Yes, now the system (for this moment ) is not hanging at ota, and it is now busy much longer (is still busy yet). Now i have seen the update. … 100% and info about sensors.
But i also saw that the ip adres was changed?? first .15 now .10 very strange. But should not be a problem for this.
I never had flashed this NSpanel, as i said before, i could not flash my old panel on my Mac (error with serial ports??? So i bought a new NSpanel and bought it Complete with already flashed with Blueprint. And the seller never said something about the OTA. But the password was from the seller.
Yes it works and I have already connected some hue lamps. It is not yet in the wall, I still have to find out whether the 2 buttons will also continue to work mechanically, since one of the buttons (left) will simply hang a fixture that unfortunately still runs conventionally at 220 (LED) with built-in LEDs. And I now also notice that, unlike the nspanel I had last year, I can’t use a complete map (Spotify and Radio). The latter is a pity, given that we have a soundbar and it very sometimes fails on its app and then they are without a radio. But thanks.
hallo @EdwardTFN I just wanted to update to 3.4 I updated the blueprint version in the folder where it is then reloaded automation & after that I updated the tft file this & then updated esphome but it doesn’t do anything now as you can see on the photo the tft is still there on 3.3 & esphome on 3.4 & blueprint also on 3.4 & I have the esphome.yaml running like this so I don’t understand why it doesn’t do anything now I get this screen ?
You have to update your TFT file.
Your settings will instruct your panel to download the latest file directly from GitHub. This is a bit easier, so you just have to go to your device page (Settings > Devices & Services > ESPHome) and press the button “Upload TFT” and your panel will try to download if from GitHub.
This kind of transfer, however, is quite fragile, so if the steps above aren’t working, I would suggest to do this using that file in a local http server (your HA could be a candidate).
There are more instructions around this here and here.
About units, you can choose the ones you like more in Home Assistant, regardless the panel model you select, and this Blueprint will just use the values as provided by HA.
Hi all.
I faced such problem as screen offset. This offset is only for the European version, not for the American one.
As I understand it, at the factory, the part of the screen was initially closed due to which, the calibration of the display is also lame, you need to press to the left of the button.
The offset is about 50px.
Tried using the following command “touch_j”. Did not help.
Perhaps in sonoff there is a stripped-down version.
Please help me with this.
Hi all.
I discovered this Blueprint solution few days ago and thanks for noob people like me
I sarted integration with 3.4 release and I have a question about it.
Is there a change about features or just is it possible I have issue while integration because setting Icon (lower left on the display) it is not present ?
There is option to display it on blueprint or just an issue ?
If it’s issue I will create a case to avoid to discuss about it here.
