I also would like that. Is there any way?
How to get bigger covers in grid view?
Just reduce the number of covers per row. The covers are resized accordingly.
I use HACS
I follow the instructions on
but i doesn’t work
- I installed The component Spotify Integration (It works) and spotcast (It Works)
I tryed to add the add-on with Manage add-on repositories adding
https://github.com/custom-cards/spotify-card.git but this is the result
unknown
unknown
and the add on is not added
I tryed to add manually follow the instructions but without success
i’m not able to create the card manually without error
the error is Error: Custom element not found: spotify-card
What can be thr problem?
Very Thanks
It works now
i changed this
/local/community/spotify-card/spotify-card.js
with
/hacsfiles/spotify-card/spotify-card.js
SOLVED
I’m trying the card work great… but the volume not… there is a way to make it work? Thanks
You dont have to add the repository manually, it’s already included in HACS standard repositories.
What exactly is not working with the volume? Please be more specific.
If i click on volume the slide appair if i change the value the volume not change… also the button || |< >| pause previous next - not have effect!
I tryed but the card is memorized as
unknown
unknown
and it didn’t appair in the listed addon
the answer is for
Have you cleared your cache after the installation?
Are there any error messages in your browser’s developer console, which are related to the spotify-card? And are you sure, that the spotify integration is working correctly?
I can command play pause next previous volume of the google home player with the media player card but if i use the button of the spotify card nothing happen, I don’t see any error message related to spotify.
No i didn’t… I installed manually and now it work apart from the buttons!
Is it possible to hide the footer or at least the control buttons? It would also be great to remove the borders of the card to use it instack with another borderless cards.
An option to hide the playback controls is added in the latest release!
Your spotify player also has to have playback controls like your google home player. Did you follow the guide here: https://www.home-assistant.io/integrations/spotify/?
This spotify-card uses the interface provided by the spotify integration to control the playback, thus a correct installation of spotify integration is needed.
Could you share your YAML config for this card? Very curious on how to add the volume sliders and shortcut buttons to play on certain devices.
This is Lovelace: Mini Media Player
type: entities
title: Музыка
entities:
- type: 'custom:mini-media-player'
entity: media_player.all
group: true
artwork: material
hide:
entity: media_player.room
artwork: none
icon: 'mdi:cast-audio'
group: true
hide:
controls: true
power: true
info: true
progress: true
entity: media_player.bath
group: true
artwork: none
icon: 'mdi:dots-horizontal-circle'
hide:
controls: true
power: true
info: true
progress: true
entity: media_player.hall
group: true
artwork: none
hide:
controls: true
power: true
info: true
progress: true
entity: media_player.kitchen
group: true
artwork: none
icon: 'mdi:google-home'
hide:
controls: true
power: true
info: true
progress: true
- type: 'custom:spotify-card'
grid_covers_per_row: 5
display_style: list
hide_top_header: true
limit: 1
account: default
spotify_entity: media_player.spotify_dmitrii
playlist_type: default
always_play_random_song: true
grid_center_covers: true
hide_playback_controls: true
hide_currently_playing: true
default_device: All
filter_devices:
- SLIM.*
- ANDORID.*
- OnePlus.*
- TEPLOV.*
entity: media_player.yandex_station_ff98f010bf59997e7b711b32
group: true
artwork: none
icon: 'yandex:irbis-a'
tts:
platform: yandex_station
hide:
controls: true
power: true
info: true
volume: true
progress: true
