As the fallback AP is working, you have a hope.
Why don’t you ask for help in GitHub… The community is way more active over there.
This is the link: Issues · Blackymas/NSPanel_HA_Blueprint · GitHub
After updating ESPHome last night, my panel lost all the configurations. I can see that the configs are still in the blueprint, but not on the panel . The two buttons are still responsive with the automations assigned to them. What’s the next steps? Sorry newb here and kinda scratching my head lol TIA
I had the same symptoms. ESPHome has been updated but not the TFT version.
Follow the steps here: https://github.com/Blackymas/NSPanel_HA_Blueprint/blob/29087e2ca05c29b0b8f120d05e8b860747bd74e2/docs/howto.md#update-blueprint
Update the Blueprint
Update ESPHome
Update TFT file
The order doesn’t matter.
Looks like an old bug returned in the latest version….
The color of the media icons (Spotify etc) is not updated real-time on the homescreen. Only if you refresh the homescreen, the icon color (status) is updated.
Since the update , nothing but issues . I apologize if I’m coming off rude not my intention. Icons not changing to reflect state of the device. Buttons not responding either . I can turn on the light let’s say, won’t change the icon but then I can’t turn it off. A bit frustrating. Rebooted twice and no luck, same issue. The stairs light is stuck on with 5% showing while device is off
Sad to hear you’re having all these issues. If you want, I can try to help you reverting to the previous version.
But trying to fix the issues in this one, do you have any error log in Home Assistant logs (Settings > System > Logs)?
Hello, I also have a problem with the display. Since the latest update, the temperature display has shifted slightly to the right. See red square picture. Is the error known?
Having some issues getting my panel working. I am basically getting the same outcome as [Drknght4] is reporting above.
First off, I got the panel flashed and it boots successfully - but I cannot get any automations to load to it. Something is working because on boot it always shows the correct time and it sometimes shows the panel temp sensor - but thats it. When it boots up it just shows the ESPHome version of 4.2.4 and the TFH panel of 4.2.4, but it never shows the Blueprint version. The Blueprint version I am using is 4.2.4 so there should be no conflict there.
All featurs work as expected on the ESPHome devices screen and it responds to load TFH, Reboot, Right click and Left click and shows the correct temperature.
I am running this on a Odroid N2 with 2Gb of memory - but unfortunately it will not compile on the N2 using ESPHome addon due to the error:
xtensa-esp32-elf-g++: fatal error: Killed signal terminated program as compilation terminated.
which I understand is an out of memory error at root. I compiled the .bin file successfully on my Ubuntu laptop using ESPHome and my laptop flashed it onto the NSPanel using a serial-USB adapter. I do not know if compiling on the laptop has introduced issues as there is very little documentation as to how to do this (even though the out of memory error is common enough on anything with less than 4gb of onboard memory).
I am going round in circles here, no automation strategy works - neither the Blueprint or the onboard devices automation in HomeAssistant. Its been a steep learning curve to get to this stage and I am out of ideas as to how to proceed. I am seeing no useful logs within HA logs, but have a suspicion that I am hitting the baud rate issue (but dont know how to get around it if I am).
Any ideas would be greatly appreciated. I hate to abandon a project but this one is pushing me to my technical limits as nothing has gone as described in the guides. HA is a hugely frustrating project as it changes so quickly that it seems to render any guidance out of date almost as soon as it is given.
Stephen
Update:
Turned out that I had introduced an error into my Configuration.yaml file which was preventing loading of all automations. Solve that problem and the automations loaded along with the blueprint.
Hi, I use nspanel blueprint but I never could configure the alarm panel, simple because this option dot not show in blueprint options. I have all my panels configured for service calls. I use ALARMO and I have some nspanels running nspanel lovelace and it works, but I never saw in blueprint. What could be?
We have changed that and the documentation got obsolete. It’s already fixed in dev and will be updated on main soon.
You can assign your alarm control panel entity to any of the buttons, and clicking there should open the alarm page.
Thank you. Worked perfect
I just updated to latest everything and curious what the grey icon in topper left screen horizontal bar is/comes from!? Can’t identify this icon/setting in my automation config!?
Anyone an idea?
alias: NSPanel Configuration
description: ""
use_blueprint:
path: Blackymas/nspanel_blueprint.yaml
input:
nspanel_name: blablabla
language: de
weather_entity: weather.forecast_myhome
indoortemp: sensor.shelly_motion_wohnzimmer_temperature
home_indoor_temp_icon_color:
- 255
- 255
- 255
home_indoor_temp_label_color:
- 255
- 255
- 255
home_value01_icon: mdi:diabetes
chip01: binary_sensor.garagentor_external_input
chip01_icon: mdi:garage-open
chip02: binary_sensor.aussenturen
chip02_icon: mdi:door-open
chip03_icon: ""
chip04: sensor.abfallbiotonne
chip04_icon: mdi:flower-outline
chip05: sensor.abfallrestmuell
chip05_icon: mdi:trash-can
chip06: sensor.abfallpapier
chip06_icon: mdi:trash-can-outline
climate: climate.lg_artcool_mirror_ac24
climate_button08: switch.lg_artcool_mirror_ac24_jet_mode
climate_button08_icon: mdi:air-conditioner
climate_button09_icon: mdi:ceiling-fan
climate_value01: sensor.lg_artcool_mirror_ac24_energy_current
climate_value01_icon: mdi:lightning-bolt
left_button_entity: light.dimmer_kuche
right_button_entity: light.dimmer_wohnzimmer
right_button_name: Licht WZ
entity01: light.dimmer_kuche
entity01_name: Küche
entity01_icon: mdi:lightbulb
entity02: light.dimmer_wohnzimmer
entity02_name: WZ
entity02_icon: mdi:lightbulb
entity03: light.dimmer_terrasse
entity03_name: Terrasse
entity03_icon: mdi:lightbulb
entity04: light.dimmer_galerie_1
entity04_name: Galerie
entity04_icon: mdi:lightbulb
entity05: switch.garagentor
entity05_name: Garagentor öffnen
entity05_icon: mdi:garage
entity06: switch.shelly_uni_hausture_channel_1
entity06_name: Haustüre öffnen
entity06_icon: mdi:door-open
chip07: binary_sensor.tursensor_hausture_door
chip07_icon: mdi:door-open
left_button_name: Licht Küche
entity07: fan.ventilatoren_wz
entity07_name: Ventilatoren
entity07_icon: mdi:ceiling-fan
entity08: climate.lg_artcool_mirror_ac24
entity08_name: Klimaanlage
entity08_icon: mdi:air-conditioner
button_page01_label: Beleuchtung und Türen
entity_page01_label: Strom und Gas
entities_entity01: sensor.stp10_0_3av_40_837_grid_power
entities_entity01_name: "PV aktuell:"
entities_entity01_icon: mdi:solar-panel-large
entities_entity02: sensor.strom_zuruck_ins_netz
entities_entity02_name: "Einspeisung aktuell:"
entities_entity02_icon: mdi:transmission-tower-import
entities_entity03: sensor.strom_gwh_bezug
entities_entity03_name: "Stromzählerstand:"
entities_entity03_icon: mdi:counter
entities_entity04: sensor.energy_production_today_remaining
entities_entity04_icon: mdi:solar-power-variant
entitypages_enabled: true
entities_entity04_name: "PV Vorhersage:"
entities_entity05: sensor.strom_pv_einspeisung
entities_entity05_name: "Zähler PV Einspeisung:"
entities_entity05_icon: mdi:counter
climate_button09_hold_custom_action: []
qrcode_label: "Gast Wifi: @MySSID"
home_button05_icon_color:
- 255
- 255
- 255
qrcode_value: Wifi:@MYSSID pwd
climate_value02: >-
sensor.shelly_luftfeuchtigkeits_und_temperatur_sensor_wohnzimmer_temperature
climate_value02_icon: mdi:thermometer
date_format: "%a, %d.%m.%Y"
qrcode_enabled: true
home_value02_icon: mdi:diabetes
home_value03_icon: mdi:solar-power-variant-outline
home_value01_icon_color:
- 250
- 250
- 0
home_value02_icon_color:
- 250
- 250
- 0
home_value03_icon_color:
- 250
- 250
- 0
chip01_icon_color:
- 255
- 255
- 255
chip02_icon_color:
- 255
- 255
- 255
chip03_icon_color:
- 255
- 255
- 255
chip04_icon_color:
- 255
- 255
- 255
chip05_icon_color:
- 255
- 255
- 255
chip06_icon_color:
- 255
- 255
- 255
chip07_icon_color:
- 255
- 255
- 255
home_button06_icon_color:
- 255
- 255
- 255
entitypages_value_alignment: "0"
home_value03: sensor.stp10_0_3av_40_837_grid_power
home_value03_label_color:
- 200
- 204
- 200
left_button_color:
- 255
- 255
- 255
right_button_color:
- 255
- 255
- 255
outdoortemp: sensor.temperatursensor_terrasse
climate_value03: sensor.temperatursensor_terrasse
climate_value03_icon: mdi:thermometer
home_indoor_temp_icon: mdi:sofa-single
chip_font_size: "8"
home_custom_button01: fan.ventilatoren_wz
home_custom_button01_icon: mdi:ceiling-fan
climate_button09: fan.ventilatoren_wz
entity09_icon: ""
entities_entity06: fan.ventilatoren_wz
entities_entity06_name: Ventilatoren
entities_entity06_icon: mdi:ceiling-fan
home_button06_icon: mdi:view-list
entity05_confirm: true
entity06_confirm: true
home_value01: sensor.blood_sugar_nightscout
home_value02: sensor.dexcom_blabla_glucose_trend
Hello, I have another question. Does the nspanel not have a humidity sensor? According to the description, one should be installed, right?
As far as I know, there’s no embedded humidity sensor.
If you take a look at this NSPanel teardown, they mention a slot for one, but nothing installed there.
I will take a look at mine on the next time I open it just in case, but I don’t think I will find a humidity sensor.
Hello, could someone help with configuring HA to use the media player card after pressing a button on NSPanel? I want to create several buttons, each with a different internet radio, and I can’t manage to do it.
Is it possible to disable 3 of the 4 button screens? I only use one.
This is not possible right now, but it is in our plans:
It would be really handy if in the Blueprint we could have a short description to show which page each one is relative to the swipe actions. ie: is Page 1 up, down, left or right? It would make the setup a lot easier.
I can put this in a Github request if you want (if it’s not already on the roadmap).
