Yes, but your indentation is wrong on the lock.another_door
. It should be directly under the first lock, not indented.
Go to developer tools and then Services and type in notify
and see what pops up. It will bring up the available notify services that you have set up. It’s been so long since I set it up, I’m not sure if there is something else you need to do on the mobile app to set it up. Googling will help you on this one, as this isn’t a keymaster specific thing. It doesn’t need to be two, it can be as many as you want. It is who you want to send the notifications to.
You want a separate dashboard, or another tab? I just made it as another tab, but it shouldn’t matter.
Do you have this in your configuration file?
homeassistant:
packages: !include_dir_named packages
Have you restarted Home Assistant?
kaws
March 10, 2024, 9:36pm
23
The formatting is correct, I tried to make the parts I changed in bold but it didn’t format correctly on here.
I will double check but I am sure I added the packages code to my configuration. I will take a screenshot later.
I did restart HA
Do I have to install Keymaster through HACS?
No, you don’t want KeyMaster on there at all. We do need to install the key master basic code and put that in your packages directory.
kaws
March 10, 2024, 10:07pm
25
key master basic code = keymaster_basic.yaml?
kaws
March 10, 2024, 11:00pm
27
It seems I am using the wrong entity IDs since I can confused as to what entity IDs I am supposed to use.
Update Oct 15
the problem was the home_locks group entity IDs. I assumed (novice!) that i could use the entity names as the entity IDs. Oops
# Add your locks here
lock:
- platform: group
entities:
- lock.node_12 #FrontDoor
- lock.assure_lever_keypad_with_z_wave_plus #GarageDoor
- lock.assure_touchscreen_deadbolt #OfficeDoor
Do I find the entity IDs under Zwave JS UI?
I have always used this
Settings-> Devices & Services → Entities
kaws
March 23, 2024, 11:03am
28
I have no clue what I am doing wrong.
Make sure I had the correct line in my configuration yaml
Downloaded the raw keymaster_basic.yaml to make sure I did not miss anything.
Uploaded the raw yaml into the directory
Went to setting->entities. Found my lock. Copied the entity ID and replaced
I have not changed the notify lines in keymaster_basic.yaml yet (I have to find out what mine are called). But this shouldn’t affect anything?
Copied everything from lovelace-keymaster-basic.yaml without changing anything
Have you restarted? Wouldn’t hurt to figure out the notify
part. Just go to Developer Tools and then Services and type notify.
and see what comes up.
kaws
March 24, 2024, 1:22am
30
I have restarted. I’ll edit the notify part and see if anything changes.
I will be very surprised if that is why it is not working for me.
kaws
March 24, 2024, 3:35am
31
Nope, still not working. I have no idea why at this point.
This was the fix for me: add the packages under homeassistant header in configuration.yaml, save, restart Home Assistant.
homeassistant:
packages: !include_dir_merge_named packages/
kaws
April 2, 2024, 3:36am
33
I’m trying to under why it would make a difference by reading this documentation but it will take me a while to process it. Packages - Home Assistant
I’ll definitely give it a try when I have a chance! Thanks!
This integration seems like the ticket. Any desire to get into HACS?
