Does margin work, because the card isn’t moving up. It’s just the icon that is clipping out of the card.
- type: custom:button-card
tap_action:
action: call-service
service: script.fernseher_ok
icon: mdi:circle-outline
show_name: false
icon_height: 50px
styles:
card:
- margin-top: '-20px'
- border-radius: 0px
- border: 2px
- padding: 0
- box-shadow: none
this is inside a custom:stack-in-card ass you can see
pimp1310
(Pimp1310)
November 4, 2021, 6:01pm
209
hello,
i tried your code but i get another output:
have you perhaps a idea?
@RomRider sorry for direct address, but can you have a look at these issues?
opened 02:12AM - 18 Dec 21 UTC
bug
<!-- READ THIS FIRST:
- If you need additional help with this template please r… efer to https://www.home-assistant.io/help/reporting_issues/
- Make sure you are running the latest version of Home Assistant before reporting an issue: https://github.com/home-assistant/home-assistant/releases
- Provide as many details as possible. Do not delete any text from this template!
**Checklist:**
- [x ] I updated to the latest version available
- [ x] I cleared the cache of my browser
**Release with the issue:**
0.2.0
**Last working release (if known):**
**Browser and Operating System:**
Win10x64, Chrome
Provide details about what browser (and version) you are seeing the issue in. And also which operating system this is on. If possible try to replicate the issue in other browsers and include your findings here.
**Description of problem:**
If one `stack-in-card` contains another `stack-in-card`, the card my not be displayed:
1. Open some dashboard.
2. Switch to "edit" mode.
3. Add a new card and then paste code into Editor. Save the changes.
4. The card is not displayed:
![image](https://user-images.githubusercontent.com/71872483/146625764-d27711af-a4f2-40f3-8eff-9fa71437d187.png)
5. Switch off the edit mode.
6. The card is not displayed.
7. Refresh the page.
8. The card is displayed.
Explain what the issue is, and how things should look/behave. If possible provide a screenshot with a description.
**Javascript errors shown in the web inspector (if applicable):**
no errors
**Additional information:**
type: custom:stack-in-card
mode: vertical
keep:
background: true
box_shadow: false
margin: true
outer_padding: false
border_radius: true
cards:
- type: entities
entities:
- sun.sun
card_mod:
style: |
ha-card {
--ha-card-background: red;
- type: custom:stack-in-card
mode: horizontal
keep:
background: true
box_shadow: true
margin: false
border_radius: true
cards:
- &ref_button
type: button
card_mod:
style: |
ha-card {
--ha-card-background: grey;
- *ref_button
- *ref_button
![image](https://user-images.githubusercontent.com/71872483/146625720-736c223c-85aa-46d4-973c-ede108ba4464.png)
opened 11:30PM - 08 Dec 21 UTC
bug
**Checklist:**
- [x ] I cleared the cache of my browser
0.2.0
Chrome, Win10x64
If the 'keep: margin: false' is set then the margin between card is supposed to be 0.
It works for two Entities cards:
mode: vertical
keep:
background: true
box_shadow: false
margin: false
border_radius: false
cards:
- type: entities
entities:
- sun.sun
card_mod:
style: |
ha-card {
background-color: red;
- type: entities
entities:
- sun.sun
card_mod:
style: |
ha-card {
background-color: green;
![image](https://user-images.githubusercontent.com/71872483/145307298-565f1905-235a-45b9-b80b-a27e435361d9.png)
But if the 2nd card is `stack-in-card`, then the margin is present anyway - look at the margin-top:
mode: vertical
keep:
background: true
box_shadow: false
margin: false
cards:
- type: entities
entities:
- sun.sun
card_mod:
style: |
ha-card {
mode: horizontal
keep:
background: true
box_shadow: false
margin: false
cards:
- type: entities
entities:
- sun.sun
card_mod:
style: |
ha-card {
- type: entities
entities:
- sun.sun
card_mod:
style: |
ha-card {
![image](https://user-images.githubusercontent.com/71872483/145307395-e8643d5f-1b8e-4bfd-ad80-1c908266f0d0.png)
![image](https://user-images.githubusercontent.com/71872483/145307595-bce420c1-bda4-4f29-a823-a26690346e9b.png)
no
Using the card gives erratic results…
Was observed in 2021.12.
on a regular base, I see the spaces between button-cards in this horizontal stack-in-card reappear. refreshing the page a few times then makes it ok again, concatenating the buttons as they should:
this is a set of button cards in:
mode: horizontal
keep:
background: true
cards:
#history.back(-1)
I believe the stack-in-card sets ‘outer-padding’ to 0, but, and here comes the question, if I do that in a core horizontal-stack, nothing happens, and I see all separated buttons.
- type: horizontal-stack
cards:
#history.back(-1)
template: button_shortcut_menu
given the fact these all use a button_shortcut_menu
template, I was wondering if I could set a card styles:
option for the outer-padding (obviously tried that)
card:
- box-shadow: none
- background: >
[[[ return variables.view === variables.path
? 'var(--secondary-background-color)' : 'var(--background-color-off)'; ]]]
- padding-top: 10px
- padding-bottom: 10px
- outer-padding: 0 #<--- no functional, but to show what I am looking for
but it doesnt work… so, please help me out if I can set anything css option here, to get the same result and make the buttons touch?
thanks!
not sure, I dont have keep: margin: false set, only keep background: true
and it’s not always, it comes and goes. Bam, as we type:
somehow the default card-background-color of my current theme peeps through… (this is the stack-in-card, not the horizontal stack)
added the margin: false
to see if that improves things.
update
no that doesnt seem to make a difference. Would be surprising too, because ‘false’ is the default value.
what does seem to help, is changing to:
mode: horizontal
keep:
background: true
card_mod:
style: |
ha-card {
background-color: var(--background-color-off);
so, if it peeps through, its the same as the default button background might be considered a hack…
Would still love to learn which variable sets the space between cards in core Lovelace though…
Seems that the repository is not maintained for a long time.
One of the most critical issue is this:
The custom:stack-in-card
is incompatible with the new Material Web Components’ dropdown list control.
Surely this issue (and some others) may be fixed by card-mod.
ilgio
(ilgio)
May 17, 2022, 1:54pm
215
how can i put a border around the two cards
multirow + horizontal?
similar
my code is
title: titolo
keep:
box_shadow: true/false
margin: true/false
border_radius: true/false
background: true/false
outer_padding: true/false
cards:
- entity: input_boolean.irrigazione_flag_zona1_ciclo3
type: custom:multiple-entity-row
state_color: false
state_header: 3
toggle: false
show_state: false
entities:
- entity: input_select.irrigazione_tipo_zona1
cards:
entity: input_boolean.irrigazione_zona1_lun
show_icon: false
entity: input_boolean.irrigazione_zona1_mar
show_icon: false
entity: input_boolean.irrigazione_zona1_mer
show_icon: false
entity: input_boolean.irrigazione_zona1_gio
show_icon: false
entity: input_boolean.irrigazione_zona1_ven
show_icon: false
entity: input_boolean.irrigazione_zona1_sab
show_icon: false
entity: input_boolean.irrigazione_zona1_dom
show_icon: false
state_color: false
state_header: 3
toggle: false
show_state: false
entities:
cards:
show_icon: false
show_icon: false
show_icon: false
show_icon: false
show_icon: false
show_icon: false
show_icon: false
benm7
(Ben M)
July 11, 2022, 2:51am
216
Is there any way to have the cards within the stack occupy min-content rather than 1/x of the stack?
Seems to be a job for card-mod.
Experiment.
Vandana
(Vandana Dass)
August 27, 2022, 6:12am
218
I added Stack-In-Card via hacs frontend integration. I restarted Home assistant but Sick-In-card is not showing when I try to add a card in Lovelace dashboard UI.
What am I doing wrong ? Kindly guide. I am on Home-assistant ver 2022.8.7
gnec220
(Ratna Kumar )
August 29, 2022, 9:44am
219
i have the same problem as @Vandana has. can you please help us ?
Do you mean “I do not see any UI to add a new card of stack-in-card type”?
If yes - check this scenario:
Add a card of ANY type.
Edit the added card in yaml mode.
Rewrite this card to stack-in-card.
gnec220
(Ratna Kumar )
September 3, 2022, 6:39am
221
Hi, it says no card type found. see the omahe below:
Do you use a storage mode of Lovelace?
If yes - does your card’s code start with “-“?
If yes - remove it.
Any workarounds for this? I have nested stacks but indeed doesn’t show. For a while it hasn’t been a problem up until 2 months ago or something. Also, some pages it actually does work, it only appears to be missing in a state switch configuration.
Must admit that for the last time I do not observe the “Card may not be displayed if one stack contains another stack” issue .
Probably will close it after some testing.
What is your code which does not work?
Post a SHORT simplified version.
Update 08.09.22: closed this issue; do not see problems on 2 setups (2022.7, 2022.9).
Not sure how to make it short and simple without stripping too much of code, I use the headers from @benm7 this one is based on the alarm state to make it green/red.
- title: ""
icon: mdi:shield-check
path: security
badges: []
cards:
- type: custom:state-switch
entity: alarm_control_panel.alarmo
default: disarmed
states:
disarmed:
mode: vertical
keep:
box_shadow: true
margin: true
border_radius: true
background: true
outer_padding: true
style: |
ha-card {
background-color: rgba(var(--color-green),0.7);
border-radius: var(--border-radius);
cards:
- type: "custom:layout-card"
layout_type: grid
layout:
grid-template-columns: 24% 76%
margin: 0px 0px 0px 0px
cards:
mode: vertical
keep:
box_shadow: false
margin: false
border_radius: true
background: false
style: |
ha-card {
background-color: rgba(var(--color-green-bg),1.0);
border-radius: var(--border-radius-bar);
box-shadow: none;
cards:
cards:
- type: 'custom:button-card'
template: chip_back
variables:
ulm_chip_back_path: /ui-lovelace-minimalist/home
template: chip_navigate
variables:
ulm_chip_navigate_path: /ui-lovelace-minimalist/home
ulm_chip_navigate_icon: mdi:home
- type: "custom:button-card"
template:
- "card_title_icon"
name: "Beveiliging en veiligheid"
variables:
ulm_card_navigate_title: Beveiliging en veiligheid
ulm_card_navigate_icon: mdi:shield-off
icon_color: green
background_color: green-bg
# More state-switches stripped away to reduce code
template: "card_title_fixed_small"
template:
- "custom_alarm"
variables:
ulm_custom_alarm_grid_state: alarm_control_panel.alarmo
# More cards below here of course ;)
SHORT - means “everyone may take your code and reproduce it”.
Here you got your own unique entities and especially button-card-templates.
To understand a reason of your problem - start with simplifying your code.
driz
(driz)
September 13, 2022, 4:12pm
227
Hello all, I searched this thread (and ghi) for anything about card gaps, but what I found didn’t seem to apply. I’m just converting a vertical stack to stack-in-card. I was hoping to eliminate the gaps from vertical stack (see image)
After moving to stack-in-card, the black emptiness is gone, but the gap is still present.
title: Kid1 Chores
mode: vertical
cards:
- type: entities
entities:
- entity: input_boolean.chore_12
- entity: input_boolean.chore_11
show_header_toggle: false
state_color: true
- type: entities
entities:
- entity: input_boolean.chore_10
state_color: true
Is there any way to eliminate the gap between cards to make it appear as if it were one single card? If that is not a function of this card, my apologies in advance. Note that while the code makes it look like i could just put all the entities together, in reality i am using conditional cards to only display some entities cards on certain days, i removed that code to confirm the conditional card wasn’t the cause.
