Do you mean that you sensor did not have exactly same states?
Asking because your posted code SEEMS to be ok.
I needed to combine 2 sensors - Time of Day and Season. The suns position is very different in the seasons so I wanted the images to reflect that.
@Ildar_Gabdullin I have a question that you may help me with.
Can I have conditional images displayed? For example:
Light Entity 1 on - Display Image 1
Light Entity 2 on - Display Image 2
Light Entities 1&2 on - Display Image 3
Is that possible? If so what could the code look like?
Hey @Ildar_Gabdullin
I have a question for you.
My current issue is that Iām using both the mobile app and a desktop browser to view my dashboards but the scale and position of the badges isnāt dynamically set with the size of the background image being displayed.
Do you know if there is a way to dynamically adjust the position and scale so that it remains in the correct spot?
Thanks in advance
- Suggest you to close the issue you opened in Github.
- Tagging people is not appreciated in Community, please avoid it.
- Please open the 1st post of this thread & check 3 links about āpositioningā.
Thanks for your comment, but "switch.r21, -.r22, etc.) are created so that only one can be āonā at a time, so this is not a problem.
You got me thinking about my hot water system. Oh that rabbit hole.
Anyway I found after a few different tests the picture itself determines the size. Now I am not sure which one I am sticking withā¦
Any idea how i should do a fireplace?
I have a top view on the floorplan
I would like to have the fireplace light the environment but flicker like a real fire
I can use a gif, but u wont see that from the top⦠and i wont see light flicker.
Maybe someone have an idea?
Iām hoping someone can help.
Iām looking to use picture-elements to track Solar Panel performance. Iād like to set the background-color alpha-channel to a value derived from the entity state.
I know I am doing this wrong, but havenāt been able to figure out the right way.
type: picture-elements
image: https://mySite/local/RoofOutline.png
title: Roof
elements:
- type: image
entity: sensor.panel_a1_power
image: https://andyland.duckdns.org/local/panel.png
style:
top: 47%
left: 75%
top: 21%
left: 42%
width: 6%
transform: translate(0%, 0%)
background-color: rgba(255,0,0,."$ states('sensor.panel_a1_power')|int/255)")
And of course that doesnāt work. background-color is ignored.
What is the correct way to get a state-value into the CSS ?
1st post ā conditional styles
How is this related to picture elements? Are you talking about css inside picture elements only?
I have a question that someone may be able to help me with.
- type: image
style:
left: 50%
top: 50%
width: 100%
state_image:
"on": local/Floorplan/Facade.png
"off": local/Floorplan/Transparent.png
entity: light.front_facade
- type: image
style:
left: 50%
top: 50%
width: 100%
state_image:
"on": local/Floorplan/Columns.png
entity: light.outside_columns
- type: image
style:
left: 50%
top: 50%
width: 100%
state_image:
"on": local/Floorplan/FrontTerrace.png
entity: light.outside_entrance
- type: image
style:
left: 50%
top: 50%
width: 100%
state_image:
"on": local/Floorplan/ColumnFacade.png
entity: light.floorplan_outside_front_cf
- type: image
style:
left: 50%
top: 50%
width: 100%
state_image:
"on": local/Floorplan/ColumnTerrace.png
entity: light.floorplan_outside_front_ct
- type: image
style:
left: 50%
top: 50%
width: 100%
state_image:
"on": local/Floorplan/OutsideFrontAll.png
entity: light.floorplan_outside_front_all
- type: image
style:
left: 50%
top: 50%
width: 100%
So I have 3 sets of lights
Column, Terrace and Facade
I have created renders for each as and all combinations as you can see in the code.
The problem is as the codes stands, and all the lights on it layers the image which is fine but transparency upon transparency upon transparency renders the image black in the areas where there are no lights.
Is it possible to use a condition?
Well, the approach is good - use āimageā element with āstate-imageā.
As for
not completely getting this: transparent png + transparent png = transparent.
Unless ātransparentā is not really transparentā¦
Hi, please I need your help. Haveing problems to rotate an object in my project I try to at list to recreate your example with the arrow but stil not working and I do not know where is the problem.
I verified if the themplate is working as yo mentionet before
{% set ANGLE = states(āinput_number.random_angleā) | float |
round(0) %} {{ANGLE}}deg
Ths is dhe code, the arrow stil not moveing:
- type: vertical-stack
cards:
- type: entities
entities:
- entity: input_number.random_angle
secondary_info: entity-id
- type: picture-elements
image: /api/image/serve/9400d0a88cef22e4c59b05ea073f67e9/512x512
elements:
- type: icon
icon: mdi:arrow-up-thin
style:
top: 18%
color: orange
left: 20%
rotate: >
float | round(0) %} {{ANGLE}}deg
Please I need your help what do I do wrong?
Please post your code using the forum standard. Using the preformatted text option makes testing your code a lot easier.
this is your code with my working template
cards:
- type: entities
entities:
elements:
- type: icon
style:
top: 18%
color: orange
left: 20%
rotate: >
{% set ANGLE = states('input_number.random_angle') | float |
thanks was my first post ever
No worries, just a little bit of advice to help ensure you get a resolution. Iāll take a look, but either way, Ildar or myself will reply.
Test thisā¦
cards:
- type: entities
entities:
card_mod:
style: |
ha-card {
{% set ANGLE = states('input_number.random_angle') + 'deg' %}
--rotate: rotate({{ANGLE}});
elements:
- type: icon
style:
top: 18%
color: orange
left: 60%
transform: var(--rotate)
Thank you thank you very very much is working
