Before it worked perfectly, but now it dont work.
I receive the message: spotcast Could not find device with name
Log in Homeassistant:
Known devices: []
23:24:20 – Start Spotify on chromecast (ERROR)
No device with id "a277e2bf1f1f19679a28d6835b63c308" known by Spotify
I get the same as you today.
It worked yesterday.
Log:
2021-03-23 09:13:06 ERROR (SyncWorker_4) [custom_components.spotcast] No device with id "anonymized" known by Spotify
2021-03-23 09:13:06 ERROR (SyncWorker_4) [custom_components.spotcast] Known devices: []
Trying to get Spotcast to work with both a Nest mini and connected devices. All devices used are listed in my Spotify account.
Spotify integration is working fine.
In configuration.yaml the values for sp_dc and sp_key are set.
Whenever I try to use a connected device, like this:
I get an error: [139620993471440] Failed to get device id from Spotify. Funny thing is that when the Nest mini is not idle it starts playing anyway. When idle, nothing happens.
I’m using a Facebook login for Spotify and connected HA with Spotify using the unique username and password. Have tried cookie values when logged in with Facebook and with unique username.
Logger: homeassistant.components.websocket_api.http.connection
Source: custom_components/spotcast/__init__.py:478
Integration: Home Assistant WebSocket API ([documentation](https://www.home-assistant.io/integrations/websocket_api), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+websocket_api%22))
First occurred: 22 marca 2021, 22:52:14 (16 occurrences)
Last logged: 10:39:58
* [XXXXXXXXXXXX] Failed to get device id from Spotify
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 141, in handle_call_service await hass.services.async_call( File "/usr/src/homeassistant/homeassistant/core.py", line 1488, in async_call task.result() File "/usr/src/homeassistant/homeassistant/core.py", line 1527, in _execute_service await self._hass.async_add_executor_job(handler.job.target, service_call) File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run result = self.fn(*self.args, **self.kwargs) File "/config/custom_components/spotcast/__init__.py", line 296, in start_casting spotify_device_id = spotify_cast_device.getSpotifyDeviceId(client) File "/config/custom_components/spotcast/__init__.py", line 478, in getSpotifyDeviceId raise HomeAssistantError("Failed to get device id from Spotify") homeassistant.exceptions.HomeAssistantError: Failed to get device id from Spotify
Logger: custom_components.spotcast
Source: custom_components/spotcast/__init__.py:477
Integration: Start Spotify on chromecast ([documentation](https://github.com/fondberg/spotcast))
First occurred: 22 marca 2021, 22:52:14 (17 occurrences)
Known devices: []
Same Problem, out of nowhere none of my spotcast things work.
Have tried replacing entity_id with device_name
Still shows error: 2021-03-24 08:00:02 ERROR (SyncWorker_8) [custom_components.spotcast] No device with id "33fa00a66f2edf0d1c5697a9f8693ba8" known by Spotify 2021-03-24 08:00:02 ERROR (SyncWorker_8) [custom_components.spotcast] Known devices: []
This is WITH EITHER ENTITY_ID OR DEVICE_NAME
I have removed and readded the spotify integration, removed and readded devices, created new sp_dc and sp_key cookies, and created a new secret for the dev app.
When already playing a song via spotify the integration is able to control, but not change speaker output, when attempting to move speakers(even selecting the one currently on and in use) is met with the same error as above.
Let me know if any other testing should be done.
Hi everyone,
Same here, Spotcast was working fine for months, and since a few days I get the error : “failed to get device id from spotify”.
Any ideas please ?
Setup failed for spotcast: Unable to import component: cannot import name ‘KNOWN_CHROMECAST_INFO_KEY’ from ‘homeassistant.components.cast.media_player’ (/usr/src/homeassistant/homeassistant/components/cast/media_player.py)
Tried to find Spotcast in HACS to see if can reinstall but could not locate Spotcast nor it would allow me to add the repository saying it is already in the catalog.
Pychromecast has been updated to 9.0 with latest HA according to the changelog. Since spotcast depends on that, perhaps it needs to be updated too. https://github.com/home-assistant/core/pull/47086
I don’t use spotcast anymore, so I’m not of any help, but wanted to drop this information.
