Sonoff Dongle PMG-24 using Thread
Hi, I have the latest Home Assistant container running on a Raspberry Pi5 (Trixie, 64 bits). According to:
I need to install an OpenThread App within Home Assistant to use Thread. Is this correct or am I missing something? Would the same apply to other hardware (e.g. Casa Nabu’s Connect ZBT-2)?
Any guidance is highly appreciated. I cannot believe that using Matter/Thread is not available on a Pi5 with containerized HA.
I can't help a lot as I don't run HA Container, nor use the PMG-24, but you can't use the OpenThread "App" as the "App" is for HAOS based installations. However I do make some notes from time-to-time trying to be helpful, and here are a couple of links for a standalone Docker OTBR container that should work for your situation:
Ownbee Docker Image
Package hass-otbr-docker · GitHub
HA Docker with OTBR docker - #8 by D34DC3N73R
Possibly more here:
Wow, thanks for posting. I spent two hours trying to figure it out with a Sonoff Dongle Plus CC2674P10 and it turned out I was using the integration, not the App! I flashed the dongle with the Sonoff app (which required first downloading a driver for my Windows 11), then flashing was easing using Sonoff web based app.
