Stack-In-Card: Drop-in replacement for vertical-stack-in-card
I think this is not actually an issue with stack-in-card, as it does eliminate the gap between the 2 entities cards, as confirmed by looking at Web Developer Tools in a (firefox) browser.
The issue therefore comes from the entities cards themselves, with each having an even 8 pixel padding around the main card content, which then adds up to a 16 pixels gap between the 2 cards.
You can address this by using Thomas Lóven’s card-mod, which (assuming you don’t already know this) allows you to style individual cards at a very fine grained level.
This code works for me using this approach:
- type: custom:stack-in-card
  title: Kid1 Chores
  mode: vertical
  cards:
    - type: entities
      card_mod:
        style: |
           div#states.card-content {
             padding-bottom: 4px;
      entities:
        - entity: input_boolean.chore_12
        - entity: input_boolean.chore_11
      show_header_toggle: false
      state_color: true
    - type: entities
      card_mod:
        style: |
             padding-top: 4px;
      entities:
        - entity: input_boolean.chore_10
      state_color: true
If you don’t want to use card-mod, and it maybe won’t be straightforward if you have several conditional cards showing or not showing, then maybe you could try using a single entities card with conditional rows instead? (I’ve not explored this myself to see if it works)
Assume you got two entities cards with fixed padding-bottom (as it was advised before).
If some conditional card IS shown - then you will not see the gap.
But when some conditional card is NOT shown - a small gap is displayed instead of the card.
Check GitHub for issues with conditional cards.
Consider conditional rows (as it was advised before). Or use state-switch card if you decide to show some other cards conditionally.
This is great! I will give this a shot and see how it works, thank you!
Thank you as well Ildar_Gabdullin, I will be sure to check for the issues with conditional cards and possible work-arounds.
Do you guys have any problem of show stack in card on phone? I use both Android and iOS but can’t load. On PC is fine
Basically when one stack contains another stack - this glitches on iOS.
I’ve noticed this also on Chrome and on Android Companion app… Reverted to 0.1.1 and works as expected in my case.
Is this not recommended to use anymore since its abandoned? Is it any alternatives to use?
Does it even work? did not for me
Works in my setup.
A month ago also added it to the test HA instance:
There is a glitch on the picture (a line between stacks) but this is another issue…
The card - yes! - seems to be abandoned, no changes on open issues.
All my issues may be fixed by card-mod.
Like this wrong margin (empty space of white color):
code
mode: vertical
keep:
  background: true
  box_shadow: false
  margin: false
  outer_padding: false
  border_radius: false
cards:
  - type: entities
    entities:
      - sun.sun
    card_mod:
      style: |
        ha-card {background-color: red}
    mode: horizontal
    keep:
      background: true
      box_shadow: false
      margin: true
      outer_padding: true
    cards:
      - type: button
        card_mod:
          style: |
            ha-card {background-color: cyan }
      - type: button
        card_mod:
          style: |
      - type: button
        card_mod:
          style: |
    card_mod:
      style: |
        ha-card {background-color: green}
I guess there’s no card_mod fix for the stack inside stack showing box-shadows, margin, etc.? I found that by using the stock horizontal or vertical stack cards the issue doesn’t occur. Unfortunately I’m using collapsable-cards which has the problem.
couldnt get it working either, card type not found
Hello everyone, I am doing a energy card, and I am getting issues with the doble and tripple. backgrounds.
mode: vertical
cards:
    mode: horizontal
    keep:
      box_shadow: false
      margin: false
      background: false
    cards:
        mode: vertical
        keep:
          box_shadow: false
          margin: false
          background: false
        cards:
            primary: 'Casa: {{ states(''sensor.energy'') }} W'
            secondary: '{{ states(''sensor.cost'') }} €/h'
            icon: mdi:home
            entity: sensor.cost
            icon_color: green
            layout: horizontal
            card_mod:
              style: |
                ha-card {
                  margin-top: 5px;
                  margin-bottom: 2px;
                  width: 180px;
                  margin-left: 10px;
          - type: custom:apexcharts-card
            chart_type: donut
            header:
              show: false
              show_states: false
              colorize_states: false
            series:
              - entity: sensor.resto_c
                show:
                  legend_value: false
                  datalabels: false
              - entity: sensor.shelly_ion
                show:
                  legend_value: false
                  datalabels: false
              - entity: sensor.rpabellon
                show:
                  legend_value: false
                  datalabels: false
                show:
                  legend_value: false
                  datalabels: false
              - entity: sensor.depuradora
                show:
                  legend_value: false
                  datalabels: false
              - entity: sensor.lights_po
                show:
                  legend_value: false
                  datalabels: false
            update_interval: 120s
            apex_config:
              legend:
                show: false
              chart:
                height: 180px
            card_mod:
              style: |
                ha-card {
                  margin-left: +10px;
                  width: 180px;
        mode: vertical
        cards:
            primary: 'Otros: {{ states(''sensor.energy'') }} W'
            icon: mdi:home
            entity: sensor.cost
            icon_color: yellow
            layout: horizontal
            card_mod:
              style: |
                ha-card {
                  margin-top: 5px;
                  margin-bottom: 0px;
                  width: 180px;
                  margin-left: 0px;
            primary: 'Cocina: {{ states(''sensor.energy'') }} W'
            icon: mdi:home
            entity: sensor.cost
            icon_color: green
            layout: horizontal
            card_mod:
              style: |
                ha-card {
                  margin-top: -10px;
                  margin-bottom: 0px;
                  width: 180px;
                  margin-left: 0px;
            primary: 'Pabellón: {{ states(''sensor.energy'') }} W'
            icon: mdi:home
            entity: sensor.cost
            icon_color: red
            layout: horizontal
            card_mod:
              style: |
                ha-card {
                  margin-top: -10px;
                  margin-bottom: 0px;
                  width: 180px;
                  margin-left: 0px;
            primary: 'Pérgola: {{ states(''sensor.energy'') }} W'
            icon: mdi:home
            entity: sensor.cost
            icon_color: deep-purple
            layout: horizontal
            card_mod:
              style: |
                ha-card {
                  margin-top: -10px;
                  margin-bottom: 0px;
                  width: 180px;
                  margin-left: 0px;
            primary: 'Depuradora: {{ states(''sensor.energy'') }} W'
            icon: mdi:home
            entity: sensor.cost
            icon_color: green
            layout: horizontal
            card_mod:
              style: |
                ha-card {
                  margin-top: -10px;
                  margin-bottom: 0px;
                  width: 180px;
                  margin-left: 0px;
            primary: 'Luces piscina: {{ states(''sensor.energy'') }} W'
            icon: mdi:home
            entity: sensor.cost
            icon_color: green
            layout: horizontal
            card_mod:
              style: |
                ha-card {
                  margin-top: -10px;
                  margin-bottom: 0px;
                  width: 180px;
                  margin-left: 0px;
  - type: custom:mini-graph-card
    entities:
      - entity: sensor.energy
        color: rgba(245,6,54,0.5)
    hours_to_show: 24
    points_per_hour: 4
    line_width: 1
    font_size: 70
    animate: true
    height: 100
    show:
      icon: false
      state: false
      extrema: false
      average: false
      legend: false
    card_mod:
      style: |
        ha-card {
          margin-top: -50px;
view_layout:
  position: sidebar
fake values for now
I love the potential of this simple add-on card, but I am finding that there are grey lines between the stacked child-cards. (See attached image.) Is there any way to get rid of them? They are quite distracting? I see them both in Firefox and Chromium. I had a look on this forum thread, but could not find an answer. Any help would be much appreciated.
mode: vertical
cards:
  - type: glance
    entities:
      - entity: sensor.living_room_temperature
      - entity: sensor.bedroom_temperature
      - entity: sensor.office_temperature
      - entity: sensor.bathroom_thp_sensor_temperature
      - entity: sensor.hallway_temperature
  - type: glance
    entities:
      - entity: sensor.calathea_monitor_soil_moisture
        icon: mdi:flower
      - entity: sensor.spider_plant_monitor_soil_moisture
        icon: mdi:flower
  - type: tile
    entity: alarm_control_panel.alarmo
  - type: tile
    entity: sensor.average_temperature
    icon: mdi:thermometer
    name: Avg. Temperature
  - type: tile
    entity: switch.adaptive_lighting_default
  - type: tile
    entity: light.living_room_light
    icon: mdi:ceiling-light
  - type: tile
    entity: light.kitchen_lights
    icon: mdi:ceiling-light-multiple
  - type: tile
    entity: light.office_light
  - type: tile
    entity: light.hallway_light
  - type: tile
    entity: switch.bedside_lamp
    icon: mdi:lamp
I think these “lines” came after 2022.11 release.
There was a PR to solve this issue (something with a new “keep border” option); do not remember if this PR was merged on not; anyway, with this or w/o this PR still I observe unsolved issues with borders (have to fix them by card-mod, see GitHub issues for details).
Hey Guys/Gals,
Having some trouble here getting rid of the lines on the bottom buttons and the border on top and shadow on the top card. Any help would be appreciated. I’m just testing to get it right before i play with the entities so don’t mind those.
Screen Shot on 2023-02-05 at 23-07-35
keep:
  box_shadow: false
  margin: false
  background: false
mode: vertical
cards:
  - type: custom:button-text-card
    styles:
      card:
        - '--keep-background': 'true'
    title: Master Bedroom
    subtitle: null
    icon: mdi:bed-king
    icon_size: 48
    large: true
    keep:
    box_shadow: true
    margin: false
    background: false
    mode: horizontal
    cards:
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
        entity: light.master_lights
        show_state: false
        icon_height: 40px
        icon: mdi:bed-king
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
        icon_height: 40px
        show_state: false
        icon: hue:room-kitchen
      - show_name: true
        show_icon: true
        type: button
        entity: fan.master_fan
        icon: mdi:ceiling-fan
        icon_height: 60px
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
        entity: light.all_lights_no_hallway
        show_state: false
        icon_height: 40px
        icon: mdi:weather-night
  1. There are some wrong indentations in your code.
  2. You got a stack inside a stack. There is a bug described on GitHub. Go to GitHub for this card → issues → find this issue → find a workaround in this issue.
Or you can also forego stack-in-card and use layout-card with even more flexibility.
I don’t need flexibility I need simplicity, the layout card seems fairly complicated.
Indeed, the layout-card is not very simple to begin with, just a suggestion to avoid the bug with stack-in-card that’s been around for quite a while now.
wouldn’t this simply be fixed by the generic
    ha-card-border-width: 0px
in the theme settings we need nowadays? (required after a change in default ha frontend settings some updates go)
