Sonoff B1 (RGBWW) brightness problems
Just tried out a Sonoff B1 flashed with ESPhome, not very sucessful I must say :confused:
When changing the brightness it’s only for the RGB channels, and not for the CW/WW channels.
That means for me to be able to dim the light, I must set the brightness to 0% and then adjust the white value. Not very smart when Google adjusts the brightness alone, hence being unable to control brightness from Google.
Any ideas to solve this?
A good start might be to post the contents of your yaml file. We are not mind readers.
Sorry - forgot to write that it’s the example in the docs that’s used.
substitutions:
  devicename: bedroom_ceiling_1
  upper_devicename: Bedroom Ceiling 1
  platform: ESP8266
  board: esp01_1m
<<: !include .common.yaml
binary_sensor:
  - platform: status
my9231:
  data_pin: GPIO12  # GPIO13 for AiLight
  clock_pin: GPIO14  # GPIO15 for AiLight
  num_channels: 6
  num_chips: 2
output:
  - platform: my9231
    channel: 0
  - platform: my9231
    channel: 1
  - platform: my9231
    channel: 2
  - platform: my9231
    channel: 4
  - platform: my9231
    channel: 5
light:
  - platform: rgb
    red: output_red
    green: output_green
    blue: output_blue
For future viewers, it needs a hard reboot so make sure it has no power for a couple seconds.
I upgraded from espurna and saw the same ish problems.
