Update!
I actually installed the Controller yesterday, so it is ONLINE!
I have not done permanent mounting, wire cleanup yet, but I do have it working.
Comments/Questions:
I have setup the on-board LED as a “light”, and set up automations, that when each zone is running, led will flash x number of times (corresponding to the zone), then wait 2 seconds, and do it over and over until that zone stops, then next zone, etc… (ie: Zone 5, light turn on/off 5x, then pause and start again).
I have noted for a switch for the rain sensor, but the one I have appears to be dead (at least from checing w/multimeter). No biggie. What I am thinking of doing, is to build an automation that if precipitation = raining or > 0 in last two days (according to accuweather, etc…), then Pause/Stop irrigation system.
i have Scheduler setup to turn on controller on given day/set time…
Will system use whatever time i have setup the controller timers? If not, how can i setup th escheduled run giwith hard - coded timers by zone?
Ths
Lastly, OT (but kind of is on topic)… Is it me, or is Home Assistant like a “Black Hole”?
Hear me out (I don’t mean it in a bad way).
I had persisted testing it out for a while, but now that I am playing w/it, it can do so many things, that I can’t finish one thing I wan to try before I start downloading/setting up another feature, and next thing you know, I’ve been at it all day long!!!
That’s how the controller started… I had one zone that was not kicking on my existing system… had to dig ou the shovel to find the valves (what fun that was!!)… Anyway, Valve rebuild kit and new solenoid later, the valve is running, but the expansion module on the controller keeps going off-line… new modules are about $80.00.
I decided i could do this myself… i have time… jumpered the bad zone (5) onto zone 4 (run both valves at the same time)… and place order for what I was missing on Ali (relays, esp32’s)… got them within 2 weeks…
Now i want to throw the kitchen sink into HA… Any ideas for fun ESP32 projects for HA???
thanks all!
