I have a door I monitor when opened. How can suspend a notification for a period of time after it is opened for occasions where we are going in and out of the door. For instance, suspending the trigger for 30 minutes.
holler if you need help.
by the way, i’d encourage you to use friendly named entity_id’s for your automation an not use device id’s and device triggers.
here’s more depth into why:
but your automation should get much simpler if you do that, and more readable:
