Hi David, while my speedtest integration had a little hiccup (meanwhile solved by reinstalling twice), I was looking for a solution. I came across your message and found the screenshot with the very nice display of the speedtest data.
Can you give me a hint how you did that? It doesn’t seem to work with the on-board tools?
Best regards, Dirk
this is the lovelace code:
- type: vertical-stack
cards:
- type: entities
title: Internet
show_header_toggle: false
entities:
- entity: sensor.speedtest_download
secondary_info: last-updated
- entity: sensor.speedtest_download_average
- entity: sensor.speedtest_upload
- entity: sensor.speedtest_upload_average
- entity: sensor.speedtest_ping
- entity: sensor.speedtest_lastrun
format: relative
- binary_sensor.fritz_box_7590_connection
- type: horizontal-stack
cards:
- type: gauge
unit: ' '
min: 0
max: 50
severity:
red: 0
yellow: 30
green: 40
- type: gauge
unit: ' '
min: 0
max: 20
severity:
red: 0
yellow: 11
green: 15
- type: custom:apexcharts-card
graph_span: 24h
header:
show: true
title: Speedtest
apex_config:
responsive:
- breakpoint: 765
options:
chart:
height: 500px
- breakpoint: 1025
options:
chart:
height: 400px
- breakpoint: 10000
options:
chart:
height: auto
stroke:
curve: smooth
chart:
zoom:
enabled: true
toolbar:
show: true
tools:
zoom: true
zoomin: true
zoomout: true
pan: true
reset: true
plotOptions:
bar:
columnWidth: '50%'
legend:
showForSingleSeries: true
series:
show:
extremas: true
stroke_width: 3
fill_raw: last
type: line
group_by:
func: raw
duration: 30min
show:
extremas: true
stroke_width: 3
fill_raw: last
type: line
group_by:
func: raw
duration: 30min
show:
extremas: true
stroke_width: 3
fill_raw: last
type: column
group_by:
func: raw
duration: 30min
Note I am using a bash script for speedtest as I find the integration very unreliable so some of the sensor names might differ. This is what it looks like now.
See I am using custom card apexcharts-card as well
Thanks - this worked for me. I’ve seen people complain that it stops working after some time… let’s see I’ll keep an eye our. For now it’s been working for a number of hours.
I am trying to install the speedtest on a RPI 3 running Buster 10. The method above to install speed test for my rpi isn’t working. Error saying package isn’t support and to use the build for your device.
From the link above, I’ve installed the armhf build and placed the speedtest file in /usr/bin
When I test run the script, I can see the download and upload speed, but error in writing to mqtt. Is there a token I need?
error:
[email protected]:~/bin/mqtt/speedtest $ ./speedtest_result.sh
{"type":"result","timestamp":"2022-03-19T23:22:36Z","ping":{"jitter":0.95099999999999996,"latency":3.4660000000000002},"download":{"bandwidth":11873685,"bytes":42775080,"elapsed":3602},"upload":{"bandwidth":11833866,"bytes":42766320,"elapsed":3614},"packetLoss":0,"isp":"au one net","interface":{"internalIp":"192.168.1.15","name":"eth0","macAddr":"xx:xx:xx:xx:xx:xx","isVpn":false,"externalIp":"xxx.xx.xxx.xxx"},"server":{"id":14623,"host":"speed.coe.ad.jp","port":8080,"name":"IPA CyberLab","location":"Bunkyo","country":"Japan","ip":"xx.xx.xx.xx"},"result":{"id":"xxx-58b4-xxx-8ae1-xxxx","url":"https://www.speedtest.net/result/c/xxx-58b4-xxx-8ae1-xxxxx","persisted":true}}
./speedtest_result.sh: line 18: jq: command not found
./speedtest_result.sh: line 19: jq: command not found
./speedtest_result.sh: line 20: jq: command not found
./speedtest_result.sh: line 21: jq: command not found
./speedtest_result.sh: line 22: jq: command not found
./speedtest_result.sh: line 26: 10**3 * *8/10**6: syntax error: operand expected (error token is "*8/10**6")
./speedtest_result.sh: line 27: 10**3 * *8/10**6: syntax error: operand expected (error token is "*8/10**6")
0.000
{"state":"","attributes":{"time_run":"","ping":"0.000","download":"","upload":""}}
this is the script I have. I’ve only changed the topic.
#!/bin/bash
# Only edit the following setup lines with correct login information
# Mosquitto Broker Details
mqttuser=xxx
mqttpassword=xxx
mqttbroker=192.168.1.20
mqttport=1883
# DO NOT ALTER ANYTHING BELOW THIS LINE
speedtest_result=$(sudo speedtest --format=json --accept-license)
echo "**********************************************************************************************"
echo $speedtest_result
download=$(echo "$speedtest_result" | jq '.download."bandwidth"')
upload=$(echo "$speedtest_result" | jq '.upload."bandwidth"')
ping_server=$(echo "$speedtest_result" | jq '.ping."latency"')
url_test=$(echo "$speedtest_result" | jq '.result."url"' | tr -d \")
time_run=$(echo "$speedtest_result" | jq '.timestamp' | tr -d \")
echo $download $upload $ping_server $time_run
echo $url_test
download=$(printf %.2f "$((10**3 * $download*8/10**6))e-3")
upload=$(printf %.2f "$((10**3 * $upload*8/10**6))e-3")
ping_server=$(printf %.3f "$ping_server")
echo $url_test
speedteststring='{"state":"'"$url_test"'","attributes":{"time_run":"'"$time_run"'","ping":"'"$ping_server"'","download":"'"$download"'","upload":"'"$upload"'"}}'
echo $speedteststring
# Publish to MQTT Broker
mosquitto_pub -h $mqttbroker -p $mqttport -u "$mqttuser" -P "$mqttpassword" -t house/speedtestresult -m "$speedteststring" -r
So looks like it doesn’t have the jq package installed. You need to install that.
Oh shh. I thought jq
was a cmd for .sh. Didn’t realized it was a package. Got it working now. Thanks.
Hi all, bringing an oldie back to life as it seems the speedtest integration is broken again. Happened sometime on Core 2022.8.1 and still persisted after 8.4, reloaded, removed, re-added same result:
Hitting Configure throws this error:
When I do this, the systemlog contains this item, consistent with the integration:
Is anybody else experiencing this behavior as of Aug 2022?
Thanks,
Max
I’m have the same exact issue Config flow could not be loaded: undefined
Got the same problem here… reloaded the speedtest… and it came up with the same error
Same for me
I had exactly the same error after updating to 2022.8.5 earlier today, but now it’s started working again.
The SpeedTest integration seems fragile generally - mine sometimes stops working and is fixed by changing the Test Server to one or other, waiting a few minutes and then changing it back to ‘Auto Detect’. Does anyone else see this and know of a better way to fix it?
yep … i was having same issues as ian… speed test would work for about a week or so… then suddenly stop… error would be server unreachable… selecting different server or reloading usually fixes the problem… but not this time… this time after reload… whole speedtest thing has gone down…
Same issue for me. Upgraded to 2022.8.4 yesterday, same errors as @MaxVonEvil reported above. TBH I’ve never had much luck with Speedtest, it works for a random period of days/weeks then stops and needs a restart.
This integration has been shit for years starting and stopping continually. My script never misses a beat. Using the official speedtest CLI and MQTT to get the data into HA.
SO strange: Now it’s working again…
I do not seem to recall it being this unstable.
Could it be Ookla does not liking automated queries as HA does (I run at the default 60 min interval)
That said, anyone aware of any alternative integrations for fast.com or similar?
Hello David, I was wondering if you could share your config/script?
I found it, thanks for this
See Speedtest Integration No longer loading - #42 by DavidFW1960
I’ve now switched to the speedtest CLI on RPi4 (without MQTT) - Add the official speedtest cli - #40 by Britespark.
Seems to be working nicely, but will need a few more hours/days to be certain.
The reason I’m using MQTT is because it’s persistent across restarts without waiting for it to run again
I’m using MQTT for SONOFF devices without really understanding how it works…will have to put that on my learning roadmap !
Thanks for sharing @DavidFW1960 - had a few hiccups setting it up but soon resolved and looks like a beautiful solution. So far has been solid which the integration sadly is proving not to be! Thanks again
