swin66
(Paul)
October 6, 2020, 11:16am
1
Rpi4, 4GB, 32bit, Fresh install of hassos_rpi4-4.13
All installed, booted and basic setup of devices ok.
However, when I click on the “Supervisor” link (http://homeassistant.local:8123/hassio ) the page never loads and that browser tab has to be closed. I can open another browser tab instance and do something else, but something is wrong with the “Supervisor” option. I’m new to this but I can;t see any obvious errors.
Any ideas?
skutter
(John)
October 6, 2020, 11:31am
2
Hi Paul,
Have you enabled Advanced mode under your user profile?
It can be found by clicking on you user icon in the bottom right of the sidebar.
swin66
(Paul)
October 6, 2020, 12:47pm
3
Thanks, I hadn’t, but have now.
Unfortunately, it made no difference.
swin66
(Paul)
October 6, 2020, 12:53pm
4
I am using Chrome browser, but I’ve just tried it on a different browser (Firefox & Edge) and it works fine there.
I would guess that it’s ok for most on Chrome so it may be one of my extensions buggering it up.
boelle
(Bo Herrmannsen)
July 17, 2021, 10:55am
5
I have the same issue
Tried Chrome, Chrome incognito and Edge and its the same thing
No erros anywhere else and no notofications, config is ok when i use “check configuration” under server tools
its running on a raspberry pi with the raspberry pi image
boelle
(Bo Herrmannsen)
July 17, 2021, 10:56am
6
that was enabled, what else could i provide that might help?
i have seen this similar reported here:
When I try to access /hassio/dashboard from the sidebar the page doesn’t load.
The sidebar i still there and the Hass.io link is displayed but when i press it the page just goes white.
It loads fine in my iOS App on my phone. I’ve tried with a bunch of different browsers on different computers, restarts, clear cache and so forth without results. Any ideas?
but that one says its a theme but i have not changed the default one, and they said incognito works but that is not the case for me
EDIT…
did an inspect and found out this
so some kind of access problem i guess but where?
i also tried this: Default dashboard won't load after update do 2021.2.0 - #6 by metsessantaset
sadly that did not help, i did have a device inside an area that had the same name, changed the area name but no luck
EDIT…
After a reboot the dashboard isn’t loading.
I can access to ssh or samba, but the dashboard isn’t working.
hassio ha restart
ERROR
panic: interface conversion: interface is nil, not string
goroutine 1 [running]:
panic(0x2c7050, 0x1070b600)
/home/travis/.gimme/versions/go1.7.6.linux.amd64/src/runtime/panic.go:500 +0x33c
github.com/home-assistant/hassio-cli/command/helpers.DisplayOutput(0x107b8200, 0x24, 0x200, 0x0)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/…
that did not help me either
boelle
(Bo Herrmannsen)
July 17, 2021, 11:31am
7
not sure if that cured it
but a full reboot did it for me so far, seems to easy and i fear that the issue could still be hiding somewhere
janbenes
(Jan Benes)
August 10, 2022, 4:33pm
8
From a few days ago, I have same problem. I did no HA updates, no OS updates. Just grafana stops working and when I go to add-ons, page does not load. All reports are “fine”…
