I have 4 Sonoff ZBMini-L with ZHA using a Sonoff Dongle Plus 3.0 as coordinator and 3 router devices and my ZBMini-L are randomly turning off.
They are no randomly turning on just off and it doesn’t seem to be a signal problem since I manage to get LQI about 90 on each device and as soon one of the lights turn magically off I can turn it on HA, also HA signal that it was “Turned off” no “Turned off by some logic on HA”.
And at iTead product page are people reporting the same:
Yes. They finally found that there is problem with their firmware and are working to release an update. Question is how are going to apply that firware with HA
We have raised the pull request for the OTA update image on github Pull requests · Koenkk/zigbee-OTA · GitHub.
Once it is approved, you can download the image and update the ZBMINI-L devices.
Feature: Added Poll Control Cluster private attribute 0xFF00 (enable/disable configuration), the default Poll Control Cluster initial configuration is disabled
Bugfix: Random shutdown issue
Have a similar problem with my ZBMINI-L: it seems to work fine with switch and Zigbee2MQTT, BUT it has an endless cycle of automatically turning the lights on and off in some 5-10 second cycle.
I ran a test on a separate system and the zbmini-l seems to work correctly.
In my case I think there are problems in the electrical system of the house. There is an inconsistent low voltage between “S2” and “L in” causing the zbmini-l to turn on and off. Bad news for me.
[UPDATE Feb 15 - I’m not allowed to put more than 3 replies in this topic… ]
Just bought some ZBMINI-L2 (wow, they are extremely small!!!) and in the same installation that was causing me problems, they work.
I did a quick test, need time for more thorough testing.
I have 8 zbmini-l devices and they all work well except for 3 of them.
Here is my experience:
I connect it all up correctly. My zbmini-l devices is inside my ceiling though, not behind my switches, and I run cables to the S1 and S2 from the switch.
If I turn on the lights at the switch, it all works immediately, no delays. The lights stay on.
When I turn off the switch, the device seems to automatically turn the lights on and off in a random fashion. Usually around the 2-minute mark.
It does not happen with all of them, just the 3, and im unsure why.
