Sonoff basic DIY dimmer
This video prompted me to such a homemade product.
Since I have a task for illuminating a barbecue and, in general, now there is an option to make lighting along the contour of the gazebo, I remembered about the basic and the ability to screw a PWM module to it (sold by kilograms for a ridiculous price).
PWM module
5-15-400-MOS-FET-PWM
The characteristics of the module allow you to connect a tape with a wide range of power supply.
I connected a 12V tape.
We find a diode on the BASIC board and cut off the diode. We need one contact (see photo)
Sonoff basic
We collect everything according to the scheme (I’m not an artist, but I hope everything is clear)
Scheme
The code … here’s my favorite ESPHOME and the Home Assistant integration.
Code
esphome:
  platform: ESP8266
  board: esp8285
wifi:
  ssid: !secret ssid
  password: !secret password
  use_address: 192.168.0.129
  fast_connect: true
  manual_ip:
    static_ip: 192.168.0.129
    gateway: 192.168.0.1
    subnet: 255.255.255.0
logger:
api:
ota:
web_server:
  port: 80
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      inverted: True
    on_press:
      then:
        - switch.toggle: led_relay
  - platform: status
output:
  - platform: esp8266_pwm
    pin: GPIO13
    frequency: 800 Hz
light:
  - platform: monochromatic
    output: pwm_output
    on_turn_on:
    - switch.turn_on: led_relay
    on_turn_off:
    - switch.turn_off: led_relay
switch:
  - platform: gpio
    pin: GPIO12
    icon: "mdi:led-on"
    optimistic: true
    turn_on_action:
    - switch.turn_on: relay_led
    - light.turn_on: led_strip
    turn_off_action:
    - switch.turn_off: relay_led
    - light.turn_off: led_strip
    icon: "mdi:led-on"
    optimistic: true
    turn_on_action:
    - switch.turn_off: led_80
    - switch.turn_off: led_60
    - switch.turn_off: led_40
    - light.turn_on:
        brightness: 100%
        transition_length: 5s
    turn_off_action:
    icon: "mdi:led-on"
    optimistic: true
    turn_on_action:
    - switch.turn_off: led_100
    - light.turn_on:
        brightness: 80%
    turn_off_action:
    icon: "mdi:led-on"
    optimistic: true
    turn_on_action:
    - light.turn_on:
        brightness: 60%
    turn_off_action:
    icon: "mdi:led-on"
    optimistic: true
    turn_on_action:
    - light.turn_on:
        brightness: 40%
    turn_off_action:
  - platform: restart
  - platform: wifi_signal
    name: "LedStrip WiFi Signal"
    update_interval: 120s
text_sensor:
  - platform: wifi_info
    ssid:
    ip_address:
      name: "LedStrip IP Address"
Made buttons to quickly switch to a given percentage (100, 80, 60 and 40).
The buttons for turning on the tape and the relay turn on and off each other, so that the power supply remains without load and only the BASIC is powered.
Home assistant
Π‘Π½ΠΈΠΌΠΎΠΊ1
sorry for the mistakes, because I write and read English fluently only with a google translator :rofl: :joy: :rofl: :joy:
