Supervisor Logs Extremely Slow to Open
For the last month or 2/3, looking at any of the logs in Supervisor or the containers take EXTREMELY long, where they used to be instant.
Anyone lese have this problem?
System Health
version core-2021.9.7
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.9.7
os_name Linux
os_version 5.10.17-v8
arch aarch64
timezone Europe/Amsterdam
Home Assistant Community Store
GitHub API ok
Github API Calls Remaining 4675
Installed Version 1.15.2
Stage running
Available Repositories 898
Installed Repositories 36
Home Assistant Cloud
logged_in true
subscription_expiration 20 October 2021, 2:00
relayer_connected true
remote_enabled true
remote_connected true
alexa_enabled false
google_enabled false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 6.4
update_channel stable
supervisor_version supervisor-2021.09.6
docker_version 20.10.7
disk_total 228.5 GB
disk_used 12.2 GB
healthy true
supported true
board rpi4-64
supervisor_api ok
version_api ok
installed_addons Samba share (9.5.1), Node-RED (10.0.1), Log Viewer (0.12.0), SSH & Web Terminal (9.0.1), Portainer (2.0.0), Visual Studio Code (3.6.2), InfluxDB (4.2.1), Grafana (7.2.0), Syncthing (1.18.3), ESPHome (2021.9.2), Glances (0.13.0), chrony (2.2.0), Mosquitto broker (6.0.1), File editor (5.3.3), Duck DNS (1.14.0), ArgonOne Active Cooling (24.1), Vaultwarden (Bitwarden) (0.13.0), AdGuard Home (4.1.9), Z-Wave JS (0.1.45)
Lovelace
dashboards 2
resources 17
views 12
mode storage
Spotify
api_endpoint_reachable ok
You can see here below that it took 1.2 minutes before the logs showed:
I do see some of these error messages in the console, unclear if it's related:
entrypoint.b658878e.js:16479 Uncaught (in promise) {code: 'unknown_error', message: ''}
Full message:
content.js:4 [Deprecation] chrome.loadTimes() is deprecated, instead use standardized API: nextHopProtocol in Navigation Timing 2. https://www.chromestatus.com/features/5637885046816768.
(anonymous) @ content.js:4
content.js:5 [Deprecation] chrome.loadTimes() is deprecated, instead use standardized API: nextHopProtocol in Navigation Timing 2. https://www.chromestatus.com/features/5637885046816768.
(anonymous) @ content.js:5
app.f08a72d3.js:5264 The main 'lit-element' module entrypoint is deprecated. Please update your imports to use the 'lit' package: 'lit' and 'lit/decorators.ts' or import from 'lit-element/lit-element.ts'.
55704 @ app.f08a72d3.js:5264
s @ app.f08a72d3.js:30632
53918 @ app.f08a72d3.js:1290
(anonymous) @ app.f08a72d3.js:30632
(anonymous) @ app.f08a72d3.js:36741
entrypoint.b658878e.js:38000 The main 'lit-element' module entrypoint is deprecated. Please update your imports to use the 'lit' package: 'lit' and 'lit/decorators.ts' or import from 'lit-element/lit-element.ts'.
5704 @ entrypoint.b658878e.js:38000
s @ entrypoint.b658878e.js:73826
4552 @ entrypoint.b658878e.js:65175
1625 @ entrypoint.b658878e.js:72024
7714 @ entrypoint.b658878e.js:6216
(anonymous) @ entrypoint.b658878e.js:73826
value @ entrypoint.b658878e.js:16479
async function (async)
_$AE @ entrypoint.b658878e.js:21033
performUpdate @ entrypoint.b658878e.js:21033
_$EC @ entrypoint.b658878e.js:21033
requestUpdate @ entrypoint.b658878e.js:21033
o @ entrypoint.b658878e.js:21033
b @ entrypoint.b658878e.js:21033
p @ entrypoint.b658878e.js:38000
F @ entrypoint.b658878e.js:16233
T @ entrypoint.b658878e.js:38000
_$AI @ entrypoint.b658878e.js:38000
update @ entrypoint.b658878e.js:38000
F @ entrypoint.b658878e.js:16971
value @ entrypoint.b658878e.js:72201
r @ entrypoint.b658878e.js:72201
F @ entrypoint.b658878e.js:17118
set @ entrypoint.b658878e.js:21033
value @ entrypoint.b658878e.js:17351
P @ entrypoint.b658878e.js:38000
m @ entrypoint.b658878e.js:38000
(anonymous) @ entrypoint.b658878e.js:17351
r @ entrypoint.b658878e.js:38000
(anonymous) @ entrypoint.b658878e.js:38000
Promise.then (async)
l @ entrypoint.b658878e.js:38000
c @ entrypoint.b658878e.js:38000
subscribe @ entrypoint.b658878e.js:38000
ws @ entrypoint.b658878e.js:17351
r @ entrypoint.b658878e.js:17351
finisher @ entrypoint.b658878e.js:21033
runClassFinishers @ entrypoint.b658878e.js:17351
7714 @ entrypoint.b658878e.js:17351
entrypoint.b658878e.js:15543 Uncaught (in promise) {code: 'unknown_error', message: ''}
value @ entrypoint.b658878e.js:15543
F @ entrypoint.b658878e.js:15386
Running HA OS or HA Supervised ?
I’m running HA OS
So it is on issue on both HA OS and HA Supervised.
I did find Supervisor issues 3014 and 3076 on Github
developing some addon currently and this drives me insane! Luckily i am not the only one…
Same problem here. Also Android app UI is extremely laggy.
I switched from hassio to debian 11 and it is fast as new :100:
Backup / Restore works great and took me nearly no work.
https://community.home-assistant.io/t/installing-home-assistant-supervised-on-a-raspberry-pi-with-debian-11/
After one week it is slow and unuseable again.
I’ve seen the same things since earlier this year on HASSOS. Here’s some example request timings when loading the logs:
endpoint time
/api/hassio/addons/core_check_config/logs 24.75s
/api/hassio/supervisor/logs 8.758s
/api/hassio/addons/a0d7b954_zwavejs2mqtt/logs 25.777s
I’m on a Pi4 + USB3 SSD. In the past, logs would load in no more than a couple seconds (not enough to notice or think about). My HA instance is generally snappy and responsive.
so, this drove me absolutely nuts, but i guess I found a solution this time!
After some reading I found that my USB3 SATA Adapter was not the one I thought I bought. Seems like Amazon.de send out different on the same name.
I bought this: Amazon.de
And it seems to exist as 174c:55aa and (like mine): 174c:235c
hdparm showed me extremely low values. After disabling UAS I now get this:
root@homeassistant:/usr/share/hassio/share# hdparm -t /dev/sda
/dev/sda:
 Timing buffered disk reads: 542 MB in  3.00 seconds = 180.64 MB/sec
And for a pretty cheap SSD with a full running system, this is totally fine.
Logs are fast as desired now <3
This helped me: STICKY: If you have a Raspberry Pi 4 and are getting bad speeds transferring data to/from USB3.0 SSDs, read this - Raspberry Pi Forums
I also have an SSD, and I checked the speeds with hdparm -t /dev/sda, I have not disabled UAS and I get the below:
Timing buffered disk reads:  637 MB in 3.15 seconds = 206.753 MB/s
My logs are all still extremely slow…
give disabling UAS a try? :slight_smile:
This might be a total silly question, but it seems I don’t have hdparm at all on my installation (Raspberry 4).
Also, I don’t have e.g. apt-get to install it. How can I install hdparm?
I ran it by doing an SSH into the OS itself (port 22222).
Normal SSH goes into the HomeAssistant container.
Assuming you’re running HassOS…
This seems not to be possible on a Raspbian installation, at least remote. Might have to find an HDMI cable and boot it with keyboard & screen attached…
So booting with a screen & keyboard attached, I could run hdparm on the Raspberry installation. It says it read 716MB in 3 Seconds, which is ~250 MB/s. This should be more than sufficient, but as @Veldkornet wrote, it still feels much slower and less snappy than it did earlier…
Disabling UAS as @MaxW mentioned solved the issue with the logs for me. Also restarting the core and loading of the history is much faster, now. :+1:
You’re right, the logs are fast again. Weird that my speeds didn’t seem to change though:
Timing buffered disk reads:  636 MB in 3.00 seconds = 217.004 MB/s
FYI, I have an Argon One M.2 with a Samsung M.2 SATA SSD and my cmdline.txt ended up looking like the below:
usb-storage.quirks=174c:55aa:u dwc_otg.lpm_enable=0 console=tty1
I might be wrong with the speed thing as proof, but I can recommend everyone with issues to try the UAS disabling thing.
