Stream component and RasPi camera
just saw the stream component is here - great thing.
Anyone already managed to show the picture and/or stream from a RasPi camera (attached to the system running hass.io on)?
Hints would be useful surely not only for myself…
Thanks in advance!
/ Ralf
I think if you can get the RTSP URL you should try it with the generic camera, is this an attached camera? You may need to use motion eye or something if its attached as you need the RTSP server for this to work.
MotionEye does not suport RTSP streaming only HTTP MJPEG.
You can read my post about how a “different” way to do it
If it gives an H264 URL like blue iris then it should work actually :slight_smile: might be worth a shot if you can find it
