Sonoff RF Bridge with ESPHOME?
I moved off my hardware hacked Sonoff RF Bridge and onto these connected to an ESP32 after I hit up against limits in number of codes I could watch/send.
Very happy with it so far. I also hooked up and LED and an RTTL buzzer to it. I have it beep when I hit buttons on my 433mhz remotes so that I know it’s “been sent and heard”…
I tried a few ESp32’s I had and it became really solid when I used a Quinled.
I left it kind of exposed deliberately - it’s my “RF bug”…
substitutions:
  devicename: rf-transmitter-reciever-quinled
  friendly_name: rf Transmitter Reciever QuinLed
  device_description: DIY 433MHZ Transmitter Reciever
esphome:
  comment: ${device_description}
esp32:
  board: mhetesp32devkit
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
  manual_ip:
      static_ip: xxx
      gateway: yyy
      subnet: zzz
api:
ota:
deep_sleep:
  run_duration: 24h
  sleep_duration: 1s
logger:
  # hardware_uart: UART1
  # level: VERY_VERBOSE
  # baud_rate: 0
text_sensor:
# Reports the ESPHome Version with compile date
  - platform: version
    name: ${friendly_name} ESPHome Version
    #Tracks last movement direction to help with the one-touch sit/stand toggle button.
  - platform: uptime
    name: ${friendly_name} Uptime Sensor
    update_interval: 60s
    accuracy_decimals: 1
    unit_of_measurement: hrs
    filters:
      - lambda: return x/60/60;
#Buzzer
rtttl:
  output: rtttl_out
  on_finished_playback:
    - logger.log: 'Song ended!'
output:
#Rttl buzzer
  - platform: ledc
    pin: GPIO27 #Yellow wire
    # frequency: 50
#LED
  #Green
  - platform: ledc
    pin: GPIO26 #Green wire
    # frequency: 50
light:
  - platform: monochromatic
    output: green_led
    internal: false
button:
    name: rf Single Beep
    on_press:
      then:
        - rtttl.play:
            rtttl: 'beep:d=4,o=7,b=100:32a'
    on_press:
      then:
        - rtttl.play:
            rtttl: 'beep:d=4,o=4,b=100:32a'
    name: rf Double Beep
    on_press:
      then:
        - rtttl.play:
        - delay: 200ms
        - rtttl.play:
    name: rf Single LED Flash
    on_press:
      then:
        - light.turn_on:
              brightness: 50%
        - delay: 500ms
        - light.turn_off: rf_green_led
    name: rf Double LED Flash
    on_press:
      then:
        - light.turn_on:
              brightness: 50%
        - delay: 500ms
        - delay: 500ms
        - light.turn_on:
              brightness: 50%
        - delay: 500ms
remote_receiver:
  pin:
    number: GPIO25 #Blue wire
    inverted: true
  dump:
    - rc_switch
  tolerance: 60%
  filter: 4us
  idle: 4ms
    # - raw
  # filter: 50us
  # tolerance: 50%
  # idle: 2ms
  # filter: 100us
  # tolerance: 50%
  # idle: 2ms
remote_transmitter:
  pin:
    number: GPIO33 #Green wire
    # inverted: True
  carrier_duty_percent: 100%
switch:
#Control Shed Door
    name: Release Shed Door
    turn_on_action:
      - remote_transmitter.transmit_rc_switch_raw:
          code: '010000000101000101010001'
          protocol:
            pulse_length: 320
          repeat:
            times: 10
            wait_time: 0s
    name: Reset Shed Door
    turn_on_action:
          code: '010000000101000101010100'
          protocol:
            pulse_length: 320
          repeat:
            times: 10
            wait_time: 0s
    name: Stop Release Shed Door dev
    turn_on_action:
          code: '010000000101000101010101'
          protocol:
            pulse_length: 320
          repeat:
            times: 10
            wait_time: 0s
binary_sensor:
# #remote 1) top left meute
  # - platform: remote_receiver
    # id: remote1topleft_togglednd
    # name: "Toggle DND"
    # rc_switch_raw:
      # code: '111111110101111101110001'
      # protocol: 6
    # filters:
      # - delayed_off: 1s
# #remote 1) top right togglemusic
    # id: remote1topright_togglemusic
    # name: "Toggle Music"
    # rc_switch_raw:
      # code: '101000110100101111000001'
      # protocol: 6
    # filters:
      # - delayed_off: 1s
# #remote 1) bottom left toggle blinds
    # id: remote1bottomleft_toggleblinds
    # name: "Toggle Blinds"
    # rc_switch_raw:
      # code: '111111110101111101110010'
      # protocol: 6
    # filters:
      # - delayed_off: 1s
# #remote 1) bottom right toggle blinds
    # id: remote1bottomright_toggleblinds
    # name: "Toggle Light"
    # rc_switch_raw:
      # code: '111111110101111101111000'
      # protocol: 6
    # filters:
      # - delayed_off: 1s
#bedroom thermostat remote
    name: "Bedroom Remote Warmer"
    rc_switch_raw:
      code: '000000011011000001010010'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
        - button.press: rf_single_high_beep
    name: "Bedroom Remote Toggle Climate"
    rc_switch_raw:
      code: '000000011011000001010100'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    name: "Bedroom Remote Cooler"
    rc_switch_raw:
      code: '000000011011000001011000'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#10 button remotes
#Start Desk Remote
#remote R1C1 - Temp Increase
    rc_switch_raw:
      code: '010011001011010101100100'
      protocol: 6
    filters:
      - delayed_off: 200ms
    on_press:
      then:
#remote R1C2 - AC Toggle
    rc_switch_raw:
      code: '010011001011010101100010'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#remote R1C3 - Temp Decrease
    rc_switch_raw:
      code: '010011001011010101100110'
      protocol: 6
    filters:
    on_press:
      then:
#remote R1C4 - Toggle DND
    rc_switch_raw:
      code: '010011001011010101100001'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#remote R1C5 - Toggle Vac
    rc_switch_raw:
      code: '010011001011010101100101'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#remote R2C1 - Toggle Vac
    rc_switch_raw:
      code: '010011001011010101101000'
      protocol: 6
    filters:
    on_press:
      then:
#remote R2C2 - Toggle Music
    rc_switch_raw:
      code: '010011001011010101101100'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#remote R2C3 - Music Vol Down
    rc_switch_raw:
      code: '010011001011010101101010'
      protocol: 6
    filters:
    on_press:
      then:
#remote R2C4 - Toggle Blinds
    rc_switch_raw:
      code: '010011001011010101101110'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#remote R2C4 - Toggle Lights
    rc_switch_raw:
      code: '010011001011010101101001'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#End Desk Remote
# #Start Dining Remote
    rc_switch_raw:
      code: '101101000111010100100100'
      protocol: 6
    filters:
    on_press:
      then:
    rc_switch_raw:
      code: '101101000111010100100010'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '101101000111010100100110'
      protocol: 6
    filters:
    on_press:
      then:
    rc_switch_raw:
      code: '101101000111010100100001'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '101101000111010100100101'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '101101000111010100101000'
      protocol: 6
    filters:
    on_press:
      then:
    rc_switch_raw:
      code: '101101000111010100101100'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '101101000111010100101010'
      protocol: 6
    filters:
    on_press:
      then:
    rc_switch_raw:
      code: '101101000111010100101110'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '101101000111010100101001'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#End Dining Remote
#Start kitchen Remote
    rc_switch_raw:
      code: '001110110110110010100100'
      protocol: 6
    filters:
    on_press:
      then:
    rc_switch_raw:
      code: '001110110110110010100010'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '001110110110110010100110'
      protocol: 6
    filters:
    on_press:
      then:
    rc_switch_raw:
      code: '001110110110110010100001'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '001110110110110010100101'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '001110110110110010101000'
      protocol: 6
    filters:
    on_press:
      then:
    rc_switch_raw:
      code: '001110110110110010101100'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '001110110110110010101010'
      protocol: 6
    filters:
    on_press:
      then:
    rc_switch_raw:
      code: '001110110110110010101110'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '001110110110110010101001'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#End kitchen Remote
#Start couch Remote
    rc_switch_raw:
      code: '001100001000010000100100'
      protocol: 6
    filters:
    on_press:
      then:
    rc_switch_raw:
      code: '001100001000010000100010'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '001100001000010000100110'
      protocol: 6
    filters:
    on_press:
      then:
    rc_switch_raw:
      code: '001100001000010000100001'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '001100001000010000100101'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '001100001000010000101000'
      protocol: 6
    filters:
    on_press:
      then:
    rc_switch_raw:
      code: '001100001000010000101100'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '001100001000010000101010'
      protocol: 6
    filters:
    on_press:
      then:
    rc_switch_raw:
      code: '001100001000010000101110'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    rc_switch_raw:
      code: '001100001000010000101001'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#End couch Remote
#H Remote
    name: "H Door Open"
    rc_switch_raw:
      code: '000000000010110000100010'
      protocol: 6
    filters:
      - delayed_off: 5s
    on_press:
      then:
    name: "H Door Close"
    rc_switch_raw:
      code: '000000000010110000101000'
      protocol: 6
    filters:
      - delayed_off: 5s
    on_press:
      then:
    name: "H likes it hot"
    rc_switch_raw:
      code: '000000000010110000100100'
      protocol: 6
    filters:
      - delayed_off: 5s
    on_press:
      then:
    rc_switch_raw:
      code: '010001001010100101100001'
      protocol: 6
    filters:
      - delayed_off: 5s
    on_press:
      then:
    # id: flossboss
    # name: "Floss Boss"
    # rc_switch_raw:
      # code: '101010000001110010101000'
      # protocol: 6
    # filters:
      # - delayed_off: 5s
    # id: brushboss
    # name: "Brush Boss"
    # rc_switch_raw:
      # code: '101010000001110010100010'
      # protocol: 6
    # filters:
      # - delayed_off: 5s
    name: "Close Shed Door Button"
    rc_switch_raw:
      code: '111111001010110100101000'
      protocol: 6
    filters:
      - delayed_off: 2s
    on_press:
      then:
    # id: resetsheddoor
    # name: "Reset Shed Door Button"
    # rc_switch_raw:
      # code: '111111001010110100100010'
      # protocol: 6
    # filters:
      # - delayed_off: 2s
    device_class: motion
    name: "Couch PIR 1"
    rc_switch_raw:
      code: '110101000010001001100110'
      protocol: 6
    filters:
      # - delayed_on: 500ms
      - delayed_off: 10s
      # - delayed_on_off: 500ms
    # id: dunnypir
    # device_class: motion
    # name: "Dunny PIR"
    # rc_switch_raw:
      # code: '100011000101011001100110'
      # protocol: 6
    # filters:
      # - delayed_off: 5s
    # id: pir3
    # name: "PIR3"
    # rc_switch_raw:
      # code: '110010001110010001100110'
      # protocol: 6
    # filters:
      # - delayed_off: 600s
# #Sonoff Remote - Balcony
#Row 1
    name: "Sonoff Remote Toggle Disco Light"
    # id: sonoffrmc1r3_togglefrontdoorlock
    # name: "Sonoff Remote Toggle Front Door Lock"
    rc_switch_raw:
      code: '001001110111001001101000'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    name: "Sonoff Remote Toggle Blinds"
    rc_switch_raw:
      code: '001001110111001001101100'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#Row 2
    name: "Sonoff Remote Toggle Light"
    rc_switch_raw:
      code: '001001110111001001100100'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    name: "Sonoff Remote Toggle Vacuum"
    rc_switch_raw:
      code: '001001110111001001101001'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#Row 3
    name: "Sonoff Remote Toggle Thermostat"
    rc_switch_raw:
      code: '001001110111001001100010'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
    name: "Sonoff Remote Toggle Music"
    rc_switch_raw:
      code: '001001110111001001100101'
      protocol: 6
    filters:
      - delayed_off: 1s
    on_press:
      then:
#Row 4
    name: "Sonoff Remote Music Vol Down"
    rc_switch_raw:
      code: '001001110111001001100001'
      protocol: 6
    filters:
      - delayed_off: 300ms
    on_press:
      then:
    name: "Sonoff Remote Music Vol Up"
    rc_switch_raw:
      code: '001001110111001001100011'
      protocol: 6
    filters:
    on_press:
      then:
    # id: sonoffrmc1r1_lighttoggle
    # name: "Sonoff Remote Toggle Light"
    # rc_switch_raw:
      # code: '001001110111001001101000'
      # protocol: 6
    # filters:
      # - delayed_off: 1s
    # id: sonoffrmc2r1_togglemusic
    # name: "Sonoff Remote Toggle Music"
    # rc_switch_raw:
      # code: '001001110111001001101100'
      # protocol: 6
    # filters:
      # - delayed_off: 1s
    # id: sonoffrmc1r2_toggleblinds
    # name: "Sonoff Remote Toggle Blinds"
    # rc_switch_raw:
      # code: '001001110111001001100100'
      # protocol: 6
    # filters:
      # - delayed_off: 1s
    # id: sonoffrmc2r2_togglevacuum
    # name: "Sonoff Remote Toggle Vacuum"
    # rc_switch_raw:
      # code: '001001110111001001101001'
      # protocol: 6
    # filters:
      # - delayed_off: 1s
    # rc_switch_raw:
      # code: '001001110111001001100010'
      # protocol: 6
    # filters:
      # - delayed_off: 1s
    # id: sonoffrmc2r3_togglethermostat
    # name: "Sonoff Remote Toggle Thermostat"
    # rc_switch_raw:
      # code: '001001110111001001100101'
      # protocol: 6
    # filters:
      # - delayed_off: 1s
    # id: sonoffrmc1r4_musicvoldown
    # name: "Sonoff Remote Music Vol Down"
    # rc_switch_raw:
      # code: '001001110111001001100001'
      # protocol: 6
    # id: sonoffrmc2r4_musicvolup
    # name: "Sonoff Remote Music Vol Up"
    # rc_switch_raw:
      # code: '001001110111001001100011'
      # protocol: 6
