Supervisor error after upgrade to supervisor-2021.02.5
I’m desperate! I’ve just installed supervisor-2021.02.5 and I now can’t access any add-ons, I get an error even when restarting my Raspberry Pi. Why does this happen? how can I fix it?
here’s what I’m seeing when trying to access any add-on:
and I’m getting the following logs:
21-02-08 12:18:34 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of Network UPS Tools
21-02-08 12:18:34 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of Network UPS Tools
21-02-08 12:18:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
21-02-08 12:18:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/7ad98f9c repository
21-02-08 12:18:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/6e66619d repository
21-02-08 12:18:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/cebe7a76 repository
21-02-08 12:18:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/15d21743 repository
21-02-08 12:18:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of Z-Wave JS
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of deCONZ
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of deCONZ
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of HomeMatic CCU
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of OpenZWave
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of TellStick
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of Terminal & SSH
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of Zigbee2mqtt Edge
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of Z-Wave JS to MQTT
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of Visual Studio Code
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of WireGuard
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of AppDaemon 4
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of Node-RED
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of Node-RED
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of ESPHome
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of Z-Wave to MQTT
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of ZeroTier One
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of SSH & Web Terminal
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of SSH & Web Terminal
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of Network UPS Tools
21-02-08 12:18:35 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of Network UPS Tools
21-02-08 12:18:35 INFO (MainThread) [supervisor.store] Loading add-ons from store: 71 all - 71 new - 0 remove
21-02-08 12:18:35 INFO (MainThread) [supervisor.addons] Found 15 installed add-ons
21-02-08 12:18:35 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-mariadb with version 2.2.1
21-02-08 12:18:35 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to sabeechen/hassio-google-drive-backup-armv7 with version 0.103.1
21-02-08 12:18:35 INFO (SyncWorker_6) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-ssh with version 9.0.0
21-02-08 12:18:35 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/node-red/armv7 with version 8.1.0
21-02-08 12:18:35 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-duckdns with version 1.12.4
21-02-08 12:18:35 INFO (SyncWorker_7) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-check_config with version 3.6.0
21-02-08 12:18:35 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-configurator with version 5.2.0
21-02-08 12:18:35 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/zerotier/armv7 with version 0.10.1
21-02-08 12:18:35 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/bookstack/armv7 with version 0.8.2
21-02-08 12:18:35 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-cec_scan with version 2.4
21-02-08 12:18:35 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/influxdb/armv7 with version 4.0.1
21-02-08 12:18:35 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/ftp/armv7 with version 4.0.0
21-02-08 12:18:35 INFO (SyncWorker_7) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/nginxproxymanager/armv7 with version 0.9.0
21-02-08 12:18:35 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-mosquitto with version 5.1
21-02-08 12:18:35 INFO (SyncWorker_6) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-zwave_js with version 0.1.4
21-02-08 12:18:35 INFO (MainThread) [supervisor.snapshots] Found 5 snapshot files
21-02-08 12:18:35 INFO (MainThread) [supervisor.discovery] Loaded 2 messages
21-02-08 12:18:35 INFO (MainThread) [supervisor.ingress] Loaded 1 ingress sessions
21-02-08 12:18:35 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-02-08 12:18:35 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-02-08 12:18:35 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-02-08 12:18:36 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-02-08 12:18:36 INFO (MainThread) [__main__] Running Supervisor
21-02-08 12:18:36 INFO (MainThread) [supervisor.hassos] Rauc: B - marked slot kernel.1 as good
21-02-08 12:18:36 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-02-08 12:18:36 INFO (MainThread) [supervisor.core] Supervisor reboot detected
21-02-08 12:18:36 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-02-08 12:18:36 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-02-08 12:18:36 INFO (MainThread) [supervisor.host.info] Updating local host information
21-02-08 12:18:36 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-02-08 12:18:36 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-02-08 12:18:36 INFO (MainThread) [supervisor.host.services] Updating service information
21-02-08 12:18:36 INFO (MainThread) [supervisor.host.network] Updating local network information
21-02-08 12:18:37 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-02-08 12:18:37 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
21-02-08 12:18:37 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
21-02-08 12:18:37 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
21-02-08 12:18:39 INFO (MainThread) [supervisor.host] Host information reload completed
21-02-08 12:19:20 INFO (SyncWorker_4) [supervisor.docker.interface] Restarting homeassistant/raspberrypi4-homeassistant
21-02-08 12:19:21 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:1000 is not str
21-02-08 12:19:21 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
21-02-08 12:19:31 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-02-08 12:20:03 INFO (MainThread) [supervisor.snapshots] Found 5 snapshot files
21-02-08 12:20:21 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
21-02-08 12:20:21 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-02-08 12:20:21 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
21-02-08 12:20:21 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
21-02-08 12:20:35 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-02-08 12:20:35 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-02-08 12:20:35 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-02-08 12:21:26 INFO (MainThread) [supervisor.homeassistant.secrets] Request secret nodered_credential_secret
21-02-08 12:21:26 INFO (MainThread) [supervisor.homeassistant.secrets] Request secret nodered_usr
21-02-08 12:21:26 INFO (MainThread) [supervisor.homeassistant.secrets] Request secret nodered_pwd
21-02-08 12:27:08 INFO (SyncWorker_5) [supervisor.docker.interface] Restarting homeassistant/raspberrypi4-homeassistant
21-02-08 12:27:08 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:1000 is not str
21-02-08 12:27:08 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
21-02-08 12:27:19 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-02-08 12:28:07 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-02-08 12:28:07 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
21-02-08 12:28:07 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
21-02-08 12:28:07 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
21-02-08 12:28:08 INFO (MainThread) [supervisor.snapshots] Found 5 snapshot files
21-02-08 12:28:13 INFO (MainThread) [supervisor.snapshots] Found 5 snapshot files
21-02-08 12:28:42 INFO (MainThread) [supervisor.snapshots] Found 5 snapshot files
I have the same issue too !!..Just restored from a snapshot…!!
Restoring from a Snapshot isn’t solving for me…
The GitHub bug seems to be closed with no action.
Feel free to comment:
I did comment. My issue is that even if I would notify the addons coders I wouldn’t be able to update them because they can’t open.
Problem went away by itself. I guess the 15 restarts helped!
Lol, only 15?
Glad you got it sorted.
?@#!! after update.
System does not start complete, Node Red not starte, File Editor not started…
Will go to perform at least 15 restarts, anyhow I doubt that this will help.
There have been a large number of addon updates released tonight. Expect to see them soon. Pretty sure Node Red was among them.
@tom_I Thank you for your quick reply. I could start Node Red bio cinetic :wink:
With the perspective you gave me, I will stay calm and wait for better days (updates).
Merci M
Yep, it was updated:
Still in trouble. System does not start propoer. Downgrade by Snapshot is not performed. Update of HA is also not running (due to system does not start complete?).
Please, what to do, any help is welcome:
One of your addons has an incorrect option “guest” in it’s configuration.
See:
This should not prevent HA from starting, but fix it and see.
What errors are you seeing in your system logs?
Looks like the addons that use USB devices need updating too.
Z-Wave? Should I remove the stick?
Currently the Z-Wave devices could not connect (yellow… in Dashboard…).
Honestly, I can’t help you there, sorry. I don’t use zwave or know much about how it works with home assistant now.
