Is anyone aware of a plugin/intergration for sungrow inverters? I am looking at one of these or the Fronius.
Thanks!
Thanks!
I’ve been using https://github.com/meltaxa/solariot
Took a bit to set up, and still need to work out how to have it auto starting on hassio instead of using the telnet/ssh plugin to get it going. But it does the trick.
Sungrow inverter
I havent been able to get SolarIOT going since the inverter firmware upgrade - I should try again
I decided to go with; https://www.home-assistant.io/integrations/fronius/ in the end
Yea should have gone for a fronius as well
There seems to be an increasing demand for Sungrow integration as it’s also one of the last major brands to be supported, especially now that SolarIOT etc has broken the encryption. Is someone perhaps able to make a HAC integration perhaps? The new Energy integration in HA would be fantastic to get working!
I wasn’t able to make fronius work with SunGrow, the Device I have is: SG6K-D.
Is there any tutorial or can anyone share an example of the config they have?
Thanks!
That’s not compatible. I think the OT went for a different inverter manufacturer, not a different integration for Sungrow inverters.
I’ve manged to get meltaxa/solariot working and can publish the data to MQTT or influxdb. Anyone successful in getting the data into the native Energy section of Home Assistant? If so, can you share how?
Thanks!
I’m using this which is based on SolarIoT (needs HA Supervised + MQTT) - creates sensors automatically that directly plug in to the energy dashboard
What I ended up doing is buying the Emporia Vue (I wanted this for a while), for energy monitoring on all my home circuits. Works like a charm and took a couple of minutes only to install, setup and see it in action.
This is awesome. I have been searching for a way to get info out of my Sungrow inverter (SG8K-D) and this looks to be working. Sorry if this is a newbie question, but how do I see the info that the ModbusTCP2MQTT extracts. I can see it getting info from the inverter in the log, but how do I add that to a dashboard??
hi,
I am new to Home Assistant and created my .yaml Modbus integration for my Sungrow SGH10.RT. Most of the stuff works now, after I asked the support to send me a modbus register map (which they really did after 3 days yeah).
In the datasheet there are some differences between sungrow models. But most of the registers are the same, so it should also work with SG* models
btw. I don’t know yet, where I should paste code like this in this forum. This is why I hijack this thread, as it was the only thread the search function returned searching for “sungrow”
So here is my current code. Feel free to ask / criticize
modbus:
- name: SungrowSH10 adapt this!
type: tcp
host: 192.168.178.20 adapt this!
port: 502 adapt this!
# retry_on_empty : true
# retries: 10
# close_comm_on_error: true
#delay: 5
#timeout: 5
sensors:
- name: Daily PV generation & battery discharge
slave: 100 adapt this and following slave addresses!
address: 5002
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
unit_of_measurement: kWh
device_class: energy
state_class: total_increasing
scale: 0.1
scan_interval: 10
- name: Total PV generation & battery discharge
slave: 100
address: 5003
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Inverter temperature
slave: 100
address: 5007
input_type: input
count: 1
data_type: int16
precision: 1
unit_of_measurement: °C
device_class: Temperature
scale: 0.1
scan_interval: 10
- name: MPPT1 voltage
slave: 100
address: 5010
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
unit_of_measurement: V
device_class: Voltage
scale: 0.1
scan_interval: 10
- name: MPPT1 current
slave: 100
address: 5011
input_type: input
count: 1
data_type: uint16
swap: word
precision: 2
unit_of_measurement: A
device_class: Current
scale: 0.1
scan_interval: 10
- name: MPPT2 voltage
slave: 100
address: 5012
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: MPPT2 current
slave: 100
address: 5013
input_type: input
count: 1
data_type: uint16
swap: word
precision: 2
scale: 0.1
scan_interval: 10
- name: Total DC power
slave: 100
address: 5016
input_type: input
count: 2
data_type: uint32
swap: word
precision: 0
unit_of_measurement: W
device_class: power
state_class: measurement
scale: 1
scan_interval: 10
- name: Reactive power
slave: 100
address: 5032
input_type: input
count: 2
data_type: int32
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
- name: Power factor
slave: 100
address: 5034
input_type: input
count: 1
data_type: int16
swap: word
precision: 3
unit_of_measurement: "%"
device_class: power_factor
scale: 0.001
scan_interval: 10
- name: System state
slave: 100
address: 12999
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 1
scan_interval: 10
- name: Running state
slave: 100
address: 13000
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 1
scan_interval: 10
slave: 100
address: 13001
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
slave: 100
address: 13002
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Daily exported energy from PV
slave: 100
address: 13004
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Total exported energy from PV
slave: 100
address: 13005
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Load power
slave: 100
address: 13007
input_type: input
count: 2
data_type: int32
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
- name: Export power
slave: 100
address: 13009
input_type: input
count: 2
data_type: int32
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
- name: Daily battery charge from PV
slave: 100
address: 13011
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Total battery charge from PV
slave: 100
address: 13012
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Daily direct energy consumption
slave: 100
address: 13016
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Total direct energy consumption
slave: 100
address: 13017
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Battery voltage
slave: 100
address: 13019
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 0.1
scan_interval: 10
- name: Battery current
slave: 100
address: 13020
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Battery power
slave: 100
address: 13021
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
- name: Battery level
slave: 100
address: 13022
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
device_class: battery
scale: 0.1
scan_interval: 10
- name: Battery state of health
slave: 100
address: 13023
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Battery temperature
slave: 100
address: 13024
input_type: input
count: 1
data_type: int16
precision: 1
scale: 0.1
scan_interval: 10
- name: Daily battery discharge
slave: 100
address: 13025
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Total battery discharge
slave: 100
address: 13026
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Grid state
slave: 100
address: 13029
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Total active power
slave: 100
address: 13033
input_type: input
count: 2
data_type: int32
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
- name: Daily imported energy
slave: 100
address: 13035
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Total imported energy
slave: 100
address: 13036
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 10
slave: 100
address: 13039
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
slave: 100
address: 13040
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 10
slave: 100
address: 13044
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
slave: 100
address: 13045
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Charge discharge power
slave: 100
address: 13051
input_type: input
count: 1
data_type: int16
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
slave: 100
address: 13108
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 1
scan_interval: 10
slave: 100
address: 13109
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 1
scan_interval: 10
binary_sensor:
sensors:
battery_charging:
friendly_name: "Battery charging"
value_template: "{{ states('sensor.running_state')|int|bitwise_and(1) > 0 }}"
battery_discharging:
friendly_name: "Battery discharging"
value_template: "{{ states('sensor.running_state')|int|bitwise_and(2) > 0 }}"
exporting_power:
friendly_name: "Exporting power"
value_template: "{{ states('sensor.running_state')|int|bitwise_and(4) > 0 }}"
importing_power:
friendly_name: "Importing power"
value_template: "{{ states('sensor.running_state')|int|bitwise_and(5) > 0 }}"
minor fixes… Should I open a new thread for this? (When yes: in the “3rd Party integration” section?)
modbus:
- name: SungrowSH10
type: tcp
port: 502
# retries: 10
#delay: 5
#timeout: 5
sensors:
slave: 100
address: 5002
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 5003
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 5007
input_type: input
count: 1
data_type: int16
precision: 1
scale: 0.1
scan_interval: 10
slave: 100
address: 5010
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
slave: 100
address: 5011
input_type: input
count: 1
data_type: uint16
swap: word
precision: 2
scale: 0.1
scan_interval: 10
slave: 100
address: 5012
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
slave: 100
address: 5013
input_type: input
count: 1
data_type: uint16
swap: word
precision: 2
scale: 0.1
scan_interval: 10
slave: 100
address: 5016
input_type: input
count: 2
data_type: uint32
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
slave: 100
address: 5032
input_type: input
count: 2
data_type: int32
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
slave: 100
address: 5034
input_type: input
count: 1
data_type: int16
swap: word
precision: 3
scale: 0.001
scan_interval: 10
slave: 100
address: 12999
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 1
scan_interval: 10
slave: 100
address: 13000
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 1
scan_interval: 10
slave: 100
address: 13001
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13002
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13004
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13005
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 600
- name: Load power
slave: 100
address: 13007
input_type: input
count: 2
data_type: int32
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
slave: 100
address: 13009
input_type: input
count: 2
data_type: int32
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
slave: 100
address: 13011
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13012
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13016
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13017
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13019
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 0.1
scan_interval: 10
slave: 100
address: 13020
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 10
slave: 100
address: 13021
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
slave: 100
address: 13022
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 60
slave: 100
address: 13023
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 0.1
scan_interval: 10
slave: 100
address: 13024
input_type: input
count: 1
data_type: int16
precision: 1
scale: 0.1
scan_interval: 60
slave: 100
address: 13025
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13026
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 10
- name: Grid state
slave: 100
address: 13029
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 0.1
scan_interval: 10
slave: 100
address: 13033
input_type: input
count: 2
data_type: int32
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
slave: 100
address: 13035
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13036
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13039
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13040
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13044
input_type: input
count: 1
data_type: uint16
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13045
input_type: input
count: 2
data_type: uint32
swap: word
precision: 1
scale: 0.1
scan_interval: 600
slave: 100
address: 13051
input_type: input
count: 1
data_type: int16
swap: word
precision: 0
device_class: power
scale: 1
scan_interval: 10
slave: 100
address: 13108
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 1
scan_interval: 10
slave: 100
address: 13109
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 1
scan_interval: 10
##defect
- name: Battery cycle count
slave: 100
address: 13110
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 1
scan_interval: 600
##defect
- name: Battery max cell voltage
slave: 100
address: 13112
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 1
scan_interval: 10
##defect
- name: Battery min cell voltage
slave: 100
address: 13113
input_type: input
count: 1
data_type: uint16
swap: word
precision: 0
scale: 1
scan_interval: 10
binary_sensor:
sensors:
pv_generating:
friendly_name: "PV generating"
value_template: "{{ states('sensor.running_state')|int|bitwise_and(0x1) > 0 }}"
battery_charging:
value_template: "{{ states('sensor.running_state')|int|bitwise_and(0x2) > 0 }}"
value_template: "{{ states('sensor.running_state')|int|bitwise_and(0x4) > 0 }}"
exporting_power:
value_template: "{{ states('sensor.running_state')|int|bitwise_and(0x10) > 0 }}"
importing_power:
value_template: "{{ states('sensor.running_state')|int|bitwise_and(0x20) > 0 }}"
Sorry mate, could you explain a but more? I was going to set up a separate Hassio to install GitHub - TenySmart/ModbusTCP2MQTT: Sungrow & SMA Solar Inverter addon for Home Assistant using mobusTCP on (as I have mine running on normal docker) but it seems you actually have got this working directly? I’ve got a SG5K with a V31 WiFi comm device.
Hi all,
Have have put together a solution for Sungrow Hybrid Inverters at the moment refer to the link below to see if your inverter is supported.
Those that are after the modbus register addresses (official) have uploaded the pdf for String & Hybrid inverters to the python module site which has been developed as part of this solution (SungrowInverter · PyPI).
You will be able to see what String Inverters can be supported once I’ve completed development, at that site. Let me know if this interests you, otherwise i wont bother as I don’t require it.
Please be aware if you use this at present there is a possibility sensor names will be changed, I’ll try limit that as much as possible though.
Let me know how you go. if you are unsure of installing custom integrations in into ~/config/custom_components then this solution may not be for you. I’ll see how time goes for a proper Hass.io solution as thats what i use these days as well, need to teach myself how that works though.
Cheers
Mark
Sounds good. When I move into my new house (7/12) I’ll have a go and update you
I just created a github repro with my current work and started a new thread:
Then I saw mvandersteen 's work, which looks way better and probably makes my stuff more or less superseeded. ![]()
I hope to find some time the next days to check your custom component with my SH10.RT and look for something I can contribute.
~Martin
This looks great, @mvandersteen, thanks for your work. I have installed the component, but have an SG5K-D inverter (no battery) and it doesn’t sound like you’ve added support for this yet. I haven’t done much work on modbus etc in the past, but if there’s code you’d like me to test for this model, let me know.
@simon4 i’ll make the change to suite SGxx inverter soon seeing as there is a need.
@mkai I’ll check your solution as well there maybe something I’ve missed, I have noticed that all those inverters you have mentioned do support the same set of registers, some inverters (like mine SH5K) just don’t record anything to all of them, also I got a lot of fixing up to do yet. Any help or advise will be taken
