Supervised installation os agent version
Im running HA in a supervised installation on RPi 4 4GB for quite some time now. The original install was on Debian Buster and got upgraded to Bullseye meanwhile.
HA Version: 2022.10.3
Supervisor: 2022.10.0
OS-Agent: 1.2.1
I noticed My OS Agent version is really old and therefore my question: Is it safe to update it to the newest version and, if yes, how could I do it?
That has info on how to make a notification for os-agent.
To actually update it, from your host console…
You need to
Wget the_os-agent_file_that_matches_your_hardware
Then
dpkg -i that_file_matching_your_hardware
Technically you are unsupported if it is out of date according to the requirements docs…
It’s always safe to re run the supervised installer. Doesnt that fix it? If not might be a bug.
Don’t think the installer does os-agent.
It certainly hasn’t in the past.
Hm well it lists it as a dependency so I feel like it should?
But maybe it won’t update it after install? Either ways seems like an issue since it is a listed dependency
Step 3 lists it as a separate install step
supervised-installer
That explains it! Should’ve checked there first
On my amd64 install it has always been safe to simply download the latest deb and install it.
Thank you. I installed it manually and after reboot HA reports V1.4.1.
