OK, thanks for your time and efforts so far @fondberg, appreciate it!
Waiting eagerly for group support so I can automate my “come home from work on friday” playlist.
Grym component fö!
Me too, seems like we are close… there was a “solution example” posted in the Github Issue for Group Play
Im very hopeful that soon this will work from Home Assistant.
Yes I tried it and added comments. Problem is that the results fluctuates between my findings and @Ph0z findings…
I’m getting the sensor.chromecast is taking over 10 seconds error very frequently:
2019-05-11 12:40:09 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.chromecast_devices is taking over 10 seconds
2019-05-11 13:08:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.chromecast_devices is taking over 10 seconds
2019-05-11 13:10:07 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.chromecast_devices is taking over 10 seconds
2019-05-11 13:25:06 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.chromecast_devices is taking over 10 seconds
2019-05-11 13:41:07 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.chromecast_devices is taking over 10 seconds
2019-05-11 13:55:04 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.chromecast_devices is taking over 10 seconds
2019-05-11 14:10:02 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.chromecast_devices is taking over 10 seconds
2019-05-11 14:25:01 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.chromecast_devices is taking over 10 seconds
2019-05-11 14:32:15 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.chromecast_devices is taking over 10 seconds
2019-05-11 14:40:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.chromecast_devices is taking over 10 seconds
My Hass.io is freezing within the last days and mostly these are the latest error messages I get. I’m still not sure if its really connected. Do you see any possible connection?
You said before, the error can be ignored. Is there a way to hide this error, then?
Weird. This should be kind of quick and I think it might be due to slow network. Are you connected using wifi?
The Raspi is connected with Ethernet. (All Google Homes obviously are connected with WiFi)
@capstan1 you can try commenting out the init of the chromecast sensor (not needed to start casting)
# hass.helpers.discovery.load_platform('sensor', DOMAIN, {}, config)
Maybe it is pychromecast which is bogging things down
For anyone who want to try bleeding edge until fondberg has updated his. I’ve created a fork which should allow support for group casting and also transferring of playback to your chromecast devices.
Requires the updated pychromecast controller.
Use at your own risk
Speaker groups and multi accounts is now released. Head over to https://github.com/fondberg/spotcast to download the latest.
I also moved all logging to debug level so if you experience problems add custom_components.spotcast: debug to your logger configuration.
Example:
logger:
default: info
logs:
custom_components.spotcast.: debug
Works like a charm! Thanks for this wonderful project.
For people updating manually by replacing the component’s files: be sure to delete the __pycache__ folder. Been pulling my hairs out over that the last hour, because streaming didn’t start.![]()
Did comment it out, up to now the error didn’ts show up. Thanks!
btw: any way to buy you a coffee?
Great it resolved itself. Can you open a ticket on github so I can investigate if there is a better way to run pychromecast?
For a coffee I added the link button in the README in the repo.
Here it also comes. I love coffee
All, anyone with knowledge custom updater who can help me with adding support for this?
You can either tell me what to do or just create a PR yourself
Hope you’ll get a good coffee!
I’ll wait a bit with reporting the bug. I noticed that I didn’t get an error within the last 2 hours, although I didn’t yet change the sensor in your latest version. So I’ll have to investigate a little bit more (also it came to my mind that my Google Home Max dropped Wifi connection several times within the last week - maybe that caused the error)
I need a bit help, have not figured out everything about all the things in HA. But could someone point me to the direction how to get the music starts to play when i push a button?
Thanks in advance
You first need to make a script like so:
script:
play_music_cc:
alias: Play music
sequence:
- service: spotcast.start
device_name: “CC device name”
uri: “yourplaylistURI”
Then we can trigger it in an automation, like so:
- alias: ‘Play music’
initial_state: ‘on’
platform: event
event_type: deconz_event
event_data:
event: 1002
> action:
> service: script.turn_on
> entity_id: script.play_music_cc
Sorry for my formatting, could not find an option for code…
+1 Coffee from me. Very well deserved. Just installed the latest version. Casting to Group Works without a flaw so far for me. I was using hacky work arounds for too long. Thank you a lot!
@Pliind Thank you for the input. I made it work with your help.
Is there a way to make the playlist shuffle as well?
Glad to be of help, sat with that issue myself a while, noticed that a reboot helps alot with making new scripts triggable in the automation.
Shuffle was also one of the things i fixed, since you dont want the same song to start every time you press that button. So you need the spotify component for this Spotify
See here: With this script i get a new song every time it starts playing.
bathroom_music_cc:
alias: Playing Bathroom
sequence:
device_name: “CC device”
uri: “Playlist”
- service: media_player.shuffle_set
entity_id: media_player.spotify
shuffle: true
Hi there, i was just creating a service call for the Spotcast component. And i realized that the call for the device is: “device_name”.
I was wondering if its possible to use the entity_id of the Cast Media Players to send the required names. i.e.:
states.media_player.tv.attributes.friendly_name
I was trying to rename some fields in the custom component it to “entity_id” to make it work with the entity selector. It works but only partialy because i do not know if its even possible to have an attribute from a state to be read by the component.
To me it seems like i need to tell the component to take the entity_id: media_player.tv but then internally only parse the attribute friendly_name and use this instead of device_name. No idea how to do that.
Basically what im asking is this:
Would it be possible to match the already installed media player chromecasts, google homes etc with the component to use them as entities?
