Damn, it was that easy.
thank you!
Hello, please excuse my bad english.
Can I implement this compilation with the āStack in cardā? That I only have a framework for everything?
Did you try with group: true instead of false in each mini-media-player config?
Yes, just add a single stack-in-card around your current configuration.
I have tested that out and it only groups the media players closer together within the stack, but the cards still add there transparency / colour together to end up being darker than normal (as per my screenshots above)
EDIT: thank you! that actually works, I just needed to test it on a different lovelace page due to the background image
Hi. Is there any solution for this on the horizon? All my pages in the UI consist only of stack-in-cards and therefore the layout is completely messed up (all stacks display in only one column). Even layout-card cannot fix the problem. Would be nice to know if there will be a solution some time in the future, because otherwise I have to rework my UI and get rid of the stack-in-card (which would be a shame).
Thanks!
Yes thereās a solution but I need to find some time to update the card
Iām quite busy latelyā¦
Great! Thanks for the quick reply. And take your time. Good to know that there is at least something on the horizon.
Is it possible to adjust the width on Stack-in-card ?
i place some button-card inside and i canāt adjust the width
thanks
Is anyone else seeing any issues with rounded corners? Specifically, Iām using the iOS themes pack from @basnijholt and here is what Iām seeing:
This happens everywhere Iām using a stack-in-card, but not to any of my other cards.
Hi, @RomRider!
Has there been any movement on this issue? Thanks in advance.
Sorry completely forgot about this one, let me look at it over the weekend
@RomRider, thanks! Do let us know if thereās a āBuy me a Beerā button available somewhere: I looked for one with no luck.
There is none, on purpose, but thanks for thinking about it
I am unable to stack the following entities, am I doing something wrong or is there a bug with HA 0.117.0?
- type: ācustom:stack-in-cardā
title: null
mode: vertical
cards:
- type: vertical-stack
cards:
- type: entities
entities:
- entity: sensor.daily_energy
- entity: sensor.monthly_energy
- entity: sensor.daily_gas
- entity: sensor.monthly_gas
cards:
- type: gauge
entity: sensor.power_consumption
min: 0
max: 40
Iāve just upgaded to .117 and none of my stack in cards now work.
Thanks a lot for the āstack-in-cardā, I am using it a lot in my setup.
Moved from āvertical-stack-in-cardā.
The ākeepā properties are very useful.
Only one thing which I am worried about is an āall cards are placed in one columnā issue which was already mentioned here.
New Features
- Support for async getCardSize, it should fix all cards sitting in one column.
Thank you very much, now it works & looks fantastic !
All cards seem to be placed properly.
Still doesnāt fix my problem as mentioned 2 posts earlier.
Any idea what I am doing wrong there?
Hi, I just updated to this version but it has a major breaking issues. I have a lot of nested cards, like button-cards inside a swiper card and that inside a stack-in-card, which is inside a switch-card. With the new update all nested cards inside stack-in-card are deleted. It has always worked fine, so something major has been changed with the code. I donāt really know what though.
How can I trouble shoot this and help fix it? My code is pretty complex with cards within cards, so Iām not sure what to do right now. I have cleared chache and tried different browsers and devices.
Edit: One thing I notice now with testing: when I edit my lovelace yaml to reload the dashboard everything appears again, until I refresh or close the tab. Then all those nested cards are gone again.
Edit: Though the results are mixed across my devices (what does and doesnāt get deleted) one thing is clear: everything inside a stack-in-card->swiper-card> is gone. So I think the new update doesnāt play nicely with swiper card somehowā¦
Edit: I created a Github ticket with further elaboration.
