Full and extensive documentation can be found here: https://spook.boo ![]()
Don't forget to star
the repo.
PS: Thanks for the
, Spook is, after all, your homie.
../Frenck
PS: Thanks for the
../Frenck
Initial feature set (v0.1.88)
β¦/Frenck
Absolutely hilarious!
Hehe. Iβm not gonna install this
This would have been a great Aprils Fools project!
There are quite a few useless and horrible services available for you to explore and self-descruct your setup with. The developer service tools are great to get you into such a situation.
Amazing and hilarious! Exactly what I was looking for, as someone developing for HA.
Is this meant to be educational in some way? Such as demonstrating anti-patterns?
No, not really. It just provides extensions/services/data that are mostly useless, or would never be added to Home Assistant itself directly. For that last reason, it would mean things it does are not acceptable from the perspective of the Home Assistant project.
However, some features it provides have been long requested, denied in the past as contributions, or are simply too freaking useless to add to Home Assistant itself. That doesnβt mean they couldnβt be helpful to you.
β¦/Frenck
input_select.randomselect.randomIβve extended the readme of the custom integration to make this more clear.
Thanks for your question/response
β¦/Frenck
number.incrementnumber.decrementinput_number.increment to support the amount to increaseinput_number.decrement to support the amount to decreasespook.booNo one should use the following services should they ever be added:
select.select_next
select.select_previous
select.select_first
select.select_last
#kiddingnotkidding
Like this?
Whoa @frenck thatβs an amazing PR. Thanks.
Can it be announced in the βOther noteworthy changesβ section of the upcoming Release Notes? Itβs a useful enhancement and itβs currently only visible far down the list of βAll Changesβ.
I havenβt read the documentation (who has time for that) or the rest of this thread, but since this is developed by @frenck, itβs fully supported by the HA core team, right? #attemptathumor
hehe #disclaimer
https://github.com/frenck/spook#disclaimer
That said, it is using the Passive Aggressive license. So, nothing to worry about
