Sonoff snzb-01p blueprint
Does anyone have the blueprint for this button please?
You just have to slightly modify an existing blueprint to get it working. See ZHA Sonoff Button (press, double press, hold actions) - #35 by ParksideParade
Thank you, I finally got it to run w/o the smart things app like I normally do, another it took some extra steps in the automation process
hi.
I’m having trouble with these buttons, with the current HA- & Z2M-versions.
(for xx reason, their entities aren’t showing up within automations (as possible triggers)).
Do you by-chance have a blueprint for these buttons?
Action entities were removed from Z2M when v2.0 was released towards the end of last year.
If you want to automate based on the events these devices generate, you will need to read this. Only option 3 (enabling the deprecated legacy action sensor) will allow you to use old blueprints if you can’t find any newer ones.
I probably should have looked in the forums before buying these SNZB-01P. I got them today and have fought with them for about an hour. No triggers are configurable and I’ve followed a million forums suggestions. They will be returned tomorrow.
Well, no sooner than I posted this, I got them to work. I used the blueprint from 2023. https://community.home-assistant.io/t/this-is-share-with-button-snzb-01p-automation-config/661287
