Has anyone been able to integrate it with ZHA (Home-Assistant Zigbee) ? or it only works with zigbee2mqtt ?
I am wondering if it’s the location of the swith or my integration, cause doesn’t seem to find it. It’s in my outdoor shed, not too far but farther than the others, the zigbee door sensor works fine. Doesn’t work to get it all out for what is really worth.
Based on what you said, it’s more likely a location thing. Options to figure out are 1) move the zbmini-l to somewhere next to the coordinator, so that to rule out integration issue or bad unit; 2) get another main powered zigbee device (most zigbee smart plugs - I have seen someone recommend IKEA repeaters also) as a relay between your coordinator and your outdoor shed, if possible
My educated guess answer based on experince; Sounds like due to how the ZBMINI-L is designed as no-neutral hardware switches to work it needs to leak/passthrough some electrical current just to operate but that will not work if the bulb does not also leak/passthrough enough electrical current (to keep the light on for the ZBMINI-L itself so to speak). My guess is that you will not be able to use any “no-neutral” hardware switches in-line with any smart lightbulbs that way. If that is the case then your only option is to feed power to the ZBMINI-L separately so they are not connected in series after each other as that will break electrical power for one of them.
FYI, you are not supposed to purposely cut power (ON and OFF too often) to any mains-powered Zigbee devices for example smart lightbulbs when they are a part of a Zigbee network because they are normally used as Zigbee Router devices (also known as Zigbee repeaters and Zigbee range extenders)? If you keep cutting power to Zigbee Router devices then it will screw up your Zigbee network mesh as it normally only updates the routes between routers once about every 24 hours in a normal environment.
ZHA will not know the status is you have cut the power because the device have not used Zigbee to report that it has been powered off (as it really has not), though the “last seen” should not be updated no more.
Really, if you plugin mains-powered Zigbee devices for example smart lightbulbs to a power circuit with a manual switch like a ceiling lamp-socket with a wall-switch then you are supposed to first disable that manual switch, bypassing that wall-switch wall-switch and usually replace it with a battery-powered Zigbee switch/remote with a wall-mount instead or install a "smart switch module like the Philips Hue Wall switch module without built-in relay behind the wall-switch in order to convert that wall-switch into a smart remote switch, or replace the whole wall switch with a smart wall switch (still bypassing power for the smart lightbulb).
The alternative is to only install a smart wall switch or switch module with built-in relay like the ZBMINI-L and do not use a smart lightbulb but instead use only dumb lightbulbs that are dimmer compatible.
I’m experiencing same problem. When I turn the ligth off, sometimes it turns on once and then turns off, other times it keeps turning on and off. No automation in place yet as well.
I have 8 zbmini-l devices and they all work well except for 3 of them.
Here is my experience:
I connect it all up correctly. My zbmini-l devices is inside my ceiling though, not behind my switches, and I run cables to the S1 and S2 from the switch.
If I turn on the lights at the switch, it all works immediately, no delays. The lights stay on.
When I turn off the switch, the device seems to automatically turn the lights on and off in a random fashion. Usually around the 2-minute mark.
It does not happen with all of them, just the 3, and im unsure why.
just an FYI I was having issues with the unit needing to be repaired, sometimes it would last a week before needed it with the built in zigbee. I upgraded to Zigbee2MQTT and I have not had an issue. The whole zigbee network seems to run a lot better and I get better visibility.
My zbmini-l worked fine for couple of months usong ZHA, and then one night i try to turn it on using HA, but i was unable to do so. After investigation i have found that device drop from my zigbee network, so i deleted it and re add it to my network. But from that day switch works in strange way after turn on, (no difference using HA or light swith) lights randomly turn off after 30min to about 1:30min after turning on, firmware on device was 1.0.5 and last night i update firmware to 1.1.1 and for now, i dont have random turn off and its works like before.
