I think I’ll just flash from scratch.
I just completely redid the firmware flash via wireless, behavior still the same.
Getting the messages
[16:38:15.123][D][script:090]: Script 'timer_page' restarting (mode: restart)
[16:38:15.124][D][script:090]: Script 'timer_dim' restarting (mode: restart)
[16:38:15.127][D][script:090]: Script 'timer_sleep' restarting (mode: restart)
[16:38:15.355][D][script:090]: Script 'timer_page' restarting (mode: restart)
[16:38:15.359][D][script:090]: Script 'timer_dim' restarting (mode: restart)
[16:38:15.360][D][script:090]: Script 'timer_sleep' restarting (mode: restart)
every time I swipe.
I created an issue over at github.
I’ve been using your blueprint since you first published it and it’s been working great. a couple of weeks ago, I applied some updates and now the NSPanel Pro doesn’t get passed the initializing splash screen. I haven’t changed any of the config from when it was working. Do you have any suggestions for how I can troubleshoot this? Thanks again for all your hard work on this!!
I just finally managed to get this blueprint working, but I have a bit of a general question: is there any way to completely disable the home page (I don’t really need info about the weather) and just show a climate entity? My main use-case would be to just use the panel as an interface for my heating.
Edit: I basically want this from the initial post of this thread:
There is an option in the config page to set the first screen. It defaults to home but you can change that to which ever page you need to display first.
I tried setting the wake-up-page to “climate”, but this doesn’t show the thermostat displayed above. I have set the “main climate entity”, it shows the correct entity, but it only displays it with a temperature slider. Also, is there a possiblity to change the background and turn off the lock screen (which again reverts back to the weather + time home screen)
I’m having a massive headache trying to update my NS Panels to ESPhome version higher than back when there were issues (2025.7?) where I’ve had to serial flash multiple times. I finally got the first one fully updated (ESPhome and TFT) but the second one is not playing nice.
When the NS Panel boots, the log shows it connect to wifi and the HA API, but then the log clears and it shows as having no IP address or connection to HA. In the HA settings page for ESPhome, the device sometimes becomes available but then generally disconnects pretty quickly.
With the first NS Panel I managed to do a TFT update whilst it was briefly connected to HA and that seemed to fix things, but he second panel won’t start the TFT update at all.
Any ideas?
hi been having the same issue , not a real solution but i deleted the automation and redone it , also upduting the blueprint before hand , all good now
You must update your blueprint.
The climate page looks different now, but still you can select that as your wake up page, and disable (set to 0) the delay page, so it will start on cli,até page and will never fallback to home page unless you close the climate page.
