Could you advise me on a new dongle after SkyConnect + Aqara troubles?
I live in Holland and I’m experienced in networking (Netgate pfSense, UniFi, Synology etc.) but I’m a Home Assistant first user since 4 weeks. Pi 4B + ZHA with Skyconnect + Aqara motion and climate sensors / Ikea bulbs / Thirdreality motion sensors. Aqara stuff gives me a daily headache (connections lost), I found this topic so I’m not alone.
Steps taken to solve the issue:
- USB cable 1.5m to place SkyConnect away from interference and USB3 and routers/wifi
- Changed zigbee channel from Auto (15) to 25 and 23
- Taken out a set of Abbess Smart Plugs
- Added reliable Ikea Tradfri Smart Plug to act as repeater
Still losing Aqara sensors. Ikea bulbs and ThirdReality sensors work very reliably and consistently.
Looks like I need to replace the SkyConnect if I want to use Aqara enddevices reliably.
Would like to stick with ZHA, but if z2m is more reliable I might switch.
Done some searches. This source clearly advises against EFR32 for z2m so the Sonoff Dongle-E is out as it is marked as experimental. Or is it still? I see SmartHomeJunkie set up the Dongle-E with z2m and seems happy.
Question #1
Would it be worth trying z2m with the SkyConnect to get the Aqara sensors to play along, or is this a hardware issue between SC and Aqara, in case of which z2m would not bring any improvement?
Question #2
I am leaning towards Sonoff Dongle-P now with the Texas Instruments CC2652P radio chip because pretty much every source says the Dongle-P is rock solid and the Dongle-E is experimental. Or is the Dongle-E becoming the preferred option, even with Aqara sensors?
Any other input very welcome.
Thank you very much!
Peter from the Netherlands
