In the ESPHome integration, one of the neat feature was the ability to use “substitutions”, which allowed me to write reusable code with the ability to change parameters and not touch the actual code. Here is one such example:
Not really, the substitutions are more local (specific to a single configuration file) and just provide an easy way to reuse a working configuration and manage it.
The example I quoted above has been used 6+ time as I have multiple boards in my alarm system. For each new board, I don’t have to tinker the code and only need to change few logical values in the “substitutions” block.
Thanks for updating and yes the substitution feature started working and I’ve been using it for a while and it has made life a lot easier. Here is the re-work of inital code I posted in 2021!
#The substitution block has all the configurable details
substitutions:
name_of_board: alarm-a
ota_password: !secret ota_alarm_A
api_password: !secret alarm_A_api_password
api_encryption_key: !secret alarm_A_api_encryption_key
device_class_type: "window"
name_1: "Window-A1"
name_2: "Window-A2"
name_5: "Window-A5"
name_6: "Window-A6"
name_7: "Window-A7"
name_RX: "Window-A8"
name_9: "Window-A9"
name_10: "Window-A10"
internal_1: "false"
internal_2: "false"
internal_5: "false"
internal_6: "false"
internal_7: "false"
internal_RX: "true"
internal_9: "true"
internal_10: "false"
ip_address: !secret ip_address_alarm_A
#YOU SHOULD NOT NEED TO EDIT BELOW THIS LINE
packages:
wifi_settings: !include common/basic_components.yaml
basics: !include common/basic_sensors.yaml
device_settings: !include common/nodemcu.yaml
Just want to ping this thread again in case I am missing some new feature that allows substitutions in HA YAML files. Coming from ESPHome, I too miss the ability to use the substitution definition to create essentially as set of variables to be used in that YAML file.
I’ve been slowly moving things from my configuration.yaml into the packages directory and would love to be able to create a template of sorts like we can in ESPHome and then just change the substitution data to reuse that code. Otherwise, copying a configuration requires find and replace, which is error prone.
But that means I also have to repeat the whole script part in the config? I’m a bit confused what the difference is then between just giving a different value to brightness and using the substitution value?
I assume the full (M5Stack Atom) config is somewhere deep in the ESPhome add-on which I cannot acces and the config I provide only sets the deltas.
Then you can create multiple instances of light devices (with unique names) such as “light-01.yaml” as follows:
substitutions:
brightness_level: 100 # put whatever number you want here
packages:
setup: !include light_set_up.yaml
So if you have 10 lights, you only need to write this code once and just pass value to each light.
If you are trying to use this script as a means to change the value of brightness when operating the lights, it will not work because each light in the above code will have a hard coded value for brightness. If you are trying to control the brightness of this light from HA then you may also want to use this:
You should look at “field” and “variables” that I’ve started using in my scripts. It is not quiet “substitution” but fairly efficient and useful in maintenance of code base.
Here is one example where I have a dashboard of toggles that can be turned on/off for creating a dynamic notification recipient list.
HTH
dynamic_email_opt_in:
alias: Dynamically opt in for notifications
mode: single
fields:
dynamic_opt_in_event:
required: true
variables:
a: !secret pankaj_email
b: !secret pankaj_cell
default_recepient: !secret pankaj_email
users:
- !secret pankaj_cell
- !secret pankaj_email
dishwasher:
- input_boolean.pankaj_email_dishwasher
- input_boolean.pankaj_sms_dishwasher
laundry_washer:
- input_boolean.pankaj_email_laundry_washer
- input_boolean.pankaj_sms_laundry_washer
laundry_dryer:
- input_boolean.pankaj_email_laundry_dryer
- input_boolean.pankaj_sms_laundry_dryer
mapper:
input_boolean.pankaj_email_dishwasher: "{{ a }}"
input_boolean.pankaj_email_laundry_dryer: "{{ a }}"
input_boolean.pankaj_email_laundry_washer: "{{ a }}"
input_boolean.pankaj_sms_dishwasher: "{{ b }}"
input_boolean.pankaj_sms_laundry_washer: "{{ b }}"
input_boolean.pankaj_sms_laundry_dryer: "{{ b }}"
targets: |
{% if ( dynamic_opt_in_event == "dishwasher") %}
{% set ns = namespace( emails=[] ) %}
{% set bools = dishwasher | select('is_state', 'on') | list %}
{% for my_bool in bools %}
{% set ns.emails = ns.emails + [ mapper.get(my_bool) ]%}
{% endfor %}{{ ns.emails }}
{% else %}
{{default_recepient}}
{% endif %}
sequence:
- service: notify.smtp_1_gmail
title: Dynamic opt-in list
message: "Test-else-2"
target: "{{ targets }}"
