Compact Legend is compact legend We can show state on State row, Y-axis, Tooltip or Detaied Legend. I think these are enough to show values. May be I can add Live value to Detailed Legend
without having completely studied all options of this seemingly amazing new cardâŚ
is there a function compared to apexcharts cardâs data_generator?
I have but a few of those, and some of the options in the statistics-graph-chart-card make me want to move, but I do need t be able to do stuff like this
figured it might be the attribute data source, but I cant find a real use example for that
sorry if this has been asked before (I did check and got no hitsâŚ)
love a card in actual development, and even though apexcharts card has been making my views shine in the past years, it needs some love, and attention from itâs dev.
Thank you for your reply.
Following your example on the gradient it just changes the background color of the card. What I would love to be able to do is change the opacity of the gradient. Below is a Statistics Graph Card compared to an Apex charts, and I would like the gradient to look more like the Apex Charts card, so less intense gradient.
Iâm trying to do what you are doing and replicate my Apex Charts (seen below). But I (mainly ChatGPT :)) getâs lost over two things:
The official Nordpool integration holding the electrical prices shows the price for each quarter. That gets a bit messy and with Apex I have aggregated it and combined 4 quarters to 1 hour to make it a bit prettier. Iâm not able to do so in SGCC. group_by: hour doesnât seem to work.
Feels like Iâm close to replicate the Apex chart but just missing out on the final tweaks
Hi I will try to help you with this but can you also look the link below? Maybe you can find similar issues or yaml samples. I do not have Nord Pool integration so It can take some time to help you.
yeah I feel you.
have the same with the compression of my graphs that happened after adding the secondary entity.
what I did was start with as basic as possible a config in the UI, and then clicked around in the optionsâŚ
the documentation is still a puzzle for me, it didnt open the main options to me like I am used to. (Even though the huge list of screenshots of all possible graphs is impressive, it doesnât help the clarity there to me).
I got lost soon, so turned to the UI, then copied yaml for my regular dashboard
Also, I found that the terminology from apexcharts is not always âuniversalâ and things like span etc are different in this card. so not knowing what to look for as a non graph expert didnât help me either. turned out that some options were the same as with mini-graph-card or stock cards. the latter being super of course. always helpful calling the same thing the same name!
just getting to know the beast (it most definitely is a beast of a card) will take me a bit more time
A quick note to say I am loving this card. I have been able to transition all my graphs from Apexcharts to SGCC.
An example of my temp/dewpoint graph. I used to not show humidity as it is inferred by the gap between dewpoint and temperature. But with SGCC and the neat thresholds etc, I can show it with an independent axis with hard max at 1500 so it is a nice visual band at the bottom. When looking over 7d it really highlights high humidity etc.
