Create ANY tree structure in the “conf” folder:
where each subfolder may have other subfolders and so on.
Inside any folder (let it be “network/net/asus_ac68u”, for example) create as many yaml files as you want.
Every yaml file may have “sensor”, “template”, “input_boolean”, “automation”, “customize” etc sections (surely one same section per one file, i.e. one “sensor”, one “customize” etc).
The main idea is to structure a config by tasks (network devices, persons, weather, home climat, etc) - instead of piling all template sensors in one file.
Unfortunately, there is one limitation - you must use unique filenames.
I.e. you cannot have several “test.yaml” files in different folders - have to rename them to “test_router.yaml”, “test_waterpump.yaml” etc. Created this issue, missed a moment when it was closed.
Also, if you want to exclude some functionality (like “got rid of this router”) - just remove the whole “router xxx” folder form the structure. Alternatively - rename all yaml files in this folder, replace “yaml” extension by something llike “disabled” (I use “dis”).
If you have several HA installation (apartment, country house, test setup, …) and some router is moved from one place to another - just move it’s particular folder into another installation.
Secrets may also be stored on several levels (local secrets, global secrets).
What am I missing? My sensors never show up in states!
this is what I did using your expamples.
made a folder templates, in it folder sensors and binary_sensors in those folders I placed yaml files with a sensor for instance, when I make a typo in them or leave out the word sensor: I get an error when i update template entites so ha looks in those files, that works some how
yes, found that out… had to use state.
plus I could not use !include_dir_merge_list it would not work had to use – template: !include templates.yaml.
Why I do not know but had to, could not leave out sensor: at the top of the file, it would not work.
I think I’m missing something here.
ATM I have a few templates working in my main configuration.yaml.
I’m trying to get a duplicate going from within templates.yaml. (Name Changed of course).
It doesn’t seem to be showing up.
I asume no reboot is required as the config check reports any errors when I have templates.yaml wrong.
Mine’s very simple, so my mistake must be basic.
Did try adding - sensor to the top of the file, but that caused an error on the line where - name is.
Can anyone help.
My Configuration.yaml,
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
template:
# Calculate Inverter Power
sensors:
net_power:
value_template:
"{{ ( states('sensor.sdm220m_3_power') | float | round(1)) -
( states('sensor.sdm220m_2_power') | float | round(1))}}"
unit_of_measurement: "W"
device_class: power
#state_class: measurement #Causes Error
friendly_name: Inverter Net Power
# Calculate Inverter Production
sensors:
net_production:
value_template:
"{{ ( states('sensor.sdm220m_3_import_active_energy') | float | round(1)) -
( states('sensor.sdm220m_2_import_active_energy') | float | round(1))}}"
unit_of_measurement: "kWh"
device_class: energy
#state_class: total_increasing #Causes Error
#attributes:
# last_reset: "1970-01-01T00:00:00+00:00"
friendly_name: Inverter Net Production
# Calculate Inverter Production - Alternate Code
template:
- sensor:
- name: "Inverter_Production"
unique_id: "inverter_net_prod_test"
state: >
{{ states ('sensor.sdm220m_3_import_active_energy') | float(2) | round(2)
- states ('sensor.sdm220m_2_import_active_energy') | float(2) | round(2)}}
availability: >
{{ states ('sensor.sdm220m_3_import_active_energy') | float(none) != none and
states ('sensor.sdm220m_2_import_active_energy') | float(none) != none }}
- name: "Inverter_Net_Power"
unique_id: "inverter_net_power"
unit_of_measurement: 'W'
device_class: power
state: >
{{ states ('sensor.sdm220m_3_power') | float(2) | round(2)
- states ('sensor.sdm220m_2_power') | float(2) | round(2)}}
availability: >
{{ states ('sensor.sdm220m_3_power') | float(none) != none and
states ('sensor.sdm220m_2_power') | float(none) != none }}
# - sensor:
- name: "Spa Temp Req"
unique_id: "spa_temp_req"
unit_of_measurement: '°C'
device_class: temperature
state: >
{{ states ('input_number.spa_set_temp') | float(1) | round(1)
- states ('sensor.gw1100c_v2_2_0_soil_temperature_5') | float(1) | round(1)}}
availability: >
{{ states ('input_number.spa_set_temp') | float(none) != none and
states ('sensor.gw1100c_v2_2_0_soil_temperature_5') | float(none) != none }}
# - sensor:
- name: "Spa Temp Rise"
unique_id: "spa_temp_diff"
state: >
{{ states ('sensor.gw1100c_v2_2_0_soil_temperature_6') | float(1) | round(1)
availability: >
{{ states ('sensor.gw1100c_v2_2_0_soil_temperature_6') | float(none) != none and
The templates.yaml I have created,
- name: "Spa Temp Need"
unique_id: "spa_temp_need"
unit_of_measurement: "°C"
state: >
- states ('sensor.gw1100c_v2_2_0_soil_temperature_6') | float(1) | round(1)}}
availability: >
states ('sensor.gw1100c_v2_2_0_soil_temperature_6') | float(none) != none }}
my package yaml doesn’t like the platform version so I tried this:
the template and the mqtt parts DO work.
but the filter doesn’t it doesn’t have error messages in the editor, but it also doesn’t work.
Any reason why one should not use packages over this?
I’ve found using a packages folder with individual yaml files per project/function/goal to be immensely easier and treating all my custom yamls like plug-ins.
For example, here’s the one for zigbee2mqtt with a variety of custom stuff (no modifications by me other than collecting it all in one place):
input_select
input_number
input_text
input_boolean
script
timer
mqtt
automation
All in one yaml file!
# Input select for Zigbee2MQTT debug level
input_select:
zigbee2mqtt_log_level:
name: Zigbee2MQTT Log Level
options:
- debug
- info
- warn
- error
initial: info
icon: mdi:format-list-bulleted
# Input number for joining time remaining (in minutes)
input_number:
zigbee2mqtt_join_minutes:
name: "Zigbee2MQTT join minutes"
initial: 2
min: 1
max: 5
step: 1
mode: slider
# Input text to input Zigbee2MQTT friendly_name for scripts
input_text:
zigbee2mqtt_old_name:
name: Zigbee2MQTT Old Name
initial: ""
zigbee2mqtt_new_name:
name: Zigbee2MQTT New Name
initial: ""
zigbee2mqtt_remove:
initial: ""
# Input boolean to set the force remove flag for devices
input_boolean:
zigbee2mqtt_force_remove:
name: Zigbee2MQTT Force Remove
initial: false
icon: mdi:alert-remove
# Scripts for renaming & removing devices
script:
zigbee2mqtt_rename:
alias: Zigbee2MQTT Rename
service: mqtt.publish
data_template:
topic: zigbee2mqtt/bridge/request/device/rename
payload_template: >-
"from": "{{ states.input_text.zigbee2mqtt_old_name.state | string }}",
"to": "{{ states.input_text.zigbee2mqtt_new_name.state | string }}"
zigbee2mqtt_remove:
alias: Zigbee2MQTT Remove
data_template:
topic: zigbee2mqtt/bridge/request/device/remove
"id": "{{ states.input_text.zigbee2mqtt_remove.state | string }}",
"force": {% if states.input_boolean.zigbee2mqtt_force_remove.state == "off" %}false{% else %}true{% endif %}
# Timer for joining time remaining (254 sec)
timer:
zigbee_permit_join:
name: Time remaining
duration: 254
mqtt:
# Sensor for monitoring the bridge state
- name: Zigbee2MQTT Bridge state
unique_id: zigbee2mqtt_bridge_state_sensor
state_topic: "zigbee2mqtt/bridge/state"
value_template: "{{ value_json.state }}"
icon: mdi:router-wireless
# Sensor for Showing the Zigbee2MQTT Version
- name: Zigbee2MQTT Version
unique_id: zigbee2mqtt_version_sensor
state_topic: "zigbee2mqtt/bridge/info"
value_template: "{{ value_json.version }}"
icon: mdi:zigbee
# Sensor for Showing the Coordinator Version
- name: Zigbee2MQTT Coordinator Version
unique_id: zigbee2mqtt_coordinator_version_sensor
value_template: "{{ value_json.coordinator.meta.revision }}"
icon: mdi:chip
- name: Zigbee2mqtt Networkmap
unique_id: zigbee2mqtt_networkmap_sensor
# if you change base_topic of Zigbee2mqtt, change state_topic accordingly
state_topic: zigbee2mqtt/bridge/networkmap/raw
value_template: >-
{{ now().strftime('%Y-%m-%d %H:%M:%S') }}
# again, if you change base_topic of Zigbee2mqtt, change json_attributes_topic accordingly
json_attributes_topic: zigbee2mqtt/bridge/networkmap/raw
# Switch for enabling joining
switch:
- name: "Zigbee2MQTT Main join"
unique_id: zigbee2mqtt_main_join_switch
value_template: '{{ value_json.permit_join | lower }}'
command_topic: "zigbee2mqtt/bridge/request/permit_join"
payload_on: "true"
payload_off: "false"
automation:
# Automation for sending MQTT message on input select change
- alias: Zigbee2MQTT Log Level
initial_state: 'On'
platform: state
entity_id: input_select.zigbee2mqtt_log_level
- service: mqtt.publish
payload_template: "{{ states('input_select.zigbee2mqtt_log_level') }}"
topic: zigbee2mqtt/bridge/request/config/log_level
# Automation to start timer when enable join is turned on
- id: zigbee_join_enabled
alias: Zigbee Join Enabled
platform: state
entity_id: switch.zigbee2mqtt_main_join
to: 'On'
service: timer.start
entity_id: timer.zigbee_permit_join
data_template:
duration: "{{ '00:0%i:00' % (states('input_number.zigbee2mqtt_join_minutes') | int ) }}"
# Automation to stop timer when switch turned off and turn off switch when timer finished
- id: zigbee_join_disabled
alias: Zigbee Join Disabled
- platform: event
event_type: timer.finished
event_data:
- platform: state
to: "off"
- service: timer.cancel
- service: switch.turn_off
- id: "zigbee2mqtt_create_notification_on_successful_interview"
alias: Zigbee Device Joined Notification
platform: mqtt
topic: 'zigbee2mqtt/bridge/event'
condition: template
value_template: '{{trigger.payload_json.type == "device_interview" and trigger.payload_json.data.status == "successful" and trigger.payload_json.data.supported}}'
- service: persistent_notification.create
data_template:
title: Device joined the Zigbee2MQTT network
message: "Name: {{trigger.payload_json.data.friendly_name}},
Vendor: {{trigger.payload_json.data.definition.vendor}},
Model: {{trigger.payload_json.data.definition.model}},
Description: {{trigger.payload_json.data.definition.description}}"
