Thanks for your reply!
Added the indents, but still getting the same error.
The ModuleNotfound error disappeared for me after an extra restart of HA.
@fondberg
looking at the media_player on Github there seems to be two contributors cgtobi & balloob
I restarted several times now, but still getting the same errors.
Succesfully added the custom component but when try to play something with the following service, I get the error below.
âdevice_nameâ : âGoogle Home Speelkamerâ,
âuriâ : âspotify:playlist:37i9dQZF1DX3yvAYDslnv8â
No module named âspotify_tokenâ
18:21 custom_components/spotcast/init.py (ERROR) - message first occured at 18:16 and shows up 3 times
awesome work man. I like your Spotify card and now this. Iâll start testing it soon and let you know of any issues.
Which version of HA are you running? I think my component requires 0.92 because the dependencies changed in that release to be specified in a manifest instead of in the python file.
If you are running 0.92 I would look in the logs for any errors importing spotify_token
@capstan1 ^^ you should also follow this
0.91.4. Will try again after an upgrade to 0.92
Should be the issue. Didnât want to update Hassio because I wouldnât have the time to troubleshoot right now. Think I will upgrade this weekend, so Iâll let you know if that helps!
Thanks!
Just updated to 0.92.1, this fixes the problem! Great!
It takes about 6-8 seconds to actually play a song after executing the command. Is this normal (for now)?
Yeah Iâm seeing the same currently on .92.1
After a reboot my google does appear ad playing on HA
Itâs just the delay
It takes time because it needs to launch the app after discovering hr device
I donât know python, but am happy to help in anyway I can.
This binary sensor will detect if Spotify is playing on a specific Google Chromecast device. I use it for my automations that automatically toggle the amp when audio is playing. Reason for this template sensor is the media_player device shows as âoffâ when the cast was started from Spotcast, even when the device is in fact playing.
binary_sensor:
sensors:
stereo_spotcasting:
friendly_name: "Stereo is playing Spotcast"
value_template: "{{ is_state_attr('media_player.spotify','source','Stereo') and is_state('media_player.spotify','playing') }}"
Of course replace âStereoâ with your device name.
noob question but how do i use this:
cd /config/custom_components && git clone https://github.com/fondberg/spotcast.git
thanks!
@Mikomi instead of that you can just download the files and put them in /config/custom_components/spotcast/
Thanks!
Sensor.chromecast_devices detects them now. But they dont show up he source selection of my Spotify media player. Or does this only work with the custom playlist card?
@Mikomi this component and the spotify-card custom card doesnât use the media_player spotify⌠yet⌠I am thinking of merging my components functionality somehow in media_player.spotify.
This components sensor just lists the chromecast devices in your network and media_player.spotify doesnât make use of chromecast devices, only logged in started Spotify connect devices⌠phew⌠this isa little bit of a mess but hopefully this can be sorted out in the future
Aha, this explains a lot. Thanks for the detailed information. So if im correct i need to craft custom âbuttonsâ for my playlists or use the custom card, right?
Thanks for your work it was what I wanted for a while now.
Depends on your usecase is to start Spotify playback on idle chromecast devices then yes. If it is to start playing a playlist on an already launched Spotify connect device (which launching Spotify on a chromecast device does) then stick with media_player.spotify
