Is it possible adjust the interval of how often Speedtest.net check speed?
You can set up a custom polling interval:
…but I believe it uses a lot of resources, so not too often.
@jackjourneyman I’m actually trying to slow it down from the current interval… e.g.: i’d like to have it run once every 5hrs
Take a look at MrSuicideParrot’s SpeedTest Home Assistant Addon. Works very well and you can adjust the interval to your needs by using a plain and simple automation.
I.e.:
- trigger: time_pattern
hours: "/5"
condition: []
- action: hassio.addon_start
addon: 6b87c29e_speedtest_addon
