 DEBUG (MainThread) [rflink.protocol] received data: 20;08;RTS;ID=bcd833;SWI
2018-05-05 19:11:03 WARNING (MainThread) [rflink.protocol] dropping invalid data: 20;07;Debug;RTS P1;ae2700debcd833;
2018-05-05 19:11:03 DEBUG (MainThread) [rflink.protocol] received data: TCH=01;CMD=UP;
2018-05-05 19:11:03 DEBUG (MainThread) [rflink.protocol] got packet: 20;08;RTS;ID=bcd833;SWITCH=01;CMD=UP;
2018-05-05 19:11:03 DEBUG (MainThread) [rflink.protocol] decoded packet: {‘node’: ‘gateway’, ‘protocol’: ‘rts’, ‘id’: ‘bcd833’, ‘switch’: ‘01’, ‘command’: ‘up’}
2018-05-05 19:11:03 DEBUG (MainThread) [rflink.protocol] got event: {‘id’: ‘rts_bcd833_01’, ‘command’: ‘up’}
2018-05-05 19:11:03 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {‘id’: ‘rts_bcd833_01’, ‘command’: ‘up’}
2018-05-05 19:11:03 DEBUG (MainThread) [homeassistant.components.rflink] device_id not known, adding new device
2018-05-05 19:11:03 DEBUG (MainThread) [rflink.protocol] received data: 20;09;Debu
2018-05-05 19:11:03 DEBUG (MainThread) [rflink.protocol] received data: g;RTS P1;ae2700debcd833;
2018-05-05 19:11:03 DEBUG (MainThread) [rflink.protocol] received data: 20;0A;RTS;ID=bcd833;SW
2018-05-05 19:11:03 WARNING (MainThread) [rflink.protocol] dropping invalid data: 20;09;Debug;RTS P1;ae2700debcd833;
2018-05-05 19:11:03 DEBUG (MainThread) [rflink.protocol] received data: ITCH=01;CMD=UP;
2018-05-05 19:11:03 DEBUG (MainThread) [rflink.protocol] got packet: 20;0A;RTS;ID=bcd833;SWITCH=01;CMD=UP;
2018-05-05 19:11:08 DEBUG (MainThread) [rflink.protocol] received data: 20;0B
2018-05-05 19:11:08 DEBUG (MainThread) [rflink.protocol] received data: ;Debug;RTS P1;af2700dfbc
2018-05-05 19:11:08 DEBUG (MainThread) [rflink.protocol] received data: d833;
How can I get the screen visible in the frontend so I can use it in the frontend like in this topic SOMFY ZRTSI Z-Wave to RTS Controller
Screenshot from that topic:
