Hi, I’m working on a project to automate some window roller shades. I’m essentially doing something very similar to this: roller blind connected to NEMA 17 stepper motor, driven by a TMC2209 driver, with a solenoid and ratchet mechanism to prevent the shade from falling when the motor is not energized.
However, instead of an Arduino in the above example, I’d like to use a D1 Mini with ESPHome so I can integrate into Home Assistant. I’ve basically got this up and running with one problem: when I include the solenoid output in my yaml code, it causes the stepper motor to stutter while running. When the solenoid is not included in the yaml code, it runs smoothly and everything is as expected.
So, I have a few theories on what might be happening:
- Calling the
wait_untilaction is introducing an added delay at odd intervals (note that I needed to include this because it seems like the actions within the cover are non-blocking: withoutwait_until, the solenoid would switch on, the motor would start turning, then the solenoid would immediately switch off - before the motor finished its movement.) - I am terrible at selecting hardware and the D1 mini is underpowered for this application, so it can’t handle the solenoid and stepper motor at the same time.
- Something else.
My first thought was that (1) was the problem, and I would need to build my own custom external component for this application. But being a mouth-breathing dunce with very limited coding skills, I didn’t want to waste a bunch of time trying to figure out external components if the problem is actually (2) or (3).
Does anyone have any insights into what might cause this? Please find my yaml code and wiring diagram attached below.
Thank you in advance!
substitutions:
friendly_name: Living Room Left Blackout Shade
devicename: living_room_left_blackout_shade
height: '16000'
speed: '2000'
accel: '1000'
esphome:
friendly_name: ${friendly_name}
name_add_mac_suffix: false
project:
version: '1.0'
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
ssid: !secret wifi_ssid
# Set up a wifi access point
ap:
ssid: "ssid"
password: "password"
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
package_import_url: github://esphome/example-configs/esphome-web/esp8266.yaml@main
import_full_config: true
# To have a "next url" for improv serial
web_server:
cover:
device_class: blind
open_action:
then:
- switch.turn_on: solenoid
- stepper.set_target:
target: ${height}
- sensor.template.publish:
state: !lambda return id(my_stepper).target_position;
- wait_until:
condition:
- lambda: |-
return id(my_stepper).current_position == id(my_stepper).target_position;
timeout: 30s
- switch.turn_off: solenoid
close_action:
then:
target: '0'
- wait_until:
condition:
- lambda: |-
timeout: 30s
stop_action:
- then:
toggle_action:
then:
- if:
condition:
- lambda: |-
return id(my_stepper).current_position == 0;
then:
target: ${height}
- wait_until:
condition:
- lambda: |-
timeout: 30s
else:
target: '0'
- wait_until:
condition:
- lambda: |-
timeout: 30s
position_action:
- then:
assumed_state: true
has_position: true
name: "Living Room Left Blackout Shade Position"
binary_sensor:
- platform: gpio
name: "Living Room Left Blackout Shade Manual Toggle"
pin: GPIO12
on_release:
then:
- cover.toggle: living_room_left_blackout_shade
switch:
- platform: gpio
pin: GPIO13
stepper:
- platform: a4988
step_pin: GPIO14
dir_pin: GPIO4
sleep_pin:
number: GPIO5
inverted: true
max_speed: ${speed}
acceleration: ${accel}
deceleration: ${accel}
