Hi, just come back from holiday to find my zigbee network failed again and all my devices were unavailable. In restoring the network (restart the docker file and load backup to phoscon) I got back most devices, however when I tried to control the lights from lovelace panel I get on some lights the following error. [139802135628432] /lights/1/state unauthorized user
A similar error occurs for some groups as well. I have not changed any user settings, either in my nuc running ubuntu or home assistant as far as I know. Any suggestions as to where to look next?
Below is the full error in logs.
Logger: homeassistant.components.websocket_api.http.connection
Source: components/deconz/light.py:242
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: September 11, 2021, 23:39:21 (15 occurrences)
Last logged: 09:17:07
[139802143005952] /lights/1/state unauthorized user
[139802133687648] /lights/1/state unauthorized user
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1492, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1527, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py", line 121, in async_handle_turn_service
await asyncio.gather(*tasks)
task.result()
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 658, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 843, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 695, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 471, in async_handle_light_off_service
await light.async_turn_off(**filter_turn_off_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/deconz/light.py", line 242, in async_turn_off
await self._device.async_set_state(data)
File "/usr/local/lib/python3.9/site-packages/pydeconz/deconzdevice.py", line 42, in async_set_state
await self.async_set(field, data)
File "/usr/local/lib/python3.9/site-packages/pydeconz/api.py", line 133, in async_set
await self._request("put", field, json=data) # type: ignore
File "/usr/local/lib/python3.9/site-packages/pydeconz/gateway.py", line 116, in request
_raise_on_error(response)
File "/usr/local/lib/python3.9/site-packages/pydeconz/gateway.py", line 228, in _raise_on_error
raise_error(data["error"])
File "/usr/local/lib/python3.9/site-packages/pydeconz/errors.py", line 59, in raise_error
raise cls("{} {}".format(error["address"], error["description"]))
pydeconz.errors.Unauthorized: /lights/1/state unauthorized user
