Star Trek LCARS Theme
Hi, I’m trying to convert from Markdown to HTML-card, but I’m failing. I keep getting the error message when I use a vertical stack and a manual card.
Custom element doesn’t exist: html-card.
Custom element not found: html-card
Followed the instructions
lovelace-html-card
THX
I want to join the discord but the invite supplied by the button, when applied in Discord, says invalid or expired. Any chance of getting a new invite code?
I had a similar issue and realized it only worked over https so my interface looks like yours on localhost and looks correct when going through nobu casa.
Hey guys,
is it possible to combine several cards in a Vertical Stack with LCARS Style still applied? I like to get rid of the gap in the Vertical Bar at the right side
But when I use the Cards in a Stack I loose the LCARS style in the Backgound and also the Grid options (columns and rows)
2
I’m trying to install HA-LCARS on my LinknLink iSG Home Assistant docker container but it looks like it’s not going to work. I’ve downloaded the integration and adjusted the Configuration.yaml as specified in the README.MD. On loading a page I see in the console of the web browser that the file cards-mod.js is not found. I cannot SSH into the container and cannot install addons either (not present in the container version). I’ve listed all the .js files using the Configuration Editor integration but the cards-mod.js is nowhere to be found.
Is it at all possible to install this nice theme onto my LinknLink iSG?
does anyone have code for this image
cb-lcars_examples_dashboard-tablet_yaml_at_main_·snootched_cb-lcars·_GitHub
can’t seem to find it
I’m not sure the context of the image but it looks like a CSS mask on a progress bar like this post talks about: Lovelace: Bar Card - #867 by HadiHassaoui
Hello everyone, I started my home assistant journey a few months ago and today I started my LCARS theme dashboard, its been a learning curve but I have enjoyed every minute of it. :slight_smile:
I noticed that the invite link for the discord channel has expired, is this still around, would it be possible to get a new link?
Thanks in advance. :slight_smile:
This is the slider card from my older project CB-LCARS (custom-button-card based) which has now become LCARdS which uses lit.
This and other LCARS-style cards/systems are available to work with the HA-LCARS themes.
