I´m searching for a way to display the recently played songs of my sonos player.
Right now I´m using a History Graph but you have to use the mouse pointer to see the songs recently played.
I´m searching for a way to show a list of three or more songs.
Is there an elegant way to do this?
You could obviously use some helper variables and shift them each time the song changes.
But the history is there already. otherwise, the history graph wouldn’t work. so there must be a way to get the last value and the second to last value and so on.
Did you figure this out? I’m looking to do the same thing.
I have solved it as follows:
I created 5 helpers as text (for the last 5 played songs) for each media device.
Then I have an automation that save the current title and artist and moves the other texts to the next helper text.
These helper texts are than shown in a markdown card in the ui.
that is the automation:
alias: Google Home mini - Track changed
description: ""
- platform: state
entity_id:
- media_player.esszimmer
attribute: media_title
condition:
- condition: device
device_id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
domain: media_player
entity_id: media_player.esszimmer
type: is_playing
- service: input_text.set_value
entity_id: input_text.googlehomemini_current_track_5
value: "{{ states('input_text.googlehomemini_current_track_4') }}"
entity_id: input_text.googlehomemini_current_track_4
value: "{{ states('input_text.googlehomemini_current_track_3') }}"
entity_id: input_text.googlehomemini_current_track_3
value: "{{ states('input_text.googlehomemini_current_track_2') }}"
entity_id: input_text.googlehomemini_current_track_2
value: "{{ states('input_text.googlehomemini_current_track') }}"
value: >-
{{state_attr("media_player.esszimmer", "media_artist")}} -
{{state_attr("media_player.esszimmer", "media_title")}}
mode: single
i hope that helps you.
Thank You!
If you’re interested, here’s my version. It uses a single Trigger-based Template Sensor to maintain a record of the last 5 tracks played (artist, title, time). It can easily be expanded from 5 to whatever quantity is needed.
template:
- trigger:
- platform: state
entity_id: media_player.kitchen
- name: Recent Tracks
state: "{{ now().timestamp() | timestamp_custom() }}"
attributes:
tracks: >
{% set current = this.attributes.get('tracks', []) %}
{% set new = [{
"artist": trigger.to_state.attributes.media_artist,
"title": trigger.to_state.attributes.media_title,
"time": now().isoformat() }]
if is_state('media_player.kitchen', 'playing') else [] %}
{{ (new + current)[:5] }}
Here’s the sensor’s information.
Here’s the content for the Markdown card.
|Artist||Title|
{% for x in state_attr('sensor.recent_tracks', 'tracks') | default([], true) -%}
|{{x.artist}}||{{x.title}}|
{% endfor -%}
Here’s the appearance of the Markdown card.
that is a really nice solution. much easier to setup than mine.
i added an if statement to check if my soundbar is playing tv sound.
#### Media Player History ####
- trigger:
- platform: state
entity_id: media_player.beam
- name: Recent Tracks Sonos Soundbar
attributes:
tracks: >
{% set new = [{
if is_state('media_player.beam', 'playing') and state_attr('media_player.beam', 'media_title') != 'TV' %}
{{ (new + current)[:5] if is_state('media_player.beam', 'playing') and state_attr('media_player.beam', 'media_title') != 'TV' else current}}
Is this still working for folks? I’m just recently getting nothing in the card I am using and the template seems broken on my end:
Well seems I must have broken the template/sensor? If anyone knows how I would fix it would appreciate it.
If the last thing played didn’t have media_artist
and media_title
attributes, that’s the result (Undefined).
FWIW, you can append the default
filter like this to make it report unknown
instead of Undefined.
"artist": trigger.to_state.attributes.media_artist | default('unknown'),
"title": trigger.to_state.attributes.media_title | default('unknown'),
Alternately, you can use the default
filter to look for some other attribute and report that instead. What that “other attribute” might be depends on the content being played.
Using the Variables & History integration https://github.com/Wibias/hass-variables
- service: variable.update_sensor
entity_id: sensor.vh_songs_played
value: "{{ (states('sensor.vh_songs_played')|int(0))+1 }}"
attributes:
message_1: "{{states('sensor.readable_date_short')}} {{states('sensor.readable_time')}}: {{ state_attr('media_player.kitchen_white', 'media_artist') }}, {{ state_attr('media_player.kitchen_white', 'media_title') }}"
message_2: "{{state_attr('sensor.vh_songs_played','message_1')}}"
message_3: "{{state_attr('sensor.vh_songs_played','message_2')}}"
message_4: "{{state_attr('sensor.vh_songs_played','message_3')}}"
message_5: "{{state_attr('sensor.vh_songs_played','message_4')}}"
message_6: "{{ trigger_message }}"
Hi, realize this a pretty old thread but would like to implement. However when i install the ‘template sensor’ from the above link and i paste the code in it tells me im pasting YAML code when it wants a sensor. What am i doing wrong?? Thanks!!
Where are you pasting it?
The example (YAML) is designed to be added to the configuration.yaml
file.
Ah, thanks will do.
