I was just doing some maintenance on my spa (hot tub) and got to thinking…
Does anyone do any remote monitoring in HA? I’m thinking water temperature, maybe PH. I’d prefer something using WiFi or ZHA, since I already use those. I suppose Z-Wave would also work.
At this point I don’t really need to control it. Knowing the PH would be huge, so I don’t have to go check daily. Knowing the temperature would show me it’s working.
No, the best I’ve done is a Zigbee temperature/humidity sensor in the mechanical area of the spa. Works great. The brand name is CentraLite, which I got on Amazon.
I also bought some waterproof temperature probes and ESPl8266 boards which I’m hoping to use to create a DIY solution, but I haven’t really started that project yet.
Things like PH monitoring seem out of reach right now, given the time and effort required.
That’s a pretty nice looking package. A bit of sticker shock on the price, but it looks really well made.
Are you saying it works out of the box with the native HA ESPHome integration? Do you need to use the vendor’s cloud, or is there a local control configuration?
I am using the Yolink temperature with probe. I use a number of yolink devices with HA - and the integration is built by Yolink - so it’s solid + they even list monitoring hot tub temperature as a use for this device. I use some white waterproof gorilla tape (my spa is white) to hold the wire in place. and hold the sensor about 15-20 cms below the water surface (Near the filter so I know there is water flow in the area). Works like a charm.
Has anyone found a way to monitor Chlorine levels through HA? I’d really like to be able to have HA check the Cl level without needing to do a water test - and then have HA alert me if it is low. I don’t even care about the other chemicals as the spa doesn’t go critical if they are low/high for a few days - but a few days without Chlorine and you are looking at a cleaning problem for a few days until things get back to normal.
I’ve looked at a number of electronic measurement tools - but they seem to be designed for spot measurements - not continuous monitoring. AliExpress might have some tools here - but my Italian sucks so I really can’t read the detailed specs (and google translate isn’t that good)
From my reading it seems that most pool monitoring uses an ORP sensor and calculates Chlorine from the ORP reading.
The Atlas Scientific stuff (see my previous post) can do continuous monitoring, works with ESPHome, but is expensive. Whether lesser probes can do the job, I don’t know. The Atlas stuff is also available as individual probes if you just want ORP.
By the way, if you don’t want Aliexpress in Italian, set it to your own language.
I got one of these. Which works reasonably well. Except it leaks or gets condensation in it. Not sure which yet, I just stuck a heap of silicon into the bottom for leak prevention…
Seems fairly accurate. The range via esphome is abit short, although that’s partly because the condensation is getting on the circuit/antenna…
If you happen to have a IQ2020 spa control system from Watkins, Hot Spring, Tiger River, Limeligh. There is a new ESP-Home integration that you can use to remotely monitor and set temperature, start/stop jets and lights and much more. The project is on GitHub here: https://github.com/Ylianst/ESP-IQ2020. It’s pretty easy to setup.
One extra thing that was added is that you can unable the music menu on the spa remote control and button presses are sent to Home Assistant to activate automation. Useful for controlling house lights from the hot tub.
This is rs485 communication and is what I am looking for. Currently I have an ACC Smart Digital 2000 controller that came with my tub. It has 4 pumps, circ, blower, ozonator, and light control (RGB). I was wondering if the IQ2020 can just be adapted to take over for the PCboard of the smart digital and use the heater, pump, etc and just plug and play wire it to the IQ2020. I also read that when purchased they come blank and need a serial number to load software. How do you get around this?
Ideally what I am looking for is either a LAN (wired ethernet) interface to communicate via HA or rs485 as I cannot rely on WiFi. I am trying to make almost everything wired because of the unreliability of wireless signals on our property (tons of granite rock, concrete, etc).
