Strange ESP-32 behavior
Problem: The ESP32 with allied relay shows as “unavailable” on the desktop. There is no entry for the ESP32 on my router/Wi-Fi. It does show up as a WAN connection!! Yet, it is not plugged into the WAN, nor has it ever been.
The ESP32 is shown as “offline” in ESPHome.
I believe this happened coincidentally with my upgrade yesterday of the HA Core.
Question 1: Could this show up on the WAN because it is connected via Bluetooth to HA?
Question 2: How might I troubleshoot the unavailable relay (which operates my heating boiler)?
Here is my setup on RPi 5, 8 GB, 250 GB USB Sata SSD:
  • Core: 2024.11.2
  • Supervisor: 2024.11.3
  • Operating System: 13.2
  • Frontend: 20241106.
  • ESP32: DoIt ESP32 (ESP32 WROOM)
YAML for ESP32
  friendly_name: ESP3201
esphome:
  friendly_name: ${friendly_name}
  min_version: 2024.6.0
  name_add_mac_suffix: false
  project:
    version: '1.0'
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
  # Set up a wifi access point
  ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
  package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
  import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
  authorizer: none
# To have a "next url" for improv serial
web_server:
switch:
  - platform: gpio
    pin: GPIO19
uart:
  tx_pin: GPIO17
  rx_pin: GPIO16
  baud_rate: 9600
Logs
So you have configured no wifi credentials. This in conjunction with captive_portal: means that you need to connect to the access point network created by the ESP to configure your wifi credentials. Have you done this?
